I have two Marshall Acton III speakers that turned out to be pre-production (DVT) samples. Both have exactly the same problem, and I suspect firmware rather than hardware.
Boards (same on both units):
Main board: Tyler Main T651000015550, V0.2.2 (DVT2), dated JUN.10.2021
Handwritten sticker on the main board: "Firmware V.No. V5.08"
BT module (U1): label Tyler S, FWV5.06
Control board: TYLER_S_KEY T651000015520, dated 2021.03.26
Amps: TI TPA3128D2 (AU3) plus an ESMT chip (AU2); there's also an Awinic IC on the main board
Factory test checklist sticker: MC / BUN / WA / PT / AP / BTP / BTC / XFD (NFD on the second board) / NFT. Only some boxes are ticked: unit 1 has MC, WA, AP, BTC; unit 2 has MC, WA and AP/BTP.
Symptoms (identical on both units):
The speaker turns on as soon as it's plugged in, whatever position the power toggle is in
Source button does nothing, so I can't switch to Bluetooth. Only AUX playback works
The play/pause/skip control knob does nothing
Bass/treble/volume knobs work
Since both units behave identically, my guess is the DVT firmware doesn't handle the buttons and power switch (maybe a factory test mode with auto power-on)
Does anyone have a firmware dump from a retail Acton III, or know where to find one?
Which chip is inside the U1 BT module, and what programmer/tools do I need to read and write it? Is read protection usually enabled?
There's a 2x5 pin header on the main board. Is that the programming/debug port?
Is there any known way to get these units out of a test mode, or to switch source/enable Bluetooth without the Source button?
Photos attached. Any help appreciated. Thanks!
