This has a blinking red power light, when I push the Enter and Advanced surround for 3 seconds it will come on but then go to Amp Error and shut off so I tried pushing the Enter and Advanced Surround again but this time I hit the power button to shut it off before it went to Amp Error and the red power light would stay lit. Then I powered it on and held the Tone and Power buttons till it said reset then I hit Tone again then it said Confirm So I hit Tone again and it would Reset for a second or 2 then say Amp Error. I've read someone else had this problem and it was the transistors at Q696 and Q697. These are C1740's with R S P under that. From what I can tell these are obsolete so my Question is what are comparable transistors to replace these with? Any help would be greatly appreciated.
Pioneer VSX-D812
Tags: None
Re: Pioneer VSX-D812
Had to resurrect this, because I had the same amp with the same problem. The other thread is here:
https://www.badcaps.net/forum/showthread.php?t=42588Last edited by CapLeaker; 05-15-2015, 06:47 PM.Comment
by DobsukHi all. I have Pioneer PL-Z460 turntable but have some issue with the tone arm.
When the record finishes or stop it manually the arm does not go back all the way to the rest. It stops just short and then decends down onto the base. Is there an adjustment to make the arm go back a futher 0.5 cm?
There is only one screw at the base of the arm but it is for height adjustment:
Any advise please?...-
by CDNBrewerHello Everyone,
I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
Symptoms:- Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
- Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
- I swapped the Left and Right surround
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
by eltano4i201) Error trying to enter the BIOS
--> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
BOOT PRIORITY ORDER (img-05)
1- Windows Boot Manager
2- SATA HDD
3- NETWORK
4- Debian
2) Error trying to access the BOOT MENU
--> I restarted the notebook and pressed [F10] but the BOOT... -
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
- Loading...
