Onkyo TX-RN515 schematic
    • 30985
    Re: Onkyo TX-RN515 schematic
    coils fail, usually where they solder to the terminal.
    • artois7
      • Mar 2011
      • 159
      The TX-NR414s and 515s suffer horrifically with O/C coils. I must've done 50-100 414s with a dead relay. It's not limited to these models either - seen it across the range.
      Must have been a bad production run.
      • Chungalin
        • Jul 2014
        • 422
        • Spain
        Darn, why didn’t I search this thread before messing for hours with an Onkyo TX-NR414 that wasn’t powering on, with irregular clicking relay???
        It’s been the relay RL9001 too! A Tyco Electronics SDT-S-109LMR2 (9VDC coil). It wasn’t open, because it clicked, but wouldn’t stay on. Very intermitent. I’ve opened the relay and I haven’t seen anything suspicious. I’ve replaced it with a scrapped Massuse ME-7-009-HL.
        I’ve fixed many relays with bad contacts, but this is the first time I see a coil failure like this.
        • KeyResults
          Roland SPA-120 Amplifier Tech Notes / SM / Schematic Source?
          by KeyResults
          Repairing a Roland SPA-120 amplifier, a solid-state early-mid 80's part of the Roland Rack. The PCB is Labled AP-124B. Was thinking lytics would resolve the nasty output on scope but all tested 100% for values, ESR, and leakage (very surprised!). Symptom is nasty wave form on both channels in Stereo mode, but clean in single channel mono (BTL) mode. The Output transistors test ok at room temp, but still could be faulty once heated up. Anyway, a schematic and some test point voltages would sure save some time. Thx!
          11-09-2024, 03:21 PM
        • Billcliffens
          JTC B-28 Cardmp3 player amplifier Schematic
          by Billcliffens
          I'm trying to troubleshoot a JTC B-28 Cardmp3player amplifier which had a power supply failure. I've replaced the damaged str transistor with a 3wire power module and now it's powering up fine but it has very low and poor quality audio output.
          A schematic of this 12vDC/220vAC Power amplifier will be of great help.
          11-25-2023, 09:10 PM
        • Tom_x
          Onkyo grand integra schematic!
          by Tom_x
          Hi friends!
          I'm looking for schematic diagram for Onkyo grand integra A-G10 (A-8890)
          speaker relays not activated, maybe protection circuit blocking.
          If i power on for a minute, and power off and on again, speaker relays activated and unit working.
          thx
          Tom
          12-02-2023, 01:30 PM
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • atunguyd
          Acer x163w Monitor PSU schematic
          by atunguyd
          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
          03-05-2025, 02:08 PM
