Yamaha TSR-5790 or RX-V579 no sound no firmware version
  • martincito
    • Sep 2026
    • Argentina
    Hi everyone, I'm struggling with a Yamaha receiver model TSR-5790, after a failed firmware update, no sound at all, not only digital but also pure direct with no audio output.
    Replaced DSP IC (IC41), just in case, but not solved the issue.
    Apparently, the flash memory related to DSP IC is corrupted (IC42), an 8mb flash.
    C1-6 says DSP BUS: NG
    System version says ----
    Does anyone has a dump file for it?
    Any experience dealing with this issue?
    Thanks for your time.
  • martincito
    • Sep 2026
    • Argentina
    This is the flash IC
    • Boardview and Schematic Bot
      How To Check BIOS / EC firmware version for MSI notebook & Update it
      Not sure how up to date this is....
      How To Check BIOS/EC firmware version for MSI notebook?
      Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
      1. How to check BIOS/EC version by Help Desk?
      1.1. Open MSI Help Desk.
      Note: Help Desk is a built-in application for MSI notebooks. If you couldn’t find this software in your Windows system, please download and install MSI Help Desk from product.
      1.2. Click the [System Info].
      1.3. BIOS and EC firmware version will display on screen.
      03-27-2026, 01:12 PM
    • Armaan Anuf
      specific firmware version: MS648ME firmware or V8-MS648ME.
      by Armaan Anuf
      08-12-2026, 09:48 AM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • jjne
      Yamaha RX V675 sound issues
      by jjne
      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
      At first I thought it was either a speaker relay or the DSP, but I don't think...
      06-24-2025, 07:01 AM
    • braveheartleo
      Need fix for BIOS upgrade ALWAYS failing on Thinkpad X12 Detachable Gen 1 (Wistron 19835-1) with an unusual version
      by braveheartleo
      Good day.
      I'm seeking information, advice, or fix for a BIOS upgrade that is always failing on a Thinkpad X12 Detachable Gen 1 (Wistron 19835-1). The failure is indicated as "An unexpected error has occurred, and the process did not complete." as shown in (1) whenever I try upgrading the BIOS via the provided official BIOS bootable CD or BIOS Utility (Windows) update releases, practically EVERY version released for this unit as can be downloaded in (2). I acquired the unit as second hand, and the sticker labels like the CPU/Manufacturer logos and even the factory labels...
      07-06-2026, 04:52 AM
