Mackie CR4 monitors
  • UserXP
    • Apr 2012
    • 356
    • Serbia
    #61
    Re: Mackie CR4 monitors
    Originally posted by Xebozone
    Yes please. That is what I purchased (and what the article I mentioned suggests making). Would like to know how to wire it all in too. My speakers are collecting dust
    Hi. I received the module and installed it, works very promising. I will put additional info with images soon. :-)
    • UserXP
      • Apr 2012
      • 356
      • Serbia
      #62
      Guys, I just want to add an update to the problem regarding the overheating +/-12 regulator on this PCB. I ordered and finally received the dual voltage regulator module based on LM7x12 parts (after 29 days of delivery time). I ordered two of these for $6 and they seem to be built quite sturdy. Both positive and negative rails have an input and output filter capacitor rated at 35V220uF. The two red LED indicators are SMD parts, and the PCB looks clean and quality soldered.
      I installed one of the modules into the powered speaker. The red light from the LED indicators does not bleed through any opening on the front side of the speaker. Of course, the procedure may or may not apply to your set of speakers. Should you try to do any of this, the responsibility falls entirely on you.
      Items required (in my case anyway):
      1 X LM7x12 1V dual voltage regulator module
      1 X M3 stand-off with one end bolt-threaded (I only had a 10mm one)
      1 X M3 screw (I used one with an integrated washer and a spring-washer)
      5 X pieces of wire (I used those from and old PSU: three for input and two for output)
      Now, I have included the pictures of the module and the schematics. They are not the clearest as this is the first time I have done something like this and I used the image previously mentioned in the German author's post. But at least it's something.
      The module has an input connector, which needs two +/- AC lines and a ground line to work. The ground on the input side simply passes to the output GND connector, which is why only the input GND wire is required. There is no need to mount the GND wire on the output end.
      Also, R1, R2, Z3 and Z4 components need to be removed from the speaker's PCB. Clear their holes of solder as wires can then be threaded through the PCB and soldered on the other side.
      1) Now, the AC inputs on the module are to be connected to the incoming voltage points on the PCB (+ and - 20 V in the image), where the pins of the resistor used to be soldered. You can connect those points to the AC input on the module any way you like because the module includes a rectifier and allows both AC and DC input, so it will sort out the rails as necessary.
      2) I connected the GND wire to the point where a zener diode used to be soldered, as this point is the actual GND rail on the speaker's PCB.
      I used a black wire for the GND, and orange wires for each of the AC input lines.
      So, the wires connected to the speaker's board, going from the left to the right, are Orange (+), Orange (-), Black (GND).
      3) The module dynamically outputs only 12V of the incoming voltage. These are the rails that we need to connect to the speaker's PCB where zener+resistor combo used to output the 12V (take a look at the included photo). The output connector of the module is connected to the second point of R1 and R2 respectively. Now, here you must not make a connection wrongly. The positive goes to the +12 marking on the PCB, and the negative goes to the -12V on the PCB.
      I used a black wire for the negative, and a red wire for the positive output.
      So, the wires connected to the speaker's board, going from the left to the right, are Red (+12V), Black (-12V).
      Now for the mounting: I removed one of the screws that mounts the heatsink to the metal holder on the PCB. I used the stand-off as a screw to re-fasten the heatsink mount, and then mounted the module onto the stand-off. I didn't remove the heatsink to drill another hole because it would require to remove the amplifier and there was no need to do so. One screw with a spring-washer is all that it took to fasten the module sufficiently, so now it kind of floats 10mm above the heatsink.
      The clearance between the magnet of the 4" driver and the back plate is 12cm. When the module is mounted like in the photo, protruding slightly toward the driver, the overall length is 10cm, which leaves 2cm of clearance for the wires inside the speaker's casing - more than enough. So nothing is hitting or compressing anything.
      Please take a look at he included photos and give me your thoughts on this. Hopefully, this can help others in repairing their Mackies. I don't know why the company chose to use zeners and resistors, especially if they get hot enough to burn the PCB an potentially cause fire. A 3$ part really wouldn't increase the price to much. Unless planned obsolescence was into effect.
      • nings
        • Apr 2010
        • 13
        #63
        Thank you UserXP
        Same HP and same problem but not opened for the moment probably burned too.. never understand manufacturer to put noname cap and design bad pcb we should use 24/24h 7/7d just for return under warranty each time
        Are you happy about the result ? No more heat ?
        What about Z2 (?) the diode you removed here https://www.badcaps.net/forum/showpo...2&postcount=17
        I view this diode exploded on one picture of another customer no overheat problem there with the dual voltage regulator ?
        I order this DIY part on Banggood because want try a backside mount of both LM to put them directly on the big radiator with a heat transfer pad for isolate ground.
        (Link if someone interested : DIY LM7812 LM7912
        Thank you for your time and sharing all information
        • UserXP
          • Apr 2012
          • 356
          • Serbia
          #64
          Originally posted by nings
          Thank you UserXP
          I'd asked myself the very same question, so I had to reopen the powered speaker while it was on for over two hours just to inspect the inside situation. The results are that the PCB no longer becomes hot at that R1/R2 area. The regulator module itself works quite cool, its heatsinks were barely mild to the touch and I think they actually warmed up to the inside temperature of the powered speaker, which would rise after a prolonged use due to the transformer. But the PCB itself no longer felt hot to the touch in the designated area. Of course, mounting the power supply externally would reduce the inner temeprature drastically. I haven't done that (yet) so I suspect some more of the smaller caps may eventually fail due to the heat. But at least (hopefully), nothing else will burn.
          That broken diode, in my case, was D1, a regular diode, which was rusted and broken. I replaced it with the same type, which is 1N4148. I suspect it was covered in some acid-based soldering flux, which ate the metal away and caused the diode to break.
          Yes, that could work, just make sure you use pads plastic washers for the screws to completely isolate the LM regulator from the heatsink (if you have a broken PSU, it is a great source of isolation pads, plastic washers and designated mounting screws). I also considered ordering a DIY version of this module as additional bridge rectifier or LED indicators wouldn't be needed, and the wires could be soldered directly onto to module's PCB - but I opted out for the completed one as it was actually cheaper. Seeing how little heat the module produces, I believe it will last long with its preinstalled heatsinks. So I opted not to drill aditional holes into the amplifier's heatsink. I am quite happy with how the mount came out as it aurely won't be touched or moved by anything inside, it stays quite firm on only one screw with a spring-washer. And most importanly, the speakers work great, no more cut-outs, hissing or crackling sounds. I now also turn them off using a back switch when they are not in use.
          You're welcome. Hopefully, this info will help other people having similar issues, I guess sharing information and findings is the main point of this entire forum.
          • willstatus
            • Jul 2020
            I stumbled upon the same German instructions and outside of doing my own minor soldering here and there, my only electronic circuitry experience was my high school electronics class 2 decades ago.
            While the Germans instructions were certainly vague, I felt that they gave you just enough info if you were willing to learn. That said, I stumbled across this forum and your solution is much more preferable. It also confirmed my theory of how the wiring should be. Thanks so much for sharing. I've been obsessing over this the past week and my speakers have been out for roughly a month now.
            • willstatus
              • Jul 2020
              On that note, I was not willing to wait for the shipment from China. I saw the DIY kit and that seemed reasonable as well. To my surprise, I was able to find the unit on Amazon that has Prime delivery.
              https://www.amazon.com/KNACRO-Voltag...237700549&th=1
              • UserXP
                • Apr 2012
                • 356
                • Serbia
                #67
                That's great! I'm glad you found this post informative and useful. Several months have passed since the repair and my speakers are still alive and kicking!
                Also make sure you check the caps on the main PCB as some may have failed due to the extreeme heat the original voltage regulating components produced.
                • nings
                  • Apr 2010
                  • 13
                  #68
                  Just two new pictures if can help someone other with the rear side
                  D1 => Added a second diode for reduce a little heat because already view one D1 diode burned
                  C80,C81,C74,C37,C38,C39 => these capacitors have high ESR so replace all just for be safe
                  Sorry, I didn't take pictures afterwards but I had to make a hole in the radiator to put a screw and then add thermal paste to make contact with LM and the radiator.
                  The temperature has gone down and no more problems since
                  • UserXP
                    • Apr 2012
                    • 356
                    • Serbia
                    #69
                    That's great, I'm glad you fixed yours as well.
                    When you have the time, please add some images so we can see how you modified/repaired your pair of Mackies. It is always nice to see those, and it encourages learning experience.
                    • UserXP
                      • Apr 2012
                      • 356
                      • Serbia
                      #70
                      Hello, people.
                      Sorry for resurrecting this old thread, but I felt the need to share this with you.
                      I have repaired another amplifier unit (I found a complete Mackie CR4 Limited Edition set that was a write off by the previous owner because it stopped producing sound). Again, the fauly capacitor C39 was the reason for the unit not producing any sound. I used the LM7X12 voltage module modification and replaced the small capacitors (all 16V100uF and 50V1uF ones) near the amplifier. Now I have this Limited Edition version unit working too, alive and kicking!
                      Thank you all for your help back then, this fix clearly can bring these great speakers back to life. This and the other thread could be of help to others who want to try and fix their Mackie CR4s speakers.
                      • shanghaidaddy
                        • Nov 2019
                        • Indonesia
                        #71
                        Thanks to this thread, I just replaced the capacitors and removed the failed DPDT switch in my CR4.
                        • sammymorrison1
                          • Jan 2022
                          Spent a couple hours delving into this problem tonight as my speakers were starting to have the problem. Just starting though so hopefully I caught it at a good time. Anyway... had those exact thoughts about the resistors being way too hot. Had the same thought of staggering them like you did hahah. However I'm glad I kept reading because your little board implementation is genius. THIS is the fix that needs to be on youtube/first google results. I thought when I saw cutting pin 5 to be the fix, it didn't address the true problems. I bet these speakers will last forever now. Thanks for all your work. Will be doing this soon!
                          Oh and to address your cost comment... maybe it was poor design, not enough testing, or planned obsolescence... the company wasn't going out of its way to do a redesign and spend $3 dollars per board to fix. 3 doesnt sound like a lot but sure does cut into profits over a ton being produced. Sadly I don't think reputation matters as much to these companies as much as a quick buck.
                          • li_gangyi
                            • Sep 2009
                            #73
                            Implemented my own variant of this fix. I had more damage around the PCB that affected the mute circuitry though.
                            https://fillwithcoolblogname.blogspo...r4-repair.html
                            • UserXP
                              • Apr 2012
                              • 356
                              • Serbia
                              #74
                              Great work! I am glad my topic has helped you fix your Mackies. As all the good people here on this forum directed me towards me fixing mine.
                              Now, I haven't replaced all the capacitors like you did. But the TDA7265 puts out a lot of heat and the mute problem should be at bay with quality capacitors like the Japanese ones.
                              I also don't understand the manufacturers. Instead of those two zener diodes and two resistors, they should have used two LM7x12 regulators and made a PCB that wouldn't have been a fire hazard.
                              • Xebozone
                                • Sep 2019
                                • 7
                                Thanks so much for your post!
                                As I'd mentioned in a previous post of mine, I also bought one of those modules but did not know how to wire it. Actually, turns out that I had wired it just fine. Your post confirmed it. I also removed Z3 and Z4 (one of which literally fell apart!). My board is heavily burnt and damaged with cracks. By analysing the photos of traces, I managed to wire components together correctly where the traces had burnt or the board had cracked.
                                ​​​​​​Other changes for me were:
                                I had also cut the mute pin on the TDA previously. I left it like that.
                                I replaced all of the 100uf16v caps around the burnt 12v circuit and also a 1uf16v cap around the area.
                                I removed the L-R switch and jumped it in the R position as my switch was failing.
                                Things seem to work for me now...almost...
                                Maybe someone can share some insight on what I can do next:
                                ​​​​When I turn the power on the speakers, even with the volume at 0 (and the front LED off), they start to make an electrical buzzing sound out of the powered speaker...kind of like when you half connect a 3.5mm audio jack. I can't really explain it, but I suppose some current is leaking into the audio circuit. No input audio works even when I turn the volume up, I only hear this sound. The volume switch doesn't increase the volume of this sound. The headphone jack does work as usual, but the main speakers still buzz.
                                I found that by SLOWLY moving the power switch from the off to the on position, it resolves the issue...or I can turn the power off and on rapidly and that sometimes works. Then the buzzing sound stops and the speakers work perfect all day until I power off the speaker for a while at the AC switch or wall until the next day's use.
                                I may also note that the speakers make a boom or a pop sound when they power on or off. I suppose the mute switch is supposed to help with that but I cut it
                                Does anyone know what I can look into next to resolve my buzzing powered speaker issue? Does it sound like I need to replace more capacitors, or is a diode behaving badly? I see a poster above replaced their 4700uf capacitors. I'm not sure if that's what I should do too?
                                Much appreciated for your time
                                • UserXP
                                  • Apr 2012
                                  • 356
                                  • Serbia
                                  #76
                                  You may need to replace one (or both) of those big 35V4700uF filtering capacitors.
                                  also, check the two 10V220uF caps, they are in the 5mm diameter format and will fail quickly due to small size for the raiting.
                                  Also, don't use 16V1uF capacitors, use 50V1uF. Those are connected to the ground on one end and the voltage at which the amplifier works is around 20 volts. That can overload the 16V cap and will cause it to fail.
                                  • Xebozone
                                    • Sep 2019
                                    • 7
                                    Thanks very much for taking the time to reply.
                                    I sold my speakers to someone who was happy to continue my repair. I was moving house and didn't have the space for them. Thanks to you however, I was able to enjoy using these speakers for a long time, learn a lot, and save another device from becoming waste!
                                    Wishing you all the best.
                                    • UserXP
                                      • Apr 2012
                                      • 356
                                      • Serbia
                                      #78
                                      You are welcome. Sorry I saw your original post way too late. I didn't get a notification about new replies. :/
                                      Yes, these speakers are great, mine still work great after the modification, without overheating any more. I've also made some changes in my room, got a bigger desk and these speakers sound much more "bassy" on a wider desk, probably due to more resonance.
                                      Best of luck, take care.
                                      • Flaku_34
                                        Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                        by Flaku_34
                                        Introduction:
                                        Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                        04-18-2024, 12:47 PM
                                      • madan1
                                        Mackie Th15 SMPS low Vout
                                        by madan1
                                        I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                                        It is basically a smps with amp and some dsp.
                                        The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                                        Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                                        By the way, the ferrite core of L10 is broken,...
                                        02-16-2025, 04:15 PM
                                      • BigOof
                                        Pioneer RM-07 Active monitors cutting out from time to time
                                        by BigOof
                                        I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
                                        12-18-2024, 04:35 AM
                                      • jolivares
                                        Black tape in the mainboard inside apple's devices
                                        by jolivares
                                        Hi everybody.
                                        i'm looking for the black tape inside apple's devices.
                                        Is the tape tha covers the shield on the mainboard. when you take it out, loses the adhesive.
                                        It is very thin.
                                        can somenone help me to find it for a better repair?
                                        Thanks, God bless you.
                                        09-09-2024, 08:07 AM
                                      • PedroGG90
                                        How to bypass hp pavilion laptop booting only if battery is inside ?
                                        by PedroGG90
                                        Hi everybody .
                                        I have a hp pavilion dv 9500 ef laptop that i think is designed to boot only if battery is inside , and my battery is dead .
                                        Any way to bypass it and make it work from power brick only without the need of a battery ?...
                                        02-15-2024, 08:19 AM
