Help for mixing console BEHRINGER UB2442FX-pro
  • Jose Manuel Borges
    • Apr 2015
    • Portugal
    Friends i have a BEHRINGER mixing console EURORACK UB2442FX-PRO, which is a number of problems, I have no great esperiência in the repair of such devices,
    1º only has signal input on channel 1 and channel 4, the other gives nothing.
    2º in the signal input to the tape, just enter signal on the right channel.
    3º only has signal output on the right.
    I would appreciate someone can help me on this repair.
  • midibob
    • Nov 2008
    • 285
    Re: Help for mixing console BEHRINGER UB2442FX-pro
    I've just been repairing a similar model to this.
    You will probably find the amplifier chips on the input board have failed and this could be due to the PSU having bad caps!
    These chips are all SMD so if you have no experience I wouldn't even think about having a go at it.
    Firstly though, before you get any chips changed make sure the PSU is checked out as it's more than likely that several of the caps have vented and lost their capacitance.
    Midibob
    • diydidi
      • Sep 2012
      • 17
      • South Africa
      Clean ALL switches (push buttons) for starters. Most of the dead channels will come back to life. You'll have to do this anyway. Then you can check the rest of the mixer like the sliders, opamps etc.
      • bman1958
        • Surinam
        Good day Members
        I do have a similar problem.
        only when i press on the bottons in the middle of the panel
        I get good sound for a minute or so
        anybody knows what this is all about ?
        • madan1
          • Nov 2016
          • 682
          bad solder joints?
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • HelpMeRepair
            Yamaha RX-A3010 left channel no signal
            by HelpMeRepair
            Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
            what I did so far ,
            factory reset
            test all other channel
            tone test
            dissasemble and look , visual inspection witout full dissasembly
            looked at all the mosfet for temperature to see if they eas operating
            scratch my head couple of time
            thanks in advance all help is appreciated , service manual are welcome too ! =)...
            11-14-2024, 02:48 PM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
          • afminguela
            No signal right output master channel - TRAKTOR KONTROL S4 MK1
            by afminguela
            HI,
            i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
            One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
            i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
            and I concluded that is a hardware issue.
            As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
            Does...
            05-11-2023, 05:58 AM
