Hi, So i am trying to troubleshoot the amp. Following the reason of the protection mode by overheating(at room temperature) I ended up at a little snippet of the power supply's circuit for the thermal sensor. I do not have any idea why it is passing almost the entire voltage trought Q129. I replaced the 4 transistors and the zenner diode and nothing changed. Anyone has any explanation for that? thanks?
Yamaha R-S202D amplifier, not regulating voltage
by rsa4092Acer Nitro 5 - AN515-54-52PY - LA-H501P
Hello, Iām having a problem with my Acer Nitro 5 laptop, which has a Compal LA-H501P motherboard.
Initially, the CPU power regulator was replaced because the computer shutdown unexpectedly, and couldn't be turned on, the service centre diagnosed a short circuit in the CPU power regulator, replaced it and laptop was working. After about two months, a new problem arose ā the laptop would shutdown under heavy load, even when connected to charger. In addition, the battery was charging very slowly ā or rather, discharging ā despite... -
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... -
The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
Internal soft-start results in small inrush current and extends battery life.
The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:02 AM -
3+1 Voltage Regulator for IMVP-7/VR12 CPUs
Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
Based on Intersil's Robust Ripple Regulator...-
11-05-2024, 03:24 PM -
- Loading...
