Yamaha RX-V*7* series protection circuits
  • videobruce
    • Aug 2014
    • 16
    • US
    Yamaha RX-V series (specifically the 675) won't power up.
    This isn't a bad caps problem, but appears to be their overly aggressive protection circuit problem.
    I got it uses, initially it did power up. Going through testing all the inputs and outputs (except for the surround speaker outputs) all was fine.
    After a few hours, I came back to familiarize myself with the on screen menu, but it didn't respond to the front panel button. I unplugged and re-plugged it and it did power up.
    The next day no power At all, removing the power cord and re-applying it made no difference. I did hear the relay(s) click a couple of times, but tht was it.
    I checked the standby board fuse which was good. I did check the input lead to the main xformer and it was not open (in case it had a thermal fuse). I tried the 'Info-Tone Control-Main Zone' button trio protection bypass per the SM, but still nothing.
    The volume was at mute (turned all the way down). I only had a pair of bookshelf speakers connected to the front outs (and no, the cables were not shorted). I only ran at low levels just to confirm audio output.
    Nothing obvious inside other than a 'musty' smell like one smells from 30 year old equipment. This is only three years old or less and it was 'refurbished' which means someone else had a problem, not doubt this.
    Any ideas with their protection circuit assuming that is the probelm area?
  • Longbow
    • Jun 2011
    • 623
    Re: Yamaha RX-V*7* series protection circuits
    But what about your standby 5v?
    But what about your secondary voltages on the supply?
    That would be getting ahead of yourself, since you don't have a stable turn-on.
    Is it plugged in?
    • honda191
      • Nov 2016
      • 12
      I have exactly the same amp and issue! Read somewhere about a Thermal Fuse in the power supply but the model in the U tube video I reviewed is different they have a grey and blue wires my amp has a blue and white wire that comes from the input board to the power supply to a small board on the power supply. My question is how to bypass the original thermal fuse and install the new replacement???
        The question is, is the Thermal fuse open circuit? It is wrapped under the insulation tape on the Primary winding of the transformer. So did you check resistance of the primary winding of that main power transformer?
        Did you verify that you do have MAIN AC between the White and Blue wires soldered to the PCB on the transformer?
        • honda191
          • Nov 2016
          • 12
          I did not check power I will tonight but I did check resistance and there was none between the white and blue wire at the board.
            If it shows open circuit then you do have open primary circuit, so the thermal fuse may have blown open circuit dues to fault in the transformer. You need to remove the transformer to the fuse under the wrapping.
            • honda191
              • Nov 2016
              • 12
              The small board that had the blue and white wires connected to the power supply had a bad trace. Removed the board wired directly to the leads to the supply and now I can get the amp to power up in sleep mode. I disconnected all speaker wires and tried to power up normally but shuts down.
              • honda191
                • Nov 2016
                • 12
                Here is a picture of input connections on the Power Supply hoping you can see the 2 small silver wires connecting to the main is solder junction is this the connection of the Thermal Fuse?? I checked resistance and it is open. I need a little help on where to cut and re solder in the new one.
                  Can I see the whole transformer top side?
                  They usually have the thermal fuse on the primary, your pictures look like the secondary side?
                  But I though you fixed the connection on the primary side and able to get the resistance reading on the primary winding.
                  BTW, what is the full model number?
                  • honda191
                    • Nov 2016
                    • 12
                    Model RXV765 I did run the protection diagnostics actually 3 times each time resetting the code it reads dc016L
                      Do you have the service manual?
                      • honda191
                        • Nov 2016
                        • 12
                        Yes all printed out
                          So what does it say in the service manual for the error code dc016L?
                          • honda191
                            • Nov 2016
                            • 12
                            Dc current low
                            • honda191
                              • Nov 2016
                              • 12
                              016 = A/D value when the protection function is activated reference voltage 3.3 v
                              L= when the lower limit of the protection function is exceeded.
                              • honda191
                                • Nov 2016
                                • 12
                                Any help on where to look for the source of issue with the DC over voltage???
                                  I looked at the service manual that I sow on the link, where do you see the error codes listing?
                                  • honda191
                                    • Nov 2016
                                    • 12
                                    Page 62 is where I got the above description.
                                    BTW, I had the amp in sleep protection mode last night and got distracted for an hour or so came back to my bench and it was totally powered off and now I can not get any response other than the initial click no there relays function display does not light up. Tested Ac in to power supply (Blue and white Wires) and no voltage. Should I just order a new main board if so how do you go about ordering it from Yamaha?
                                    • honda191
                                      • Nov 2016
                                      • 12
                                      Page 108 in the manual is the board for power in can't seem to find the part number for the whole board assembly? I think it is WR433800 but not 100% sure
                                      • madan1
                                        • Nov 2016
                                        • 682
                                        • Bulgaria
                                        can you post some images of the unit and the individual PCBs?
                                        the dc power regulators usually look like transistors and are mounted on radiators or the chasis. They have 3 legs ( input ground output , order differs ). Near them you will find e-caps. On the pcb it should be undicated for whuch dc line is the regulator ( +/- 12, 8, 7, 5, etc V ).
                                          ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ASUS Pro Series D320MT-I56400058C Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I56400058C can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I56400058C boardview and Pro Series D320MT-I56400058C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:30 PM
                                          ASUS Pro Series D320MT-I56400105C Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I56400105C can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I56400105C boardview and Pro Series D320MT-I56400105C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ASUS Pro Series D320SF Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320SF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF boardview and Pro Series D320SF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
