Arcom AVR400
  • dick_barton
    • Aug 2015
    • 6648
    • Wales
    Arcom AVR400
    Hello All,
    I am repairing an Arcam FMJ AVR400 amplifier. Fault is that neither of the two fans spin up. The manual says fan 1 should spin up when the temperature is between 65-70 deg C and fan 2 between 75 and 80 deg C. Both fans have been checked and are working.
    Without the fans running the unit switches off when the heatsink temperature exceeds 80 deg C.
    I have disconnected the positive temperature coefficient (PTC) mounted on the heatsink.
    The resistance at 25 deg C measured 80 ohms and at 100 deg C measured 240 ohms.
    It appears as though this is faulty but I am having a hard time trying to find a suitable replacement/substitute
    Any help or advice would be appreciated.
    The part number of the PTC is given as SYPSX08850JD
  • dick_barton
    • Aug 2015
    • 6648
    • Wales
    Perhaps anyone familiar with the Marantz SR6003 can help identify the part. It appears to have a very similar device, labeled TH91, Varistor, CRTSYPS06850JD
    • madan1
      • Nov 2016
      • 775
      From marantz SM:
      MAIN TH91 90M-HP000090R 90M-HP000090R VARISTOR POSISTOR ASSY CRTSYPSX06850JD
      There are lots of results for 90M-HP000090R
      For SR6003, th91 is responsible and for the overheat protection, so if the amp switches off when hot, then most likely it is working. You might want to check the rest of the thermal prot. and fan pwm circuits.
      • R_J
        • Jun 2012
        • 9775
        • Making Money
        Have you tried the Fan Test? [TH586]. Do you have FAN_12V? if not Q5911 may not be turning on. Signal must be present from FL, FR or C for the fans to turn on
        Does the amp stay on with no signal applied? if it shuts down with no signal, I suspect one of the amp sections could be at fault, check the Dc offset voltage on all channels
        • dick_barton
          dick_barton commented
          Editing a comment
          Many thanks for your help.
          I haven't tried the fan test since the PTC reading are nowhere near what the manual says they should be at the various temperature.
          The service manual gives a number of reading for the PTC at various temperatures.
          80 ohm at 25 deg
          105 ohm at 65 deg
          140 ohm at 75 deg
          1300 ohm at 100 deg
          4000 ohm at 105 deg
          When the PTC is tested out of circuit on a hotplate the min resistance reading is 80 ohms at room temperature and 240 ohms at 100 deg C.
          The fans themselves work when 12V is applied to them.
      • R_J
        • Jun 2012
        • 9775
        • Making Money
        Are you getting any audio from the channels before it shuts down?
        Install a 1K resistor in place of the ptc, that would tell the circuit the heatsink temperature is around 90c and the fans would turn on if the ptc is the problem.
        Like I said, the fans will never come on with no signal to the amp, at idle there will be no FAN_12V
        • dick_barton
          Editing a comment
          Hello R_J
          Thanks for your reply/ The amplifier works well until it overheats and then goes into I believe protection mode. The resistor in place of the PTC is a good idea and should indicate if there is a fault further back on the control side.
          Many thanks
      • dick_barton
        • Aug 2015
        • 6648
        • Wales
        Hello R_J
        With a 1.2K resistor in place of the PTC the voltage across it was 5.95V. When replaced with a 3.3K the voltage was 8.05V and with 4.5K the amp went into protection.
        It looks as though either the 12V_Fan voltage is missing or there's a fault in the fan drive circuitry. Both fans when connected to a power supply each run oK at 12V, 330mA
        Thanks for all your support. My colleague whose amp it is had made a note of all the findings and has taken it back.
        Regards
        • AndyTech
          • Feb 2021
          • electronics
          Hi im gonna add 5 cents , Arcam avr 400 and 600 suffer from overheating , its a well know problem , the main issue is an unstable bias of power transistors goes to high causing overheating of power end , there is video on YouTube showing repair ( replacing capacitors around driver IC ) , i did that on my Arcam and didn't help a lot , i have purchased another avr-400 for parts and notice there is modification , they added thermistors to bias settings pots - with modification bias is more stable but still a bit high .
          fans on this models come on very rarely , if you using this avr in home conditions with reasonable volume fans will not come on
          good luck.
          • skdsp
            Helping troubleshooting PWM control of fans/GPU on HP Omen 16 Gaming Laptop 16-xf0087nr
            by skdsp
            I recently repaired a HP Omen 16 laptop that had no power and ended up having a burnt PUU1 (SY8370CTMC) component.
            After replacement, the laptop powered on successfully but had issues with the fans where I could only have one plugged in at a time and they would spin maximum speed for a few seconds then turn off with 0V going to the +12V pin.
            Each fan will work individually for a few seconds then turn off and I get a BIOS fan error.
            I thought I maybe just had bad fans so I proceeded to install Windows and noticed that the discrete GPU (RTX...
            05-30-2026, 11:44 AM
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • Jazoe
            Acer Nitro 5 AN515-55 (LA-K862P GH51M) - Turns on for a split second, fans spin then stop, lights stay on (Not BIOS/EC)
            by Jazoe
            I am working on an Acer Nitro 5 AN515-55 with motherboard model GH51M LA-K862P.
            The Symptoms:
            When I press the power button, the cooling fans spin up for a fraction of a second and immediately turn back off. However, the keyboard backlight remains on, the power LED stays solid blue, and the charging LED remains solid orange (indicating it detects and charges the battery normally).
            There is no image on the screen, and the laptop appears stuck in an early power state.
            What I have tried so far:
            1. Power Drain & Hard Reset: Disconnected the main battery
            07-07-2026, 02:20 PM
          • eccerr0r
            Shipping PCs with heavy heatsink/fans...
            by eccerr0r
            For people who have shipped PCs with huge heatsink/fans through UPS/USPS/Fedex... do they survive?
            How does one ensure that the heatsink stays attached and does not rip itself off the motherboard?
            Or do they tend to stay in place just fine?
            04-13-2022, 11:24 PM
          • AppleLover123
            Asus Zenbook "braindead"
            by AppleLover123
            Hello guys,
            i have an Asus UX51VZ here from scratch.
            It powers on and won't post. (fans not spinning)
            The first thing i noticed is that the ampage that it takes is the same everytime.
            Like it won't change if i reset the bios with the battery. It stays at the 470 milliamps when turned on.
            I found that all voltages are okay except on the vcore and gfx_core.
            On Vcore 0 Volt as well at GFX_Core just 1 volt at nvdd.
            Vcore = 1.4 ohms
            Nvdd= 23 ohms
            Gfx_core= 1.4 ohms
            Now in my opinion i think that the cpu is partial...
            03-15-2025, 11:24 AM
