Digital amp kits
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Digital amp kits
    theres a lot of noise on various forums about these digital amp parts http://www.hypex.nl/
    looks really interesting
    http://www.gweep.net/~rocko/UcD400/
    and not that difficult
    http://www.tnt-audio.com/ampli/udc180_e.html
    http://home.wanadoo.nl/dezaire/UcD180AD/UcD180AD.htm
  • Logistics
    • Apr 2007
    • 721
    Re: Digital amp kits
    You mean Class D amplifiers? They became a popular item because of their simplicity and ability to create lots of power for cheap, but they also make more distortion so they are commonly used for subwoofer amplifiers where that is not such a big deal. (to some people, anyway) If you're looking for something HiFi, you don't want Class D.
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      There are some class D hi-fi amplifiers: mine is the old Sonic impact T-Amp employing a Tripath chip, but they're manifactured from Nuforce, Pioneer, Marantz and others (there is even B&O, but I would consider it a "life style equipment" producer more than a hi-fi manifacturer). Most chips are cheap, are reliable, deliver a lot of power and are employed in "professional" gear (discos, live concertos and such) but they're like diesel engines: adopted by trucks and even by cars (at least in Europe).
      Anyway I'm not mad at you, only a bit curious:
      1) which class D amp did you listen in order to detect such a distortion?
      2) tubes amps are known for their analog sound: isn't analog sound a distortion of odd-order harmonics?
      Zandrax
      Have an happy life.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Sorry, I wanted to write even-order harmonics, which are more pleasant for the ear than odd-order ones.
        Zandrax
        Have an happy life.
        • i4004
          • Oct 2006
          • 2029
          logistics i think you didn't read all links willa provided...
          zandrax: one of willa's links is comparing this to tube amp sound.
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            I know and you got my points: the UcD goal is to sound analog, tube-like, which means coloring the sound with even-order harmonics.
            Since Logistic is pointing out distortion as a weakness for class D amps (I think he's referring to odd-order harmonics distortion, which is unpleasant to listen to: sound become quite harsh) and suggested looking for other amps, I wanted to know which amp did Logistic listen to and to discuss my thoughts:
            - if distortion is something to be minimized in an hi-fi amp, then tube amps aren't strictly speaking hi-fi gears because of even-order harmonics distortion;
            - if tube amps are hi-fi, then the UcD is hi-fi too because it sounds like a tube amp; furthermore, this means that class D equipments sound so different from each other you can't draw general conclusions, only per-case ones.
            At least these are my 2 cents.
            Zandrax
            Have an happy life.
            • Logistics
              • Apr 2007
              • 721
              I'm not comparing tubes to solid-state, I'm comparing Class D design to typical Class AB and A. You can make an exotic sounding Class D amplifier, but Class D is not accepted by most as HiFi; probably because of the more complex design and the required integrated circuitry involved. In my experience, when dealing with Solid State, HiFi usually comes in the form of a large (due to necessity) amplifier using a linear PSU (non-regulated) with huge heat-sinking and, typically, toroidal transformers.
              In any case, there are high-end examples of each. Take sound-cards for example! Usually, they are class AB at best, and they rely on the PC's PSU which is all Pulse Modulation. Many people consider that to be HiFi. I suppose the term is relative.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Well, HIFI was an standard set by the German DIN 45500. It specified a bandwidth of 20 Hz to 12,5 kHz at nominal RMS power with not more then 1% THD.
                  Today HIFI does mean nothing, as the new standard defined in the EN 61305 does not bother with minimal requirements.
                  So i think most class D amps will certainly comply with the older HIFI requirements, but i think we all know, that those are noting compared with what even a cheap solid state amp could archive.
                  Any sure, most sound cards can archive those minimal specs easily too.
                  • arneson
                    • Sep 2005
                    • 1267
                    Gonzo 0815,
                    I don't meen anything by this except to correct the word you used.
                    To archive means to store away safely, I think you meant to say achieve.
                    Which means to meat a goal or specification.
                    FYI.
                    Jim
                    • i4004
                      • Oct 2006
                      • 2029
                      so logistics, what's wrong with this amp's sound?
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        @ Logistic: I acknowledge I missed your point comparing tube to class D amps instead of solid state to class D ones, but you could have stated your thoughts explicitly: I didn't know the classes you were comparing to.
                        Anyway I don't want to be the devil's advocate: if you have any good reason to warn Willa about the UcD kit, then write it. Previous claims of distortion and design issues (too simple or too complex one?) without any supporting proof aren't good reasons, that's all.
                        In i4004's words, what's wrong with it?
                        Zandrax
                        Have an happy life.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Here is yet another single channel Class D amp.
                          This one is a kit constructed of SMT parts.
                          http://www.ramseyelectronics.com/cgi...ction&key=UAM2
                          • Logistics
                            • Apr 2007
                            • 721
                            I'm sorry, in the popular form I was speaking about, it was easier to achieve good results in a subwoofer amplifier because you didn't have to worry about the distortion as much. Implementation was simpler, unless you wanted to make the amplifier sound more exotic; which is the case with great sounding T-amps. Technically, as you'll read on Wiki, they are not digital, but then, what amplifier is digital? Speakers don't run off digital.
                            They are cheaper and simpler to implement, unless you want really good sound; then Class A is much simpler, but MUCH more expensive if you want to reach the same power levels.
                            There is no way I could know what that amplifier sounds like without actually listening to it. If it's not expensive, give it a whirl. Just don't expect to power anything big with it. You can just look at it and tell that there's no significant amperage running through it.
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              I honestly can say in this digital age no matter how fancy your setup is it all comes down to old fashioned analog speakers.
                              It makes me think that we will eventually hit into a brick wall when we've maxed out what our ears can percieve.
                              What's next do we need digital ear upgrades to get better sound ?
                              • zandrax
                                Hit and miss
                                • Dec 2007
                                • 1157
                                • Italy
                                Right: class D doesn't mean Digital though most amp are wrongly dubbed this way. There are a few manifacturers claiming their amp are fully digital (e.g. Tact audio, Lyngdorf Millennium) but I never got into details.
                                True: only Chuck Norris can judge a book by its cover
                                I wish I was as confident as you.
                                The smallest is 180W at 4 Ohm (say around 90 at 8 ohm), I think the speakers it'd have hard time in driving are low efficiency ones such as some electrostatic speakers. There are 400 and 700W modules if you need beefier amplifiers.
                                Nope: mine are still on warranty so I won't touch them
                                Zandrax
                                Have an happy life.
                                  MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
                                  Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
                                  The nonvolatile...
                                  10-07-2024, 04:55 AM
                                • japlytic
                                  Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
                                  by japlytic
                                  For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
                                  Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
                                  09-06-2023, 08:50 PM
                                • wolf1976
                                  is there any univarsal wifi motherboard that supports and digital tvs ?
                                  by wolf1976
                                  hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
                                  is there ?
                                  do you have to suggest me one ?
                                  thanks on advance...
                                  01-05-2025, 04:29 PM
                                • presario425
                                  RIFA Class Y Capacitor remedy
                                  by presario425
                                  Hi all!
                                  I have a piece of gear with a Power-one SPL130 power supply in it. On the primary side, there is a very tiny (about the size of your thumb nail) RIFA Class Y capacitor, 2.2 nF. I'm not too sure about the condition (whether or not it's cracking) but I do know that it's there.
                                  I'm aggregating information as to how I should remedy this. It hasn't exploded yet, but that's what I'm trying to avoid.
                                  I've never seen a RIFA class Y safety cap self destruct (or at least it hasn't been documented in the past). However, it's not worth the risk to leave it in there....
                                  05-19-2020, 06:53 PM
                                • Bektronics
                                  Schematic Digital Audio mixer RCF type M18
                                  by Bektronics
                                  Hello dear audio friends.
                                  I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                  The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                  I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                  Thanks in advance if anyone can help me with this schematic.
                                  Of course, all information about this digital mixer and possibly references...
                                  07-24-2023, 06:40 AM
