Onkyo SR806 buzzing noise on outputs
  • tony359
    • Oct 2018
    • 287
    HI all,
    I'm trying to repair an Onkyo SR806. Originally it had the usual "faulty DSP" sympthoms but it turned out that the supply voltage of the DSP chips was oscillating. I found both capacitors after the linear regulators for the DSP supply to be dead and that was causing the issue.
    Once that was resolved, I focussed on the other issue: a pretty loud buzzing noise from the speakers, the usual 100Hz (I am in the UK so we have 50Hz here).
    I've unplugged the amplifier board from the inputs and there is NO noise so the issue is in the signal being fed to the amps. I tried feeding some music directly to the amplifier board and it works with no noise.
    And here is where I'd like your input: the noise is obviously pretty low on the oscilloscope, I cannot really see it clearly so it's difficult to track it down.
    I've noticed that +12VHDMI - the main voltage which is then being used to 1.8V, 2.5V and 4V (which is in turn used to generate the many 3.3V on the board) is a bit dirty, it's got about 500mV of ripple. But all the voltages generated from it seem to be fine. The 12VHDMI is filtered by only one 10000uF capacitor. Could that be the issue?
    Any ideas without having to re-cap the whole unit?
    Service manual is here: https://cdn.badcaps-static.com/pdfs/...d2917e4a88.pdf
    • 32055
    get a big cap,
    something like 1000uf 25v and jam it across each of the voltage rails till it effects the hum.
    • tony359
      • Oct 2018
      • 287
      That's a good idea, thanks.
      Meanwhile I determined that all the other 100uf/4V caps have ALL died and when I went to check a 220uF and a 100uF/16V, they also died so the board needs a full re-cap regardless.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5401
        • New Zealand
        • Electronics and computer repair
        Sounds like all the capacitors are just gone, yeah.
        What brand are they?
        -David VanHorn
        • tony359
          • Oct 2018
          • 287
          I’m not sure, I don’t recognise most of them, they’re SMD.
          the only ones I recognise because they have the Nichicon logo on them, are good - surprise surprise 😂
          • Agent24
            I see dead caps
            • Oct 2007
            • 5401
            • New Zealand
            Ah, yeah something about SMD electrolytics, they just don't seem to last very well. I wonder if the oven reflow damages them more than leaded capacitors that go through wave soldering instead.
            -David VanHorn
              • 32055
              they are just too damned small to last long.
              i try to replace them with tantalum caps usually.
              • tony359
                • Oct 2018
                • 287
                the 806 is also probably from the capacitor plague time - or shortly afterwards. The board is also the hottest of the lot, at the top of the unit - obviously no fans (unless the amp is about to go on fire), no heatsinks so those caps have a tough life.
                Given that the only "branded" caps I could identify look perfectly fine, I'd be more inclined to think that Onkyo cheaped out on some caps. Maybe... intentionally? who knows
                • tony359
                  • Oct 2018
                  • 287
                  Update. I eventually re-capped the "HDMI" board entirely, every single cap I tested on it was bad.
                  Unfortunately the noise is still there, unchanged. So let's assume it's not the HDMI board and it's not the amplifier board as it's quiet if I unplug the inputs.
                  I will have a look at schematics but how do I trace a buzzing noise with a scope when it's so low I can barely see it on the signals - but it's pretty obvious on speakers? I'd imagine mains buzzing noise is mostly coming from badly filtered rails, right? I mean, there is no other way, right? So I'd imagine I want to look at every rail generation and check the caps?
                    • 32055
                    if it's 100hz then it's rails
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5401
                      • New Zealand
                      Well, are you able to test that 10,000uF capacitor for ESR, capacity, etc?
                      -David VanHorn
                      • tony359
                        • Oct 2018
                        • 287
                        stj
                        yes it's 100hz.
                        Agent24
                        I will test them better but in circuit they did test ok. The thing is that the 12VHDMI is then further regulated once or even twice so I doubt that is my issue.
                        I had a look at the schematics, I will begin from the transformer, follow the various rail generation, check them with the scope and check the caps with my ESR meter. I will also check the standby voltage, you never know it's just sitting there in the background injecting noise into everything
                        Thanks so far!
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5401
                          • New Zealand
                          It looks like this thing has two different 12v rails??
                          One from bridge D4004 and C4007 which generates +12VHDMI and one that comes from another bridge, D4009 and C4013.
                          So there are two 10,000uF capacitors? Did you measure ripple on the correct one?
                          There's also what seem to be snubber capacitors across the bridges, maybe, C4012 and C4003. both 330nF capacitors. If one of these went open or low value it might cause noise problems.
                          Or maybe something in the preamp sections are causing the noise. I notice most of the opamps are powered from +/-12V rails that are themselves derived from +/-15V rails, which come from +/-22V rails that tap off the main winding that feeds the power amp. See D5601 on Page 25. Are C5661 and C5662 OK?
                          This +/-22V then goes to Q5670 and Q5671, which are 7815 and 7915 regulators. Check the capacitors around those, too.
                          -David VanHorn
                          • tony359
                            • Oct 2018
                            • 287
                            I checked the ripple on +12VHDMI, I believe it was 500mV which I feel it's a bit too much but that +12VHDMI goes through multiple regulations and the resulting voltages are all good. I checked C4007 in circuit from the +12VHDMI and it was indeed reading good values. But I will look into that again, including the other voltages coming from D4009.
                            Thanks, I'll take a look. In any case, I guess I want to check all the main rails (the two +12V) and if those show ripple, I can look into why that happens.
                            One question: would a SINGLE 10000uF capacitor be able to provide a very linear voltage? I'd imagine that's a rough rectification for voltages which will then undergo through further regulation, right? A 3.3V regulator won't care if the 12V input has 2V ripple, right?
                            I think this might be it! I was looking for the voltages powering the ICs dealing with audio and op-amps, thanks for finding it for me. It's interesting to see the cascade of components here! I will certainly check that path, I have a feeling that that is my problem.
                            Thanks so much for taking the time to study the schematics for me!
                              • 32055
                              very wrong.
                              the regulator would need to constantly ajust the output from the feedback and it has a response delay.
                              • tony359
                                • Oct 2018
                                • 287
                                I kind of suspected that, though is that a thing for 50hz as well? I thought it might just be an issue with higher frequencies.
                                  • 32055
                                  depends on the regulator and the caps surrounding it.
                                  • tony359
                                    • Oct 2018
                                    • 287
                                    Agent24
                                    Bingo.
                                    +15VA was heavily rippled, the cap on the +22 line was dead. Because... Onkyo in their infinite wisdom installed the bridge rectifier UNDER it **AND** it is an 85C cap. What would possibly go wrong. -15V is ok but I am swapping the -22V cap as well to be safe.
                                    I don't have a replacement (schematics say 35V, I found a 50V installed, I'll go with 50 to be on the safe side) but it's clearly the issue.
                                    Click image for larger version  Name:	SCR-20260131-qtoo.png Views:	0 Size:	1.26 MB ID:	3815408
                                    Thanks so far!
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5401
                                      • New Zealand
                                      Any capacitor can provide a very stable voltage.... at no load.
                                      There will always be some ripple with a load.
                                      It is the circuit designer's job to size the smoothing capacitor correctly given the load required from it, and minimise the ripple to be acceptable for the load in question.
                                      The transformer also must have enough power to keep up with the load as well, ripple will also increase if the transformer is too small.
                                      Agent24
                                      Thanks so far!
                                      Yeah, that looks like it'd cause problems for sure.... What a great design....
                                      Put a really good quality capacitor in that spot!
                                      -David VanHorn
                                      • tony359
                                        • Oct 2018
                                        • 287
                                        made my usual repair video on this unit, this is part 1, the buzzing noise is explored in part 2, where I also mention this thread 🙂
                                        I
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • ezenia
                                          Gigabyte B450M S2H POST/boot issue
                                          by ezenia
                                          So I got a faulty Gigabyte B450M S2H motherboard off eBay. It was listed as having a potentially faulty CPU socket. When I got the board, I went straight to checking the CPU socket under a microscope with the plastic cover removed to verify if it was actually damaged. None of the pins looked broken or damaged.
                                          So I started troubleshooting the board to see what's actually wrong. The 1st issue I found was there was 0.7V at the power button header. I found the cause was the 6-legged ESD chip that was next to the header. So I removed the chip which brought 5V back to...
                                          04-19-2026, 03:20 PM
                                        • GraphicMan
                                          Pioneer A-205 faint noise/hiss issue
                                          by GraphicMan
                                          as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
                                          what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
                                          out of curiosity what does that mean?
                                          thanks
                                          05-19-2024, 11:45 AM
                                        • stvhop
                                          HP1955L Buzzing noise & interference
                                          by stvhop
                                          Hello, This is my first post so please forgive me if I miss out some vital info.
                                          I have a problem with my HP1955L monitor from 2005.
                                          The first thing to say is that it is still basically working, ie the picture is fine.
                                          However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                          The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                          11-07-2020, 07:13 AM
                                        • ezenia
                                          ASUS ROG STRIX B450-F GAMING REV 1.01 - USB Overcurrent Issue.
                                          by ezenia
                                          Bought an ASUS ROG STRIX B450-F GAMING REV 1.01 off eBay. Seller said fault was board wouldn't POST and was stuck on CPU LED (and occasionally VGA/DRAM). When I tested the board, it actually does POST. However, it complains about a USB Overcurrent issue and shuts down in 15 seconds.
                                          Work has been done on this motherboard already. They removed the audio codec, a chip labelled U31U3 on boardview and some ESD diodes/SOT23's near the USB ports. It appears they tried to resolve this overcurrent issue and weren't successful. I did my usual resistance checks on the 24-pin connector and found...
                                          06-19-2026, 12:07 PM
