Yamaha HTR 3067 DC PRT 000L
  • hemant_2222
    Hemant
    • Jul 2015
    • 78
    • India
    • High End audio repairs
    Hello Friends,
    Greetings and Good day!
    It has been a long time that I had taken any AVR for repairs but then I got this old Yamaha HTR-3067 which was totally dead and I would appreciate if someone can look at the description and possibly assist.
    While I continued looking, there were few issues with its reset and mute circuits, which after they got cleared it worked for some time but then it stopped working, no sound. The error in the diagnostic mode shows DC PRT 000L.
    and now all the protection measuring parameters like the DC_PRT, AMP-OLV, PS-PRT, and AMP-LMT are disturbed. They are now at -0.60, 2.44, 1.7 and 0.27 volts respectively.
    but while the +/-12 volt supply is fine along with the output amplifier power rails, being fine, at above +B/-B, at 54 volts however the output ceramic emitter resistor of all the 5 channels is showing -5 volts, which I think has disturbed the above parameters.
    I have tried looking for all the possible voltages at different connector and they all seems to be fine but I can check them again, if required. I went through some of the google searches and mostly techs suggested that this error is due the blown transistor at the output stage however, in my case there is -5 volts on all the emitter ceramic resistor, which make me think there is some voltage that is still able to pass through the output amplifier stage and run to the speaker relays.
    I will be really helpful if someone can suggest the next step.
    Thank you for your help!
    Regards,
    Hemant
  • dobrykamil
    • Jun 2013
    • 69
    AMP-LMT should be around 2.5-3.3V. You have only 0.27V, but check it right upon power on. Inspect circuit below, something is telling me, you don't have +BV and -BV rails. I've had exactly the same issue with rx-v3067. Check all low value resistors and Q63-Q67.
    • hemant_2222
      Hemant
      • Jul 2015
      • 78
      • India
      Hey, dobrykamil,
      Thank you for your time in reading the post.
      I had a chance to measure the voltages at the bases of the transistors Q63 and Q67, they are at -2.3v and 0.17v respectively and the both the emitter, which are tied together are at -0.3v. All these readings were taken in the diagnostic mode.
      Thank you,
      • hemant_2222
        Hemant
        • Jul 2015
        • 78
        • India
        Hi dobrykamil,
        Here is an update on the further troubleshooting that was done.
        There is a Zener disode D33, which was gone bad (shorted) and had disturbed the entire -BV rail. I have replaced it with normal Zener diode and the receiver is back up and running.😍
        Thank you your help!
        Regards,
        Hemant
        • u666sa
          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
          by u666sa
          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
          Platform: ipa32 la-m024p rev 1b
          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
          I found a short on the other side:
          10-04-2025, 05:03 PM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • Kuat
          Troubleshooting Audio Equipment Yamaha CVP-505
          by Kuat
          Subject: Yamaha CVP-505 IC204 Sub1 Boot ROM dump needed (MX29LV160DBTI-70G)
          Hello, I'm repairing a Yamaha CVP-505 Clavinova. The Sub1 Boot ROM chip IC204 (MX29LV160DBTI-70G, Yamaha part YA452A00) is corrupted. Diagnostic test 002 shows "No Card". The original chip data was partially erased before I could read it. I need a dump from a working CVP-505 IC204 chip (Sub1 Boot version 1.03 according to service manual). Can anyone with a working CVP-505 read this chip and share the dump? The chip is TSOP48, 2MB NOR flash....
          09-24-2026, 01:13 AM
        • jimmy2022
          Asus M3500QA R2.1 missing 3.3 and 5 volts
          by jimmy2022
          Hello. Main power rail and secondary power rail working, but 3.3 and 5 volts is missing. the ec chip has 3.3 volts except that all neighbouring components around ec chip either 0 volts or half volt. tested for shorts can't find anything. i have also included picture of 3.3/5volt chip. there is missing ac detect signal. any help? When pressing power button the 3.3 v drops and then goes back to 3.3 vafter letting go of the button
          5 v coil and 3.3 v coil has very high resistance....
          04-12-2026, 09:44 AM
        • supermattch
          HP 15dy-2021nr wont power on mystery volts
          by supermattch
          Hi everyone.
          I am diagnosing my personal laptop, because it wont power on and no leds light up.
          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
          09-23-2025, 12:13 PM
