Need advice on an MK4800 Class AB power amp
This topic has been answered.
  • Crystaleyes
    • Sep 2021
    • 511
    • Brazil
    Hi people.
    I have this Mark Audio MK4800 amp where the Left channel output gets scorchingly hot and just stays that way, even when the input signal is removed. It's almost like a semiconductor breakdown has occurred.
    Originally I thought that it might be only incorrect biasing, and in fact the base voltage to the output transistors (both NPN and PNP) is just short of double the cool running, Right channel, however there are no trimpots to make any bias adjustments and looking at the schematic I'm not sure where a modification could be made to resolve any imbalance?
    Amplifiers are not my forté, but when they do (rarely) come my way, I normally find any damaged components and get the unit working again. In fact this unit 'is' working, only with seriously imbalanced outputs.
    I've attached the full set of schematics. The relevant channel page is 4: PWR-A.
    The overheating starts at T 14A (2SA1837) and T 15A (2SC4793) then affects every other transistor from there up to T 21A. These two transistors are perhaps the root of the problem as the Emitters on the good channel are balanced at around 0.4v whereas (before overheating) the Emitters on the Left channel are around 0.55v and 0.3v. During the overheating they are both stuck between 1.2 and 1.5 volts.
    No other components are getting hot, not really even warm. The Left channel won't heat up until it receives a signal past a certain level. It can be used at a low volume for seemingly hours without overheating.
    Whilst I swap out the 2SA1837 and 2SC4793 from the good channel...
    ...Any amplifier techs out there who can help out?
    Click image for larger version  Name:	MK4800_Schematic.png Views:	0 Size:	37.5 KB ID:	3866753
    Click image for larger version  Name:	P1110911.jpg Views:	0 Size:	5.38 MB ID:	3866754
  • Answer selected by Crystaleyes at 05-10-2026, 04:17 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8641
    I said I’m my post number 3 that this is not an output transistor problem. Since you’re plan off attack changed by taking things off the board, we’ll keep doing that. That is what I do as well for certain reasons. Do it by stage’s for example all output transistors, all bias transistors, etc. Also strategic placed resistors to isolate a circuit etc. Could be anything even from a short in a component or bad component to an open trace.
    • mon2
      • 16110
      Hi. Not an expert on this but we have fixed a number of similar amps. Recall something like this schematic in the past 6 months. The fault was with the end high / low side transistors.
      Remove all power. Meter in resistance mode. Measure the resistance from the collector (high side transistor bank) to the coil that is driving the speaker output. What is the resistance?
      Repeat the same test but this time from the collector of the south (low) side transistor bank and the speaker again. Anywhere you have a low resistance, that bank is a suspect and at least one of the transistor is defective. Flux and remove the transistor(s) till the resistance is higher. Respectively, you can test the removed transistor by using diode mode of the meter and watching one of the many YT videos on this topic. If I recall correctly, we had to replace one of the transistors to fix the amp. Do not power up with a missing transistor but use this method to locate the bad boy(s).
      Curious on your progress so continue to post here.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8641
        I think there is nothing wrong with the output transistors. The problem is in the biasing circuit as the transistors are oscillating and getting hot a Eff. Bummer is there is no trimmer pot. Since you got one working channel use it as comparison.
        • Crystaleyes
          • Sep 2021
          • 511
          • Brazil
          Thanks for the suggestions fellas.
          mon2
          I've not encountered that Collector to coil test before but shall definitely remember and use it.
          As for the readings, there's some strangeness going on...
          The 2SC5198 NPN's all consistently measure around 700kΩ.
          The 2SA1941 PNP's, on both channels measure considerably lower. The first measurements (taken just before I started this reply) were around 200kΩ. Twenty minutes later it was 70k, then a few minutes later 10kΩ, on the last reading five minutes ago it is back around 70kΩ on all 2SA1941's. Both channels.
          How does that work?
          All of these transistors test fine in diode mode on my calibrated Fluke 289, in fact two of them were replaced yesterday.
          This has now raised the question in my head as to 'why', if both channel PNP's are reading low in regards to the coil circuit, does the right hand channel hardly get hot, if at all?
          I must admit that it seems that the cooler channel could have more power, but we'll cross that hurdle when we get to it.
          Gonna leave the amp overnight and take more readings in the morning as it was running for hours today as I tested components and settings.
          CapLeaker
          Until those coil tests I was in agreement with you regarding the bias and am definitely not ruling that out.
          The question is, "Where in the circuit could the output stage bias be tweaked?"
          This amp is Brazilian and even in Portuguese, technical documentation for this amp is almost non-existent. It seems to me that they might be using diodes, resistors and capacitors to bias different stages.
          Regardless, I don't want to bias the amp too far back down the line.
          EDIT;
          I'm now wondering if a previous tech has crossed a couple of wires over?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8641
            Correct. Usually you don’t find 3 diodes in series.
            • Crystaleyes
              • Sep 2021
              • 511
              • Brazil
              Just did some more Collector/Coil testing and now the readings are stable.
              The PNP's all measure 0.50 MΩ
              The NPN's all measure 0.57 MΩ
              None of those seem low so back to somehow adjusting the bias.
              As I mentioned the problem does display symptoms of semi-conductor breakdown but I don't have a curve tracer, so maybe I'll just replace certain diodes and see?
              • Crystaleyes
                • Sep 2021
                • 511
                • Brazil
                EDIT;
                Rewind.. It's not cooling down
                I'm fast losing patience with this amp. The left channel just keeps heating up and I have a life to get on with.
                Swapped over a couple of the diodes - no difference.
                Increased the Left channel R30A and R31A resistors form 470Ω to 620Ω but those transistors are still way too hot to touch. In fact when shining a light through the pcb it can be seen that T14A and T15A have scorched the board. They have no heat sink and I don't believe it's a design fault.
                Considering the owner doesn't want to pay a penny, after 15 hours over three days, I've had enough of this shitty amp.
                Thanks again for the suggestions and support.
                • mon2
                  • 16110
                  Had a similar day with a macbook repair that we suspect was stolen and was locked. Client stayed on the premises for hours (most of the afternoon) and then decided, never mind, he will consider to buy a new unit. Our (spineless) fee = 'take it bro with a smile - no charge'. What a waste of a day!!
                  My suggestion is to consider using an external powered PC speaker with a 0.1uf cap at the tip of the input cable to this speaker. The cap will be used as a probe for this defective amp. The owner will likely scrap it so you probably could try some other ideas or not.
                  That is scary. I would review the full part # on the part -> google the type of transistor they are -> review how to test the transistor out of circuit with a multimeter. Watch a few YT videos on this topic to confirm if the part is good or bad.
                  If good then the output of these parts is shorted and forcing these parts to be over loaded. You may even find typical schematics with the same transistors which you can use as a reference for study on websites / YT. We did for a mix of our audio equipment.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8641
                    Check out T10A and R26A. If you change that resistor it should set the bias. Anything off spec, well… bias is going to be off as well.
                    • Crystaleyes
                      • Sep 2021
                      • 511
                      • Brazil
                      So had another look. And testing every transistor, diode and resistor in circuit revealed nothing obviously out of the ordinary.
                      mon2
                      Those transistors are a BD 139 and BD 140
                      Can you give more details on that active speaker and capacitor trick? As in are you saying connect one side of the speaker to the amp output and then use the cap to probe through the circuit?
                      As for the owner, there is no way he will scrap it as it still plays even if incorrectly.
                      CapLeaker
                      Both those test fine. The reisistor is 100.02 Ω.
                      I'll change the value tomorrow and see how it goes.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8641
                        maybe the problem is further left on the schematic?
                        • Crystaleyes
                          • Sep 2021
                          • 511
                          • Brazil
                          Would make sense.
                          I'm thinking of swapping from the good channel, all the remaining semi-conductor devices until something presents itself.
                          Failing that, I'll call it a day. It's not been a complete waste of time as I have learnt more than I knew before..
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8641
                            check out the transistor pair T1A and T2A you need to take them out
                            • Crystaleyes
                              • Sep 2021
                              • 511
                              • Brazil
                              Ok, right...
                              had a break due to lack of time, however..,
                              CapLeaker
                              removed and tested T1A and T2A as well as T4A and T5A but all is in order.
                              mon2
                              Went back to your original suggestion and between Collector and coil on all the NPN's it was reading between 5 -7 kΩ, (whereas the PNP's are still above 600kΩ). So, one by one removed each of the 2SC5198's and even the 1N5406's but that made no difference.
                              The reading actually rises if I keep the probes connected (don't tell me it is a capacitor problem...?) anyway it is clearly not an output transistor problem.
                              The headfuck is that the readings keep changing
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8641
                                • Crystaleyes
                                  • Sep 2021
                                  • 511
                                  • Brazil
                                  Don't want to speak too soon, however after resoldering the components mentioned above as well as reflowing various resistors and transistors, I ran the amp for well over an hour today and lo and behold, it no longer overheats!
                                  Ok, I don't have 800W speakers nor a preamp but it certainly seems that I can no longer reproduce that problem. The amp was run at full volume, and/or ran with the input signal overdriven and nothing could get the overheating problem to reappear.
                                  The amp has a few years on it and clearly had previous repairs, so perhaps there was a dry joint hidden in there somewhere? The traces side of the pcb is not easy to access but it's a good lesson for me to not be lazy and to just remove each and every suspect component.
                                  NOW, the amp will go back to it's owner
                                  Sincere thanks for the patient support
                                  • rustinjust
                                    Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                                    by rustinjust
                                    My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                                    The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                                    It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                                    I have to turn the tv off and then on again with...
                                    09-28-2023, 12:23 PM
                                  • eccerr0r
                                    old X58 triple channel board... memtest86 memory speed?
                                    by eccerr0r
                                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                    06-28-2025, 09:06 AM
                                  • spleenharvester
                                    Reverse engineering of 18650 4-channel tester
                                    by spleenharvester
                                    Hi friends
                                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                    05-04-2025, 02:43 AM
                                  • tronitas46
                                    B&W ASW1000 output stage transistors bias imbalance issue
                                    by tronitas46
                                    hi everyone!
                                    I'm having an issue with my subwoofer and this is getting beyond my basic knowledge and at this point I'm not sure what I'm doing so I decided to stop and ask for help.
                                    long story short:
                                    I bought this sub about 5 years ago for cheap with no audio issue, I found out it was a simple dirty phase switch that contact cleaner fixed, the sub was working great with the exception of making a poping noise when turning off (which was super annoying)
                                    since I was using it every day I figure I'll just put to switch to always ON and be good with it (I know,...
                                    02-13-2026, 03:53 PM
                                  • CDNBrewer
                                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                    by CDNBrewer
                                    Hello Everyone,
                                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                    Symptoms:
                                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                    • I swapped the Left and Right surround
                                    08-05-2025, 09:29 PM
