Harman Kardon AVR360 repair attempt. Burned HDMI pcb and other issue.
  • mrugi
    • Oct 2025
    • 17
    • Poland
    A friend gave me a Harman Kardon AVR 360 receiver to see if I could repair it.
    When plugged into a power source, it would turn on by itself after a short while and display only squares on the screen. I opened it up and found a large, burnt-out hole on the HDMI board (COP12179C / CUP12179Z), located underneath some foam. I cleaned away the charred material, and the short circuit is now gone; the resistance has risen into the mega-ohm range. As a result, fuses F110 and F111—located on the +15V and -15V lines on the transformer PCB (CUP12172-1) were blown. I replaced them, and power was restored to the HDMI board and the display no longer shows squares, now it is blank. Device still turn on by itself after a short while.
    On this HDMI PCB, there is an inductor (L826) and a voltage regulator (IC121) for +3.3VDD (measured at 3.4V). There is also another inductor (L827) with a regulator (IC122) for +1.8VDD (measured at 1.85V), as well as an inductor (L868) and a regulator (IC130) for 8V (measured at 8V). Additionally, there are IC128 (providing 5V and 3.3V) and IC129 (providing 5V and 1.8V). I checked various components for short circuits, and everything seems fine. Visually, there is no other damage, aside from the hole caused by the short—which I haven't patched yet with solder mask. I don't see any signs of other traces, such as signal lines, running through the area where the hole is. It’s difficult to take further measurements because the components are located on the underside of the board.
    Now for the best part: located beneath the HDMI board is an iPod pcb (COP12169F / 12169). If I remove only the HDMI board and power on the unit, nothing changes. The AV receiver turns itself on after a short while (indicated by a white LED), becomes unresponsive to any buttons, and the display remains blank.
    If I remove the iPod board and power on the unit, the receiver no longer turns on by itself and responds to the power button. Text appears on the display, and I am able to adjust the volume. I also performed a "reset" by holding down the 'OK' button while the unit was in standby (amber LED). The device reset successfully, confirming this with the word "reset" on the display. This suggests that the main processor is likely functioning, at least to some extent.
    There are no visible signs of a short circuit on the iPod board; it even looks fine under a microscope. I’m not entirely sure what I should be measuring on it, or why its presence causes the receiver to turn on automatically, become unresponsive to buttons, and show a blank display. There are two components (amplifiers?) on the board, IC216 and IC217, with supply voltages of 15.03V and -14.74V, respectively. The 5V STB and 3.3V STB supply voltages for IC207 are also present.
    There is no DC voltage at the speaker outputs - only about 0.006V.
    It is possible that the short circuit on the HDMI PCB caused further damage, or perhaps the short on the HDMI board is unrelated to the original issue... From what I’ve gathered, the device remained in a damaged state for a very long time. The owner might have tried to power it on while it was already faulty; the foam on hdmi pcb had absorbed moisture(from air?), which then triggered a short circuit on the 15V line. I’ve seen reports online about these models and the issue with short circuits occurring beneath that foam. My unit does not have any signs of water damage.
    There is a transistor on the front panel PCB that heats up to 80 degrees Celsius—is this normal? Based on my research, such a temperature is actually within the expected range for this component.
    Unit is like 10 years old and i don't want to recap yet because it’s not particularly cost-effective. Caps are old and maybe they can cause an issue?
    I will stop the description of the problem here, as it is already quite long. Please feel free to ask for further details or suggest what I should measure or check if you have any ideas.
    Service manual in attachment.
  • mrugi
    • Oct 2025
    • 17
    • Poland
    I re-checked all the power rails and found a 4-ohm short circuit on the 5V line that powers IC41. I injected voltage and discovered that IC41 heats up. It is a Cirrus Logic CS42528-CQ chip, which is powered by the 5V regulator IC82 located on PCB 12172-4. I need to desolder it and check the remaining components to see if the short circuit persists elsewhere. I’m not sure if I checked this power line earlier, but somehow it escaped my notice.
    Do you think it may work without it? Maybe remove it and check if other functions of device can work without it? Just to check if it makes sense to invest in this equipment.
    • madan1
      • Nov 2016
      • 775
      If I remember correctly Cirrus Logic CS42528 is ADC/DAC. Probably communicates with a DSP ic, but my guess is that the unit should at least show an error message. In any case, a missing ADC/DAC should not prevent the main cpu to boot.
      • PowellSkier
        Harman/Kardon AVR 645 returning to stand-by after a few seconds.
        by PowellSkier
        A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
        06-17-2024, 11:43 AM
      • Tomylee
        Harman Kardon making noise
        by Tomylee
        Hello, I have a Harman Kardon SB 30 CNTR soundbar that started making a squealing/grinding noise after some time of use. When I opened it, I found a bulging and leaking capacitor , which I replaced. Since then, the noise is now constant.
        I also noticed a resistor that is overheating, but I can’t identify the root cause of the problem.
        Could someone help point me in the right direction for troubleshooting?
        Here is the service manual I found:
        https://fr.scribd.com/document/88984...Service-Manual
        Thanks in advance 🙏...
        02-02-2026, 01:32 PM
      • ryancog
        Lenovo Legion 5 Pro 16ARH7H Short On "5V Always-On" Rail
        by ryancog
        Hello there,
        I've got a Lenovo Legion 5 Pro 16ARH7H (AMD Ryzen 7 6800H, NVIDIA RTX 3070Ti) that seems to have "developed" a short on the 5V "Always-On" rail.
        Background
        I don't have too much in the way of useful information here, I don't think. This laptop has been used for the past few years without any notable issues/incidents. The laptop is often "docked" w/ the AC adapter (Lenovo's rectangle one) connected. A few days ago, I finished up working on things in the evening, and the next morning I found the laptop off w/o any...
        04-20-2026, 10:50 PM
      • salim1gr
        HARMAN KARDON ONYX STUDIO 4 SPEAKER MAIN BOARD REPLACEMENT PARTS 40-0ONYX-MAF2G
        by salim1gr
        Hi need schematic HARMAN KARDON ONYX STUDIO 4 SPEAKER MAIN BOARD REPLACEMENT PARTS 40-0ONYX-MAF2G please if someboady have it...
        07-22-2026, 07:32 AM
      • Leefreeman97
        Diagnosing short to ground issue. pcb from an e scooter
        by Leefreeman97
        Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
        09-19-2025, 03:33 PM
