I am quite new to electronic device repair and I would need some help to understand and troubleshoot my Yamaha RX-V457.
Symptoms: Unit powers on, then powers off after a few seconds
Autodiag says (10. AD DATA CHECK) PS:016 (should be between 18 and 33, from service manual)
Measured voltage of PRV is 0.77 V, which roughly correlates to 5V x 16 %.
Before measuring this, I had replaced C405 & R419 on SUBTRANS as when I 1st measured C405 value, it was half the nominal one and R419 was a bit dark (even if value was OK). It did not change anything.
Subtrans measured voltages are :
When power-on
- S10 = 10 V
- PRY = 4.7 V
- E = 0V
- PDET = 4.9V
- +5M = 5 V
- /RES = 4.7 V
When powered-off :
- S10 = 10 V
- PRY = 0 V
- E = 0V
- PDET = 4.9V
- +5M = 5 V
- /RES = 4.9 V
I am thinking the root cause of my issue is more on the main board (voltage divider ? shorted capa to ground ?) but I am not very experienced and I could be totally wrong.
I have also measured this on MAIN if interesting (as it can be related to PRV voltage if I am not wrong ?) :
When power-on
- +B = 56 V
- -B = -56 V
- E = 0V
When powered-off :
- +B = 32 V (?)
- -B = 0 V (not sure why ?)
- E = 0V
What should I measure next (before removing Main board if possible) or what would be the next relevant steps ?
Thank you !
Alex.
When power-on
- S10 = 10 V
- PRY = 4.7 V
- E = 0V
- PDET = 4.9V
- +5M = 5 V
- /RES = 4.7 V
When powered-off :
- S10 = 10 V
- PRY = 0 V
- E = 0V
- PDET = 4.9V
- +5M = 5 V
- /RES = 4.9 V
When power-on
- +B = 56 V
- -B = -56 V
- E = 0V
When powered-off :
- +B = 32 V (?)
- E = 0V
Thank you !
Alex.
