Avr370 blown fuse, please help
  • robert1000
    • Aug 2015
    • 19
    Hello good people!
    I have a HK avr370. The main fuse is blown.
    Mosfets Q905 and q910 are shorted.
    Ic ob2358 has 3ohms between vcc and gnd pins. Guess it is shorted?
    The standby transformer, on primary, it measures 5.2ohms and 1.50mH between 1-2 pins, and 0.50ohms between pins 3-4 (see photo attached). It the transformer faulty?
    Thanks! Waiting for your replies!
  • lotas
    • Jan 2016
    • 5385
    • Russia
    Most likely it is working, 5 Ohm is the normal resistance of the power winding of a pulse transformer.
    • R_J
      • Jun 2012
      • 9722
      • Making Money
      There may have been a mains spike that caused the problem, Q905 and Q910 are not really part of the standby circuit, I would check if D914 zener is shorted, also check D911 for a short. ic91 may have survived. if D914and D911 are ok then ic91 is bad, I would get the standby circuit working first then go on to the two other circuits with Q905, Q910
      You may want to check IC92 pins 4or5(Drain) to 3 (cs)
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • whc14765
        Gigabyte 980TI Windforce - Blown PCIE Fuse
        by whc14765
        Hey,
        I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
        The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
        I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
        1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
        04-08-2022, 06:22 PM
