Aiwa MX-Z3300M receiver repair, no display, capacitors in series
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This is a common fault in this amp model and others from Aiwa, same age. VFD display doesn't work. Everything else OK, if you can operate it blindly.
    The culprit is C15 and C16. C15 is 47uF/50V and C16 is 33uF/50V, both electrolytic. They put two 50V caps in series to get a 100V cap, but this is as crappy as putting rectifier diodes in parallel to add current. It works for a time, but ends up unbalancing and one component is exposed to more voltage (case of capacitors in series) or to more current (case of diodes in parallel) than the other, exceding its maximum and failing prematurely.
    I've repaired this receiver two times. 2008, 2012 and now. It lasts 4 years. Now I want to do something different. This means an equivalent 20uF/100V, not easy to get. Perhaps this is why original enginer splitted it in two.
    I attach schematic fragment. Any smart idea?
    Re: Aiwa MX-Z3300M receiver repair, no display, capacitors in series
    It uses those caps to drop down the ACV feeding the rectifier/ dual Voltage linear regulators circuit to drop -70vdc down to -32V.
    May be you can use this:
    http://www.parts-express.com/22uf-10...citor--027-348
    Or you can tap of the -42V to generate the needed regulated -32V.
    • Chungalin
      • Jul 2014
      • 422
      • Spain
      After removing both caps, the only one that’s failed is C16 (null capacity and huge ESR). C15 is apparently not bad.
      When I’ve seen your link with 22uF/100V unpolarized cap I’ve had an idea: you’re right, ideally, this should have been an unpolarized cap.
      I have two good Rubycon 33uF/100V caps. I’ve recalled when I searched some time ago how to make an unpolarized cap from two polarized. I’ve put one in C16 position, with same polarity as marked in PCB, and C15 with reversed polarity. Now both positive terminals are in contact. This acts as a 16uF/100V unpolarized cap. It works, as expected. Question is: will we talk again about this in four years?
        • 31028
        that's interesting, i have an Aiwa unit at the back of the stack of busted stuff with a very weak display.
        have to go pull it out for a fresh look.
        • Chungalin
          • Jul 2014
          • 422
          • Spain
          This no-display failure may affect other models, like MX-Z3200M, MX-Z9400M, etc. Any one that looks similar to attached pic (this is from another repair shop in Spain, not mine).
            • 31028
            similar, but the one i have is about 3 times as tall and has double tapedecks at the bottom!!
            • Tube_Dude
              • Feb 2011
              • 51
              Hi, Budm
              Quite the opposite. These capacitors are part of a voltage doubler circuit working together with D15, D16 and C17. They turn the input 30 Volts AC in 70 Volts DC at the input of the pre-regulator transistor T15...
                Originally posted by Tube_Dude
                Hi, Budm
                Ah I see now, you are correct, the feeding Voltage is only 30VAC, I did not see the D16 earlier which is blocked by the red circle which is part of the Voltage doubler circuit. Thanks.
                I still do not see why they need to convert the 30VAC to -70VDC to feed two series connected regulator transistors just to drop it down to -32V when they could have use 30VAC to produce the -42VDC and regulated it to the needed -32VDC.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Originally posted by Chungalin
                  This is a common fault in this amp model and others from Aiwa, same age. VFD display doesn’t work. Everything else OK, if you can operate it blindly.
                  I’ve repaired this receiver two times. 2008, 2012 and now. It lasts 4 years. Now I want to do something different. This means an equivalent 20uF/100V, not easy to get. Perhaps this is why original enginer splitted it in two.
                  If a cap is in series they act as resistors do in parallel or vice a versa. http://www.allaboutcircuits.com/text...el-capacitors/ Sorry I read the Volts on the caps as uF.
                  • Tube_Dude
                    • Feb 2011
                    • 51
                    Me too! Can't see any good reason for the extra expenditure...!
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      If these are electrolytic caps connected directly to AC voltage and there is a significant swing on them they will wear out fast. Better to replace them with non-electrolytic. It will be a much bigger cap. Or buy a bunch of the electrolytics and have a maintenance schedule to replace them.
                        https://en.wikipedia.org/wiki/Voltage_doubler
                        http://www.electronics-tutorials.ws/...r-circuit.html
                        https://en.wikipedia.org/wiki/Voltage_multiplier
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Interestingly enough I see no + marking for electrolytics in any of the diagram on that site. Electrolytics do not like being charged and discharged. They can accept a low tolerance of this as one would see on the output side of a bridge rectifier. The input side would be another thing. When they reverse current through them as a discharge would do they are not made to operate in a reverse current mode. This is why there is a time limit on electrolytic caps.Where a non-electrolytic cap will last way longer. In the thread the person replaces these every 4 years which also attest to the problem.
                            The polarity of the caps (if polarized caps are used) will be based on if you want + output with ref to GND or Negative out put with ref to GND, so the polarity of the cap (lytic caps) and the direction of the diodes will have to be installed correctly. The cap is not exposed to reverse bias due to the diode is not conducting in one half of the cycle. You have to draw the charge and discharge path to visualize it.
                            The old PC power supply with 120/240V selector switch uses the same topology.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              I did not say reverse bias I said discharge. They do not like to discharge as the current has to go in the reverse direction. It does not have to have the cap having a reverse voltage between the positive and negative terminals to have reverse current. When the voltage on the cap goes from say a positive 10 Volts to a positive 8 volts in order for that cap to do that it will be exposed to a reverse current because it is a discharge state.
                                This one may have better explanation as to what happen in each half cycle of the AC and how the current flows in the circuit and how they are charged and discharged.
                                https://upload.wikimedia.org/wikiped...er_explain.png
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  If you will look at this and see how the progression was made away from tying them directly to the Ac line that is allow to discharge the caps. In the Dickson charge pump they are not allow the discharge the caps stay at there potential as the diodes stop any reversing of current. In the stacking you can see a the first cap is in series with the rest of the circuits and is subjected to discharge.
                                  Although some leakage current will go through the diode in the reverse direction but it will be tiny.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Bud M I looked again at your reference I think there is a lot more finesse going on then what is explained.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      ran out of time limit here is the rest
                                      Bud M I looked again at your reference I think there is a lot more finesse going on then what is explained. So I read your first source fully understand the principle of a perfect circuit. However when they say this builds up in more than a few cycles. There is discharging and charging of capacitors in place. Which will cause some ripple and unlike a full wave rectifier which is making all the ripple in one direction both cycles are used in opposite directions so the ripple will be in both direction. The amount of this ripple will adversely affect a electrolytic cap, depending on the amount and the current strength behind it. These voltage multipliers are used in low current high resistance outputs so maybe in these conditions the electrolytics would not be as affected as much, however they will be affected. As I have said above it depends on those factor as how fast the cap wears out. Along with how often the circuit is turned off and on and the length of time the electronics have been on. Now, that I know this fully it will be in a couple of week and I will forget most of it. Thank BudM for your references.
                                      • makissat
                                        • Nov 2017
                                        • 3
                                        • Greece
                                        Hello guys! I have the exact same problem that is shown in the following video
                                        https://www.youtube.com/watch?v=spD4YjYrgcQ
                                        I have already changed the capacitors C15 and C16 but the display still doesn't works. Any ideas please?
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
