Samsung MX-T70 Sound Tower - Dead, stuck in early boot loop / bootloader console via UART (Need Dump)
  • janos6662000
    • Mar 2015
    • 69
    I'm working on a Samsung Sound Tower MX-T70 (1500W Party Audio) that came to me completely dead, showing no signs of life. Since I couldn't find any schematics or service manuals, I did some deep diagnostics and measurements.
    Here is a summary of what I have checked and done so far:
    • Power Supply: The standby voltage is present and stable at 12.3V–12.5V. The 3.3V rail is also active.
    • Power Button: The power key pin receives 3.3V and successfully drops to ~0.3V when pressed, so the signal reaches the board.
    • PSU Forced Start: I identified the Power-On pin on the 14-pin cable connecting the PSU to the mainboard. By injecting 3.3V into this pin (with the mainboard disconnected), the power supply wakes up fully, and the main amplifier rail appears, delivering a stable 56V DC.
    • Previous Hardware Issues Fixed: The unit previously had a failed primary-side startup capacitor (CE8) on the standby rail, causing a hiccup/pulsing effect under load. Additionally, the ribbon cable going to the sub-board (I/O & BT module area) was physically damaged, shorting Pin 1 (GND) to Pin 2 (12.3V Standby). I successfully replaced the ribbon cable, repaired the standby power supply, and now all voltage rails are completely solid and stable.
    At this stage, I suspected a firmware corruption—possibly caused by the power supply pulsing or the short circuit during previous operation.
    The firmware resides on a GigaDevice GD25Q32SCP (32Mbit / 4MB SPI NOR flash). I desoldered it, read the content using an XGecu T48 programmer (the read and verify process completed with no errors), and flashed the exact dump onto a brand-new, identical chip. Soldering the new chip back didn't change the behavior.
    Next, I hunted for an UART interface to see what the CPU was doing. I found an unpopulated 4-pin header near the Bluetooth module area (XP16). After connecting a USB-to-TTL converter (configured to 3.3V logi levels at 115200 Baud), the terminal output confirmed my suspicions.
    Upon plugging the unit into AC, the console prints exactly this and then completely freezes:
    Plaintext
    [AV] Samsung Party T70
    1000.0 >
    This output proves that the main SoC is getting the correct voltages, the clock signal is running, and the SPI bus is functionally active, as the CPU successfully reads the model identifier string and the firmware version (1000.0 or 1007.0) from the header of the flash memory.
    However, right after printing the prompt > character, the boot process halts completely. The console is non-interactive (does not accept RX inputs/commands), and pressing the physical power button triggers no change or further logs.
    It strongly appears that the main firmware binary is corrupted right past the initial bootloader header.
    Unfortunately, Samsung only provides standard USB update packages on their support page, which requires a functioning system to initiate. I have searched everywhere but cannot find a raw SPI dump for this model.
    Does anyone happen to have a known-good working SPI Flash Dump (.bin) for the Samsung MX-T70?
    Any help, dump files, or further advice would be highly appreciated!
    Thank you in advance!
    Janos
  • janos6662000
    • Mar 2015
    • 69
    Anybody?
    • Kolyaping
      Kolyaping commented
      Editing a comment
      Didn’t you find any Solution?
  • Kolyaping
    • Aug 2026
    Hi, just got same mx t70 it has same problems, 12v, 3.3 is here, dropping to almost 0v when I pressing the Button But it still doesn’t turn on, did you found dump file?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8884
      Sounds like U-Boot is FUBAR. Maybe compare the U-Boot section of the NAND. Just a firmware update, does not include the full firmware with U-Boot etc.
      • Kolyaping
        Kolyaping commented
        Editing a comment
        So, you mean, there no chance to repair that? As Long we have no dump file?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8884
      Chances are very slim.
      • pichai5004
        Request: Cisco WS-C3850-48F-S V04 SPI Flash / Bootloader ROM Dump (Hard Bricked after Power Outage during Bootloader Upgrade)
        by pichai5004
        I am requesting a working SPI Flash / Bootloader (ROMMON) dump file (.bin or .hex) for a Cisco Catalyst WS-C3850-48F-S (Hardware Revision: V04).
        --- Problem Background ---
        - I attempted an IOS-XE upgrade on this switch to version 16.12.13.
        - During the boot process, the system deleted the image file due to low flash space (<300MB) and entered a Bootloader Upgrade process ("PLEASE DO NOT POWER CYCLE ### BOOT LOADER UPGRADING 4").
        - Unfortunately, a power interruption / manual reboot occurred while it was updating the bootloader...
        10-15-2026, 01:26 AM
      • BigPete
        Panasonic LED TV Dead after EMMC dump
        by BigPete
        I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
        The dump was successful and the program finished without errors.
        I used a XGecu T48 to do the dump.
        I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
        One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
        I also shorted out the crystal of the adjoining ECU together and at one...
        03-15-2026, 03:08 AM
      • Darksands
        Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
        by Darksands
        [SOLVED]
        Laptop: Dell Pro 14 Plus, PB14250
        Motherboard: PWB CMF34, Rev (A00).
        Service Tag: 3YLQ8F4.
        CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
        BIOS Flash Chip: Winbond 25R512NWEQ.
        BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
        Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
        09-13-2026, 03:15 AM
      • s.izadbakhsh
        Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
        by s.izadbakhsh
        I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
        Here are the motherboard details:
        • Model: Tongfang GM5AGFO MB V1.1
        • CPU: Intel 12th Gen (Alder Lake)
        The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
        Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
        Could someone please provide...
        06-24-2026, 09:10 AM
      • Remskiy228
        BIOS Dump Request — Lenovo ThinkPad P14s Gen 5 Intel (21G2) (21G3)
        by Remskiy228
        Hello everyone!
        I'm looking for a BIOS dump or assistance with BIOS recovery for my Lenovo ThinkPad P14s Gen 5 Intel.
        Laptop specifications:
        - Model: Lenovo ThinkPad P14s Gen 5 Intel
        - Machine Type: 21G2
        - CPU: Intel Core Ultra 5 135H
        - GPU: NVIDIA RTX 500 Ada Generation
        Problem:
        My laptop stopped booting after a firmware update through Lenovo Vantage. It powers on but does not POST or display anything.
        What I'm looking for:
        Either of the following...
        Today, 09:48 AM
