Hi, I'm trying this sound bar. The bar works. the bar and subwoofer have independent power supplies and connect via 5Ghz wifi (Everestek EV01SA Rx module). If the subwoofer is unplugged overnight, it works for a couple minutes then stops. The power supply is good. The 12V and 3.3V are present. The STANDBY is not present. The schematic is a bit confusing to me. Seems like the STANDBY is created by the EN of U4 (WS4603E Power distribution switch). Also, the STANDBY seems to be providing the gate signal to Q7 (WPM3407 P-channel mosfet) but +12V and A_12V are present. I disconnected R133 and R25 to test for the STANDBY power source but it's not present on either side of those resistors. I'm thinking that the schematic has an error but I'm not too good at understanding these circuits yet. I provided the service manual and some images of the STANDBY power on the schematic. I would really like some assistance with troubleshooting this, TIA.
JBL Bar 2.1 Deep Bass subwoofer works for short time
Tags: None
A small update, since it powers on after being unplugged for some time, I checked and the STANDBY is not present until after the "pair/ power button" is pressed. When it stops working the 3.3V line fluctuates between 0.9-1.2V. I will try replacing the U1 (SY8120B1) and the surrounding capacitors to see if that helps
by Xan03Hi,
I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?-
11-17-2024, 06:54 AM -
I’m looking for help diagnosing a no-power issue on an ASUS ROG Zephyrus G14 (GA402R / GA402RK series). ❗ Problem
The laptop does not power on at all:- No LEDs
- No fan spin
- No response to power button
The issue started right after a RAM upgrade. The previous owner mentioned there may have been static discharge during reassembly.
🔍 What I have checked so far (with a multimeter)- AC adapter is confirmed working
- 19–20V is present at the DC jack
- Both input MOSFETs have 19–20V on both sides
- Multiple inductors near the eDP connector
8 Photos -
by BenassI am troubleshooting an AVT150 amplifier. The standby pin is at 0 V, so the amp remains muted.
I have the schematics attached.
Key observation:- The standby pin is 0 V (muted condition).
- If I remove T104, the standby voltage is restored.
- With T104 removed, I have 4.7v on standby pin and TDA can see signal generated.
This suggests T104 (or its surrounding circuitry) is pulling the standby line low, but I am not yet certain whether this is due to a faulty transistor, a control signal upstream, or a protection condition being asserted.
Has anyone...-
by _AcE_I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
There's no physical damage... -
by Fabián MorinHello everyone,
I'm working on a Huawei MateBook D16 and I'm stuck with a persistent issue. I hope someone here can help.
The problems:- Touchpad: Works perfectly in the BIOS (cursor moves), but it's completely dead once Windows starts. It doesn't appear in Device Manager.
- Display: The Intel UHD Graphics driver causes a black screen when booting Windows normally. However, in Safe Mode, the Intel driver works flawlessly and the display is stable. If I uninstall the Intel driver and use the generic Microsoft Basic Display Adapter, the screen works, but the touchpad remains
- Loading...
