I bought this AVR-X1400H (E2, Europe) cheap as faulty, to repair. Seller said it died suddenly: no sound, no picture, headphones silent too. I have the service manual and a **working AVR-X1500H** on the bench as a reference. I've done a fairly complete diagnostic already — full details below so nobody wastes time on ground I've covered.
Symptoms
- No audio from any source: HDMI, USB, network/HEOS, analog IN1 and IN2, tuner. Nothing, on any input.
- The internal DSP test tone plays correctly** through the speakers, on every channel.
- No HDMI video output at all**: monitor reports 0 kHz / 0 Hz, so no TMDS clock. +5 V is present on pin 18 of the output connector (the monitor stops showing "no signal" when plugged, but never locks).
- No OSD.
- At every startup the unit shows `Please wait` then `Assigning` for 20-30 seconds. My working X1500H never does this. This is the only anomaly I've been able to qualify against a known-good unit.
What is proven good
| Block | Evidence |
| PSU, MCU, display, front panel, menus | All responsive, navigable |
| Protection circuit and speaker relay | Relay clicks 2-3 s after power-on. Protection history reads `NO PROTECT` — never tripped in the unit's life |
| DIR (IC761) | No `DIR ERROR` in diagnostic mode |
| DSP (IC781) — FLAG0, ACK, full handshake | No `DSP ERROR` |
| EEPROM checksum | No `BACKUP ERROR` |
| Backup memory | Counters were zeroed by the factory restore and now increment normally |
| Network module | Two OTA firmware updates completed, unit visible on the network |
| Media module | USB playback actually runs: track title scrolls, playback indicator on, `DIG.` indicator lit |
| DSP tone generator, DAC AK4458VN, volume IC (IC822), power amp, relay | The internal test tone comes out of the speakers |
| Region straps | R7581 = 0 Ω, R7582 not fitted → E2, matching the destination the unit reports |
| `PLD1.8V` rail | 1.781 V, stable |
## Service Path Check Mode results
- `A01:ANALOG PASS` — **silent**. This path is fully analog: RCA → NJU72750V matrix (IC821) → NJU72343V volume (IC822) → power amp. No DSP involved.
- `A06:AD` — **silent**. Measured **100 mV at the RCA input**, only **a few mV at the speaker terminals**, with the mode forcing Vol 60 (−20 dB).
- `A05:HDMI` — not testable: the unit presents no valid HPD/EDID on its inputs, so no source will transmit.
Key measurement
**`MVOL_MUTE` (IC822 pin 15): 3.3 V during the internal test tone (sound present), 0 V during playback of any source**, including `A01:ANALOG PASS`.
So the volume IC is **muted whenever a source plays**. The MCU only releases the mute for its own internally generated tone. My reading: the DSP never reports a locked stream, so the MCU never releases the mute.
Already tried, no change whatsoever
1. Factory reset
2. Two OTA firmware updates
3. Firmware Factory Restore (Dimmer + Tuner Preset CH− held, then Power) — completed, unit returned to original 2017 firmware, `Package 0000`, `M:0201703030405`
4. Service Region Settings via USB (`denon-config-locale-set-2`, Europe)
5. Full OTA update from the 2017 firmware back to current — completed, no `Update ErrorYYXX` code displayed at any point
One thing NOT to chase
The version display mode shows `FIRM ERROR` with a `▲` on the `Audio PLD` line. I spent a long time on this before finding the AVS Forum poll thread on 2017 Denon AVRs: **this is a known cosmetic quirk on this generation**, present on brand-new units, and does not affect functionality. The info fills in gradually and the marker clears on the second or third STATUS press. Mentioning it so nobody repeats my detour.
My questions
1. `Please wait` + `Assigning` at every single boot, 20-30 s — has anyone seen this? My reading is that the MCU re-runs the firmware assignment to a sub-component at each boot because it never completes. The Audio PLD (IC771, 5M570ZF256C5N) is written at boot via `PLD_WRITE` / `AP_CK` / `AP_DA`, and the service manual classifies it as category B (software may need rewriting on version updates). Would a failed PLD write explain the whole picture — no source routed to the DSP, no lock, mute never released?
2. Given the test tone comes out fine, **everything downstream of the DSP is proven good**. Where would you probe next? I plan to measure `AP_CK`, `AP_DA` and `PLD_WRITE` in DC during the `Assigning` window, and reflow IC771.
3. Is the no-HDMI-output a separate fault, or could both come from the same failed boot-time configuration? The GUI ROM (IC732) shows no version mismatch.
4. Has anyone ever obtained the factory USB update file `avr_40.prod.update.factory` for an AVR-X1400H E2, or found a way to force a rewrite of the Audio PLD image?
Related threads I've already read
- Denon AVR-X2000 no sound on main zone (this forum) — closest match I've found, unresolved. Same picture: no main-zone audio from any source, Zone 2 working, GUI intermittent, all audio diagnostic paths failing except A07. The OP traced it with a scope: analog signal reaches the digital board at `AD_L`/`AD_R`, nothing returns on `DA_FL`/`DA_FR`. **Difference in my case: my internal test tone does play**, so my DAC and power stage are confirmed good and my fault is narrower.
- Denon AVR-X1500H no sound at all (AVForums) — same symptom set but with a genuine `DSP ERROR 02`, fixed by the Firmware Factory Restore. My unit shows no DSP error and did not respond to the same procedure.
Service manual is the AVR-S730H / AVR-X1400H one, if anyone needs page references. I'll post any measurement asked for — the unit is on the bench and the `Assigning` phase is reproducible on every power cycle, so there's a 20-30 second window to probe in.
Thanks in advance.
Symptoms
- No OSD.
What is proven good
| Block | Evidence |
Key measurement
1. Factory reset
My questions
Thanks in advance.
