Crest CPX1500
  • 5inc
    • 120
    • Spain
    Crest CPX1500
    I have this dead crest amp, a friend gave it to me to play around years ago. Apparently it got blasted by a surge in a party and the big caps popped, a few resistors burned up, some diodes died and a pair of power transistors got shorted.
    I begun experimenting on it before I knew about the use of variacs or low-voltage operation for repair, and plugged it straight into mains, big mistake. That tought me a valuable lesson in it's day, but also made the repair go 2steps back. Now I'm back on the move, a bit more experienced and I want to get to the bottom.
    Allthough after replacing everything I suspected was failing, I still face a shorted amplifier.
    I don't have a variac yet, so I built 2plugs in series to plug in a 2000w light bulb and the amp for testing purposes. The bulb lights up shy and then shines brightly. Protect lights stay on, no fan.
    Tried isolating the problem by disconnecting everything possible but it narrows down to power supply, at the least. And I fear the transformer may be shorted.
    Could I test that by simply disconnecting and isolating the secondary leads and plugging it in to check for short?
    thanks!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Crest CPX1500
    Is that a linear (50Hz, big iron) transformer?
    --- EDIT ---
    Yes, it is.
    Step one: search for service manual -
    Step two: yes, disconnecting the secondary of the transformer from the rest of the circuit should be enough to see if it puts out the voltage it's supposed to.
    Given that the CPX 1500 has 100V main caps, i'd expect something along the lines of maybe 80V DC across each, which would require 2x 55-60VAC at the input of the bridge rectifier (ie. measured between TX13 and TX12/TX14, and then TX16 and TX15/TX17 respectively), or 110-120VAC (between TX12 and TX14 / TX15 and TX17).
    Obviously, you'll want to measure that with alligator clips connected to the transformer leads (and NOT holding them with your hands )
    You'll wanna take a look at that crowbar(?) protection circuit that's between the speaker output and ground. There's a good possibility that's (also) toast, and what's keeping the protection tripped.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Longbow
      • Jun 2011
      • 623
      Re: Shorted Crest CPX1500 with protect leds
      Yes. But probably not necessary. Check your diode bridges in the secondary.
      Is it plugged in?
      • 5inc
        • 120
        • Spain
        Re: Crest CPX1500
        My original question was aimed towards getting a burnt transformer diagnosis, why?
        because I believe I get a short circuit, since the 2000w lamps shines bright. It has burned some component in front of my nose before, so I'm not so comfortable leaving it on for longer periods, can't read much in that time.
        I just checked the the bridge rectifiers and diode bridge and they all seem ok.
        First I'll have a look at the schematics again to see that crowbar protection circuit you mentioned Khron, but again, my gut tells me it might be the transformer (really hope not), if I don't see anything there I'll go ahead and disconnect it.
          Re: Crest CPX1500
          Is there anyway you can disconnect the secondary side winding from the the load so all you will have is the primary winding to test and see if the lamp will still light up brightly?
          Pictures of what we are dealing with?
          • 5inc
            • 120
            • Spain
            Re: Crest CPX1500
            okay, we have a picture of the amp in question. I'm in the process of disconnecting the secondary windings.
            https://s27.postimg.org/kd8h9kiyb/20170126_231902.jpg
            yes budm, I think what you mean is exactly what I was asking in the begginning.
            • 5inc
              • 120
              • Spain
              Re: Crest CPX1500
              hurray, just disconnected secondary leads, plugged the amp in and the bulb doesn't shine, at all. Tested for voltage on the back of the mains socket and I get a normal 260vac, that makes me really happy.
              Since I have no idea where to attack now, I will connect one of the 3 secondary windings, and check for short untill I hit the defective one. If it shows up.
              But that will have to be tomorrow, I have a hard day ahead.
              thanks lads
              • 5inc
                • 120
                • Spain
                Re: Crest CPX1500
                I will also check the voltages before I start connecting windings too.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  Re: Crest CPX1500
                  Next step would be, with or without the transformer reconnected, to check for a short-circuit between the speaker output posts.
                  • 5inc
                    • 120
                    • Spain
                    Re: Crest CPX1500
                    ok people, I just checked voltages on secondary and I have a steady 30-0-30vac through oranges-white, and 80-0-80vac on blues-white and reds-yellow.
                    No short between speaker outputs, so I will now start by connecting an 80v line, then the other and then the 30v one to see which ones are shorted.
                    • 5inc
                      • 120
                      • Spain
                      Re: Crest CPX1500
                      I isolated the problem down to the 30v line.
                      Gonna have a look around for shorts and where it goes.
                      testing was made with only colour power leads connected, no link connectors connected to main boards.
                      • 5inc
                        • 120
                        • Spain
                        Re: Crest CPX1500
                        okay khron, I didn't knew what the hell you were talking about with the crowbar protection circuit, googled it and I have found this CR320 in the schematic, read resistance through it and I get 5.3ohms, and CR321 reads 1.2ohm. Are those zener diodes?
                        https://s30.postimg.org/83ola6kgh/20170127_231739.jpg
                        thanks!
                        • petehall347
                          • Jan 2015
                          • 4451
                          Re: Crest CPX1500
                          if you remove the wires that come from the +-15v power supply and also the 28v take off that connects to c401 you can fire it up to test that regulated supply is working .. if it is you could then check for short circuit from ground to each of the wires .
                          wires should go to c403 c404 .
                          cr320 is a 22v 1/2w zener
                          c321 is a 30v 1/2w zener .
                          you could also pull the 28v take off first ... this is power supply for fans etc and where those diodes reside
                          • 5inc
                            • 120
                            • Spain
                            Re: Crest CPX1500
                            right... i think I get it. I have one thing to say though, there is no wire that connects to c401 or c403 or c404, it's all on lines the board.
                            but taking r330 and r338 out might take down the 28v input... I'll try that
                            • petehall347
                              • Jan 2015
                              • 4451
                              Re: Crest CPX1500
                              yes it should work .. plus it should keep at least some of the thermal circuits intact if i am looking at it correctly .
                              • 5inc
                                • 120
                                • Spain
                                Re: Crest CPX1500
                                no luck still get a short, if I also disconnect one lead of c401 +28v dies?
                                • 5inc
                                  • 120
                                  • Spain
                                  Re: Crest CPX1500
                                  sorry, I meant c402 -15v dies?
                                  • petehall347
                                    • Jan 2015
                                    • 4451
                                    Re: Crest CPX1500
                                    disconnecting c402 is no use .. same with c401 ..
                                    +28v is tapped off before the +-15v regulators . so short is before or after the regulators ..
                                    test rectifier diodes cr400 401 402 403 .
                                    also the other diodes in that circuit .
                                    • petehall347
                                      • Jan 2015
                                      • 4451
                                      Re: Crest CPX1500
                                      i suppose you could check input and output sides of the regulators for short to ground .
                                      u400 u401 ..
                                      or if its easy to remove them do that and see what happens .
                                      • 5inc
                                        • 120
                                        • Spain
                                        Re: Crest CPX1500
                                        ok, I took the regulators out, plugged in and no short. While I was reconnecting them i got a spark between 2legs of +15v regulator(I luckilly have a couple lying around so I just replaced it), from the main capacitors i guess.
                                        When I plug everything back on I still get the short. That's probably because I still haven't removed the bad zeners, so I'll get down to that now. I don't know if I should test it without anything in there. Should I?
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
