Need Help with this Circuit Please
  • tfs2015
    • Feb 2015
    • 135
    Dear Forum members,
    I hope that you can help me out with this amp circuit, I cannot get it to work correctly even on +- 12 vdc supply. I end up with 10vdc between the speaker output and ground.
    Tom
    Computer and Small electronics troubleshooting and repair
    • 31154
    Re: Need Help with this Circuit Please
    i'm not surprised, it has no bias ajustment or anything.
    it looks like a classroom example of what not to try to build!
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Might i suggest taking a look at some of Rod Elliott's projects? As a starting point, i'd like to point you towards his Project 3A - http://sound.westhost.com/project3a.htm
      He has strived to make his designs as simple and forgiving (if not even bulletproof), using mostly "jellybean" parts, so they should make a decent starting point
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • SteveNielsen
        Retired Tech
        • 2327
        Originally posted by tfs2015
        Dear Forum members,
        Tom
        It's no wonder, there is no output DC decoupling. At least put a cap in series with the speaker before you burn out the voice coil.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          At least in theory, it shouldn't need any, since at least on the schematic, it has +/-45v supplies, so...
          • SteveNielsen
            Retired Tech
            • 2327
            Yes, if the circuit was really balanced but it doesn't look like it at a glance and the circuit is not drawn very well. It's not possible to tell how the transistors are biased without knowing what they are. One could look them up and redraw the diagram but I'm not gonna do it.
              +1, great site for learning also.
                Dear Forum members,
                Tom
                Link to the site where you get this diagram from?
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Here are a couple I found:
                  http://circuitdiagram.net/150w-power-amplifier.html
                  http://www.circuitdiagramworld.com/a...ram_16729.html
                    The reason I want the link is to fiond out how many people or if the Author actually build the circuit.
                    I see the power supply circuit (http://circuitdiagram.net/150w-power-amplifier.html) suggested to use 35V-0-35V and the filter caps are rated at 50VDC (4500uF 50V), @35V, the DCV on the cap will be about 49VDC if the line Voltage stays still.
                    I found this:
                    http://pcb.jspayne.com/150wattamp.html
                    I would also implement speaker protection relay.
                    I.E. http://sound.westhost.com/project33.htm
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      The alternate schem is easier to read:
                      • tfs2015
                        • Feb 2015
                        • 135
                        I got the schematic from http://electronics-diy.com/electroni...tic.php?id=477
                        I simulated it MultSim and found out that with +- 12vdc power I would get about 10vdc on the + speaker output to ground. If I raised the supply voltage to +- 45vdv the vdc would drop to 950 mv which should not burn out the speaker. When I ordered the components I forgot about the TIP 141 and ended up using a TIP 142 in its place. According to the specs it has 100 watt handling capability where as the TIP 141 has 80 watt. I have a couple of 1200 uF 63v caps laying around, can I use one of those as a decoupling cap on the speaker output? I don't have a lot of money to spend on this project right now so I am hoping I can use what I have on hand.
                          • 31154
                          you will need a lot of aluminium - and probably a fan.
                          that is going to get real hot.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            1200uF is a bit much at 8 ohms, that puts the resonant freq center at below 20Hz. Around 20uF at 8 ohms would center close to 1KHz.
                            http://www.calculatoredge.com/enggca...apacitance.htm
                            • tfs2015
                              • Feb 2015
                              • 135
                              Which is going to get hot, the cap or the transistors? I have a heat sink to mount them on.
                              I need to clarify something: I am trying to rebuild the power amp on my Fender PD250 PA system since the original board is not able to be repaired.
                              The SMPS outputs +/- 52 vdc for powering the amplifier section. I need a circuit that has low component count, can use most of what I have on hand and is cheap and easy to build. The SMPS is already mounted to a very big heat sink and the power amp board also mounts to this heat sink as well. The orginal board had a lot of transistors and diodes on it plus trimmer pots for setting all of the volategs and currents correctly. I want to get away from that so I can just plug the circuit in and go.
                              Any help or recommendations would be greatly apprecaited.
                              Tom
                                • 31154
                                the transistors will generate heat, your psu will need to be pretty capable too.
                                • SteveNielsen
                                  Retired Tech
                                  • 2327
                                  I don't think you're going to have a good time of it going that route. Please explain why the original board cannot be repaired. It might be the best and easiest solution and there are people here willing to help with that. I found a svc manual for the unit.
                                    • 31154
                                    the chinese probably sell a pre-built pcb for peanuts.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      Here is a link to a course on understanding amplifiers. http://www.learnabout-electronics.or...plifiers50.php
                                      It even has tests to verify your understanding.
                                      • tfs2015
                                        • Feb 2015
                                        • 135
                                        The circuit board traces are badly damaged due to repeated repairs to the board. I called Fender about obtaining a replacement board. They told me that the board is no longer available and that the new systems they make use a digital technology instead of analog. Therefore I am kind of stuck on what to do that is why I reached out for some help. Any help and recommendations would be helpful.
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • SluggerB
                                          Help with trying to fix phone that is not charging (Pics inside)
                                          by SluggerB
                                          I have two TCL A30 phones.
                                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                          08-12-2024, 08:11 AM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
