Dear reader
I am looking for a suitable replacement part for the headphone jack for a Sony SW55. The current one often stays stuck inbetween input and speaker mode, resulting in reduced or no speaker volume. Using the regular cleaning tricks didn't work.
The part name is 1-507-806-00 JACK 1P (J4 on PCB schematic). Not much can be found on the internet. It seems the green barrel jack part uses 3 THT pins (what I'd expect), to which a separate seemlingly joined grey piece has 6 THT pins. I am making the assumption that the joined grey and green parts are linked, but I am not sure. The PCB 'x-ray' board overview seems to indicate they are not linked.
I am not familiar enough with common part technological compatibily / substitution to think of something myself. If some creative problem solving or a workaround is required (soldering, wires, components, etc.), that would be no issue in fabricating, as long as the instructions are clear enough
Thank you in advance.
Kind regards
Kind regards
