Advise on tape deck
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Advise on tape deck
    I'm working on the cassette deck I bought in 1985. A Sansui DW-10, the belts finally started slipping so I had to open it up. Here's the service manual http://www.hifiengine.com/manual_lib...ui/d-w10.shtml . While I was changing belts I thought about how old the caps were and decided to replace them.
    I'm on the record/play amp now. Specifically around IC4, the volume control chip for playback/rec and double speed dubbing. If you look at the CR input, pin 12, you'll see it goes back to the collector of Q2, and Q3. Through C4 and C5, which look like DC blocking caps. I looked at the spec sheet for the chip and it looks like it takes 11 volts max although it was in Japanese. The question is the two caps are 100 volt Elna's, I have 50 volt in hand. I think they'll work just fine. Does anyone think I should order 100 volt? I know 50 is as small as you can get those values today and I'm thinking 100 was the smallest available in 1984. Does that sound right?
    Thanks for your time.
    sigpicThe Sky Is Falling
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Advise on tape deck
    I would measure the input voltage to those caps(last trace before caps) and if it's somewhere close to 100VDC, get 100VDC caps. 50V caps would grenade on 100VDC.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      Thank you for the reply, but it's in pieces right now. It took me two days to tear it down and would take the same to put it back together. It's a very complicated deck. The main board I'm working on has about thirty ribbon cables and probably 300 wires total. It's hard to get to some of the caps because of all of the cables.
        • 31305
        before you chew any tapes - check the pinch rollers.
        those cause far more problems than the belts.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Service manual only available to registered users from that site. Post it if you have it downloaded.
          Shelf life on some rubber-like products is no where near 31 years and since no one knows what the belts and rollers are made of it might be a good idea to replace them all if you can.
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            Good advice, the pinch rollers are still good. The belts are shot. It has one flat belt for each well, gears for the rest. That's why it lasted so long. I've got the new belts on the mechs, I just need to know if someone sees something I don't in the schematic. I don't see how the transistor could have anywhere near 100 volts either AC or DC. I think that was the lowest voltage available for an electrolytic in a .22uF in 1984. I've seen it before in other gear but that was made in the seventies. It was also a low noise cap. I used a 50v in that one and it was fine. I'm not sure if 50v were available in the eighties. It's an Elna 0.22 uF 100volt RE series I think. The other is a 0.33uF 100volt Elna. I've got 50v KL Nichicons I can use there. Just wondering if anyone sees a problem if I do it.
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              here's the manual maybe, ahh, looks like it went through.
                • 31305
                .22 is obsolete, even .47 is hard to get decent brands and 50v is minimum.
                i'd use a polyester or ceramic myself.
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  I looked at Elna's offerings now, they have a RE3 line which is general purpose. I don't know if they're the same as the old RE series. They only go down to 1uF at 50 volts. I got some Nichicon KL series last year at .22 and .33 50 volt. I was planning on using them, but they also have the same at 100 volt. I would have to order them though or any other kind. It would save me money to use what I have since it costs about $10 shipping for 2 day delivery from Mouser.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Schematic label says IC4 as LA-7530 but it's not, it's LC-7530 and that threw me for a loop (at least the parts list has it right). I can't see anything in that part of the circuit that would be above B+ which is 12.8v but it doesn't help that the spec sheet for that chip is in Japanese (as you said). I bet 50v caps would be fine.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      Yeah, that got me too. I didn't see any reason not to use it but wanted a second, or more, set of eyes on it. Appreciate all the replies, I'll carry on with the 50 volt KL's I have here.
                      Sansui schematics are notorious for being different. So many revisions and none documented.
                      • pecman
                        Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
                        by pecman
                        I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
                        08-05-2025, 10:10 AM
                      • RetroComputingGrotto
                        IBM LTO 7 Tape Drive - Dust Sensors??
                        by RetroComputingGrotto
                        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                        09-19-2024, 01:54 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • Dannyx
                        Harman Kardon TD202 Tape Deck SLOW boot-up
                        by Dannyx
                        Good day folks. Today I got something which I haven't worked on very often because they're falling out of fashion: a tape deck - sounds lame, but it's a challenge I'm willing to accept.
                        It's a rather basic one: no auto-reverse, though it's got Dolby on it, so I guess it's decent and worth saving.
                        There are 2 issues with it:
                        A) it takes its sweet time to finally output any sound after being powered on, despite the transport running and the LEDs coming on fine
                        B) the left channel is dead
                        A) I had a look at the schematic on page 49,...
                        02-28-2022, 12:06 PM
                      • triplefour
                        LG 75UN8570AUD panel issue fixed with tape.
                        by triplefour
                        I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                        add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                        07-17-2023, 10:22 PM
