I'm repairing a Marshall Kilburn II that came in dead - powers on (button press draws current, main components warm up briefly) but no audio, no LEDs, no Bluetooth pairing tone, nothing.
What I found so far:
- The AW9523B (LED driver/GPIO expander, drives the battery/power LEDs) had a visible hole burned into the package. Replaced it with a new one, soldering confirmed good - still no change.
- Traced the AW9523B's RSTN pin (pin 23) and found a low-resistance short to GND (~1.6 ohm after subtracting probe lead resistance).
- That pin traces back to the main MCU, an STM32F030C8T6 (LQFP48). Current injection (1V, measured ~250mA) causes a very localized hot spot on the STM32F package, right around the pin that connects to the AW9523B's RSTN line (pin 20 on the MCU, likely PB2 on the standard LQFP48 pinout).
Conclusion: whatever event damaged the AW9523B (visible hole) also appears to have damaged an internal GPIO driver stage inside the STM32F030C8T6. Replacing the AW9523B alone won't fix this - the MCU itself needs to be replaced or repaired.
I don't want to buy a full replacement mainboard (~100€ on AliExpress) for a unit I picked up for 50€, so I'm hoping to source just the firmware, or find someone with a working Kilburn II (or a donor board with the same MCU) who'd be willing to check a couple of things for me via ST-Link/SWD:
1. Read out the current RDP (Readout Protection) status via the Option Bytes - this is a non-destructive read, no erase involved.
2. If RDP is Level 0 or if you're comfortable with it, a full flash dump of the STM32F030C8T6 would be hugely appreciated.
I noticed there is a service port on the mainboard that appear to break out the SWD lines, which makes me hopeful RDP2 (permanent lock) isn't set on these units - but I obviously can't confirm without a live test unit.
Also happy to hear from anyone who has already dumped or has a copy of the Kilburn II firmware, or who's done similar STM32F030 RDP bypass work on other Marshall Industries speakers (saw the Stanmore II thread here, which covers a similar situation with the same MCU family).
Thanks in advance for any pointers!
