I have a Tascam CD-RW900 CD recorder that I was asked to fix that is having some issues with the CD drive. It came in with the drive tray stuck half way out and not closing so I though this should be easy and straight forward, which it was, until I got the drive out to start disassembling it to get the tray realigned. The owner decided to flood the inside with WD-40 to unstick the tray. I was really hoping that just cleaning the lens would be all it needed, but the drive doesn't read at all anymore. I opened it up while it was hooked to power and it will spin the disc for a second then throw a no disc error.
The problem I am having is I can't find a replacement drive for it anywhere using the Drive model number ( CD-W58DB-T00) Since it looks like a regular IDE drive without the eject button, volume knob, or headphone jack. I tried a couple of LG drives and it would say reading but it would get stuck on reading and never progress past that. While it said reading pressing the eject on the drive and on the unit itself wouldn't eject the drive.
Reading around online it sounds like the drives are more specific to the unit itself than a standard drive, but that was only things I was able to find online on other forums. I did look through the service manual and was unable to find anything online for this unit using the part number listed it there.
I am hoping someone out there has some experience with these things and what drives will work or if anyone knows if an ide to sata adapter would possibly work on this?
