Marantz M-CR610 mcu replaced, advice & firmware needed
  • Eagle26
    • Feb 2026
    • 10
    I have a Marantz M-CR610 (UK version) which suffered lightning damage. The mcu (IC21 R5F56108VNFP) failed with a couple of pins permanently shorted to ground so with nothing to lose I decided to replace the ic. The shorts have now cleared and its clock is running but of course it contains no code.
    Does anyone happen to have the necessary firmware files which I presume will need to be loaded via the small seven pin connector WF81 beneath the unit. Any experience of, or information on this process would really be appreciated as the service manual only refers to upgrading the existing firmware via usb using the menu system which obviously needs code to already be present. Thanks in advance for any help.
  • ngvuanh
    • Jul 2013
    • 58
    You seem to be out of luck once you replaced mcu with a blank chip.
    The best and easy option for you is to buy a pre written mcu from a parts store like encompass.com for your unit.
    if you want to go with other option by flashing the firmware for mcu, you will need to find a dump from other unit which is nearly impossible to find. Then you need Renesas Emulator E1 or E2 to program the chip.
    • Eagle26
      • Feb 2026
      • 10
      Thanks for the reply and kinda confirming my thoughts that it's probably not doable without a programmer and the official firmware. I've searched high and low but Marantz just don't seem to provide any downloadable firmware. Following your suggestion I found a company here in the UK, fixpart.co.uk, which is listing the mcu and describes it as from "original product manufacturer". It's expensive, nearly £50 and with a long lead time. I contacted them to ask if it would be pre-programmed with the necessary firmware direct from Marantz but they wouldn't confirm it.... Not very helpful! I guess the only way I'll find out is to bite the bullet and order one.
      • check12
        • Nov 2012
        • 142
        Why don't you ask Marantz about the replacement MCU? .... I've been surprised sometimes about how helpful some companies can be especially if you can get through to the tech. department ...
        • ngvuanh
          • Jul 2013
          • 58
          You will never unless you are their authorized service center.
          • check12
            • Nov 2012
            • 142
            Have you tried to contact them?
            I've been told companies are unapproachable over & over on forums but in reality I don't think there's a single company that hasn't helped me when I've contacted them.
            They may not send you schematics etc. but if they are providing oem MCU's to a parts supplier I don't see why they wouldn't tell you if it had the firmware programmed or not.
            Like I said I've been surprised in the past how helpful companies are when I've been told it's impossible... you've just got to ask the right way.
            How did you contact Marantz when they told you that?...
            • Eagle26
              • Feb 2026
              • 10
              Hi all, Just a quick update....In the end I ordered the mcu from another company, spares2repair, listed as an original part so time will tell if it is programmed or just a blank. You'll probably hear the scream from here! I'll report back how it goes when it turns up...it might just help someone faced with a similar situation.
              • check12
                • Nov 2012
                • 142
                Fingers crossed for you! ... yes let us know how it goes
                Usually though I find that if it's available from spares2repair then it's available from the manufacturers cheaper
                But then I rarely deal with hifi gear... Usually it's pro-audio I'm involved with so maybe that's what makes the difference in my experiences with manufacturers...
                • Eagle26
                  • Feb 2026
                  • 10
                  I have everything crossed! I agree with you, the prices on that website are insane. I've spent a lifetime in consumer electronics and all the big players, the likes of Sony, JVC etc just didn't want to know you unless you were an approved service agent so that may have coloured my approach here. Now retired, I still have the urge to repair stuff so I buy the odd bit of hifi gear to keep the soldering iron warm and my brain alive. I usually buy Denon which is so easy to fix. I've had success with a few Marantz M-CR611s which were pretty straightforward with their poorly designed psus but this '610 just bit me back... I do like a challenge. Will keep you updated.
                  • check12
                    • Nov 2012
                    • 142
                    Me too... retired recording engineer & musician which is why my main interest is in pro-audio electronics but I have repaired a few pieces of hifi over the years... it's always amusing listening to all the hifi buzz phrases... I also like to show the "believers" a selection of caps to see which colour they think will sound best... 😊
                    • check12
                      • Nov 2012
                      • 142
                      Any update... did the part work?
                      • Eagle26
                        • Feb 2026
                        • 10
                        Hi, well that's a coincidence....Just got an email from spares2repair to say that the part is now with DPD and should be with me shortly. I'll report back when it arrives...
                        • check12
                          • Nov 2012
                          • 142
                          I'm on the edge of my seat ....
                          • Eagle26
                            • Feb 2026
                            • 10
                            The mcu finally arrived. 144 pins later I plugged the unit in and lo and behold the oled display lit up and it worked! Still can't quite believe it. Of course things were not that straightforward, when I plugged in a usb drive to play some mp3s all I got was silence, no audio at all. I left it running for a while then suddenly a digital hash came from the speakers followed by the unit shutting down with a flashing red led (protection mode). On entering special mode, protection history, it reported "SP Protect". To cut a very long story short I eventually discovered that the 3.3 volt ldo linear regulator IC52 was osclilating at around 1.36 MHz and outputting only 2.6-2.7 volts. This powers all the digital processing circuitry so it kinda made sense why I was getting corrupted audio. The two capacitors around the regulator, C513/516 had fallen in value with a high esr. After clearing protection mode and replacing these the unit worked. I was curious if any of the other capacitors on the board were on the way out and on checking a few they were all well on the way to the great capacitor graveyard in the sky....I decided to re-cap the whole lot. The capacitors live on a board buried underneath the class D output board so they get pretty toasty which makes Marantz's descision to use cheap 85C capacitors mind boggling. There is something very satisfying about saving e-waste from the tip.
                            • Eagle26
                              • Feb 2026
                              • 10
                              ....oh and excuse the typos, funny how you don't see them when typing....I blame it on old age eyesight and way too much excitement in one day!!
                              • dobrykamil
                                • Jun 2013
                                • 69
                                Common issue with IC52 output rail, happens after some time, if Network Standby is set to ON, which is a default option.
                                • Eagle26
                                  • Feb 2026
                                  • 10
                                  Hmmm... well that's odd, with the unit I have here in standby, IC52 is disabled by the mcu regardless of whether network standby is set to on or off in the settings menu (network control), so I can't see how setting it to on would adversely affect IC52 or its local caps....unless of course the unit is repeatedly woken over the network. Anyway I'm just relieved the thing is finally working!
                                  • check12
                                    • Nov 2012
                                    • 142
                                    144 pins later
                                    I know that feeling!....
                                    Chuffed for you!... as we say here North of the border.
                                    At least that offsets the mad spares2repair prices. I remember looking at them for a chip amp IC for a Sony (can't remember which one now) but they wanted £80 for a £3 IC
                                    I ended just buying a cheap parts unit and getting about 5 genuine spares.
                                    Yeah as ever small 85c caps causing havoc... did you do a full re-cap?
                                    He he, just noticed Canned Heat as the test track... that's showing yer age.. great band but the singers voice always reminded me of Kermit the frog.... ​
                                    • dobrykamil
                                      • Jun 2013
                                      • 69
                                      Correct, I was was wrong. IC52 provies power for digital audio circuit.
                                      • Eagle26
                                        • Feb 2026
                                        • 10
                                        No probs, I changed the caps around all the other regs so everything should be good.
                                        • satbeginner
                                          Firmware for Marantz SR6009 needed, bricked after power fail
                                          by satbeginner
                                          new to Badcaps, my name is Leo, I am a retired Dutch engineer now living in sunny Spain.
                                          After a power fail my trusty Marantz SR6009 bricked its firmware.
                                          I checked all voltages and fuses but these are all OK.
                                          Furthermore, when I initiate the Firmware restore via USB, the display lights up with the USB message and the walking dots, so to me it seems the hardware is still OK.
                                          But, I need the firmware file to restore the firmware via USB.
                                          I know it is a longshot because of the age of this amp, but I can only hope..
                                          Thanks...
                                          04-04-2026, 03:13 AM
                                        • weisian
                                          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                          by weisian
                                          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                          03-12-2026, 05:54 AM
                                        • Daniel Larsson
                                          Firmware file for Marantz NR1501 needed
                                          by Daniel Larsson
                                          I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                                          After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                                          The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                                          The content of these seems to be useless as far...
                                          05-23-2025, 04:11 AM
                                        • Robby-Gr
                                          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                          by Robby-Gr
                                          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                          Additional issues:...
                                          09-27-2025, 12:02 AM
                                        • Nebukadnerzar_V
                                          Firmware needed: Samsung Odyssey G9 LC49G94TSSPXEN
                                          by Nebukadnerzar_V
                                          Hi!
                                          I am working in a Samsung Monitor with Model Code LC49G94TSSPXEN.
                                          The Power Supply is working fine, but the mainboard is stuck in a boot loop.
                                          All voltages on the board are present, so I am suspecting a Firmware issue.
                                          Since I cannot find a Firmware to download on Samsungs website, I am kindly asking, if someone here can provide a firmware dump for this model.
                                          Model: LC49G94TSSP
                                          Mode Code: LC49G94TSSPXEN
                                          S/N: 0NLKHNTW200306L
                                          I have attached the firmware dump of my unit, just in case it helps....
                                          Today, 03:28 AM
