Samsung soundbar (HT-WS1) goes into standby mode almost immediately
  • justwanttowatch
    • Jul 2013
    • 5
    I have a Samsung soundbar (HT-WS1G/XEF) here that goes into standby mode almost immediately after turning it on. I've only ever had it work once which was when I first obtained it and I tested both the Toslink and the analog input which seemed to work fine at the time.
    Opened it up by removing 12 screws, checked out the components with my limited understanding (tested some of the diodes and mosfets I could get to, checked the caps and looked for other obvious signs of damage) but I haven't the foggiest as to why it goes back into standby mode almost immediately.
    Any clues or hints about where to look next?
    • 31015
    Re: Samsung soundbar (HT-WS1) goes into standby mode almost immediately
    3 caps in the psu look like the tops are starting to dome.
    2 on the left, one small one top-right above the mains caps
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      As STJ says , they look suspicious.
      Replace them all and see how the soundbar reacts to it. It worked for my philips htc...which needed a lot more caps to be replaced!!!
      • justwanttowatch
        • Jul 2013
        • 5
        Thanks, will do so and get back to you!
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • Crystaleyes
          Samsung BN44-00259A standby question
          by Crystaleyes
          Hi all.
          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
          08-11-2023, 05:15 AM
        • psssst
          Yamaha TSX 120 Standby Problem
          by psssst
          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
          03-01-2024, 07:25 AM
        • reessi
          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
          by reessi
          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
          Years ago it had some bulging caps...
          04-26-2021, 11:42 AM
