Newbie potentially fried a circuit on AKAI MPK25
  • cart
    • Mar 2016
    • 12
    So I picked up an AKAI MPK25 (a controller for music) and got a great deal because the usb was ripped out of it, but i was able to power it up and figured since I was starting soldering around the same time this would be a great test to repair and profit if I didn't really get into it as I have a number of other hobbies.
    So I ordered some type b usb female connectors to replace the broken one. I used flux because the type b usb has small holes that i was having trouble clearing out, but eventually got through it all and was able to mount (poorly) the usb to the board. In a rush of excitement plugged in the usb cable to the device and to my pc that powers it up without wiping or cleaning off the flux, and it worked for 10 seconds just fine, until it didn't. It still show signs that power is getting to it when plugged in, but it's not operating correctly, as if it it is only receiving a very small or minimal amount to show any activity and my computer does not recognize it. This happens when I use the power cable as well. So, it's worse off than when I started working on it today....
    Basically I want to know if I fried this thing or if I can somehow save this and have one successful project...
    It can be powered via usb or a 9v DC connection. Both of those power inputs show signs of life and I wasn't sure what was going on at first until i heard a sizzling sound and I have yet to plug it in since.
    I am new to all of this and view it as a valuable skill and fun hobby, but today has been nothing but failure on all 3 of my soldering projects sadly. So please help if you can, though I think I fucked this poor guy up...
  • cart
    • Mar 2016
    • 12
    Re: Newbie potentially fried a circuit on AKAI MPK25
    I mistyped when I said I used a 9v DC, I used the correct voltage of a 6v DC. Just so everything is clear.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      It is best to perfect your soldering skills on on working boards that have been scraped.
        • 31025
        clean Q2 and C5 and get better foto's
        • cart
          • Mar 2016
          • 12
          well i suppose i am creating those scraped boards. home grown
          will do.
          thanks
          -cart
          • cart
            • Mar 2016
            • 12
            Photos attached.
            Am I missing a pad?
            Do Q2 and C5 still look damaged?
            Thank you for any assistance.
            -Cart
              • 31025
              the original foto's made them look burned!
              • cart
                • Mar 2016
                • 12
                something was wrong with them, and the solder was crispy. but i scrubbed them down with rubbing alc and they cleaned up nicely enough and the ICs seem undamaged. so that's good.
                question: That stuffed that looked burned was what was "sizzling" when i powered it on using either the usb or the 6v DC connection. should i attempt to power it on with the 6v DC connection to test that this can power on normally even if not by using the USB which was obviously my intent of this project? doesn't seem like i can do any further damage using the DC right now.
                q2: how do i deal with that missing pad so that i can do the original repair of adding a working usb connector?
                thank you for any assistance
                -Cart
                • cart
                  • Mar 2016
                  • 12
                  The USB and DC power it up just fine and the usb won't be moving around anytime soon. Powered on via USB all night with various settings that would inform me if it shut down at all and it went just fine. It is fixed for all intensive purposes, and learned a lot along the way and still have a lot to learn ahead of me. The missing pad is a mounting pad and it is in their pretty firmly.
                  Wish I started this hobby/skill years ago.
                  These skills will certainly pay for themselves even if I just repair my own gear. One fixed laptop or DC connection and I've saved myself at minimum a $100 repair bill.
                  Great skills to have during this day and age.
                  Thanks again.
                  • Alimash
                    op amp circuit function?
                    by Alimash
                    I am repairing a ups which doesn't turn on ,it has the following ICs:
                    SG3525 used to drive inverter mosfets.
                    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                    A LM358 and TL074 for control mechanism and of course the uController.
                    The SG3525 is shutting down every time the ups is turned on.
                    I want your help to know the function of LM358 and TL074 in the system.
                    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                    07-31-2025, 07:45 AM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
                  • rddube
                    Lenovo L490 Ram voltage circuit malfunction
                    by rddube
                    Hello friends,
                    Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                    I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                    07-15-2025, 04:41 PM
                  • Tarot Superstars
                    Short Circuit tester
                    by Tarot Superstars
                    Hello.
                    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                    Link
                    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                    https://www.youtube.com/watch?v=0eixDdCpiO4
                    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                    09-25-2023, 09:11 AM
                  • M1NEBLANK SHOW
                    MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                    by M1NEBLANK SHOW
                    Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                    (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                    Schematic and Boardview here
                    04-04-2025, 03:57 PM
