Bose 321 Gs Series II DVD hum
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5080
    • US
    • computers, electronic stuff
    My customer hasn't had this hooked up in a very long time. He wanted to get his LG tv on it (on toslink) and I get a 60hz hum no matter what input, no matter what volume, the hum remains the same volume (though does turn off on mute)
    I took the subwoofer home and it has really only one cap (also a very small one), a large nichicon on the power board. Think it could be the main unit? All RCA analog connectors are disconnected.
  • mon2
    • 16811
    https://www.eevblog.com/forum/repair...ing-60-hz-hum/
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5080
      • US
      This isn't intermittent. No RCA connected, this is on spdif. Also, the hum stays at the same level no matter how high the volume is, so I don't think it would be the power supply side of things. I've seen that happen before and when it does the hum usually increases with volume, here it's not.
        • 32068
        it could be the main filter cap, but i would expect that to be 120Hz.
        so also check all the rectifier diodes for leakage.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5080
          • US
          It has a single rectifier. Single Nichicon VT. Though I'm wondering if R10 didn't get too hot, of if it's just that color
            • 32068
            the resistors are fine,
            but - THE BOARD IS CRACKED!
            it also shows signs of getting very hot on the underside.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5080
              • US
              Is the crack around those two transistors? Yeah let me look at the underside
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5080
                • US
                I can't see the crack, here is a close up of the board burning but I see no component under the board that would be causing it to get hot from the bottom, only the top.
                Yeah I messed up my previous (deleted post). I assumed it was synched to my nas from the DCIM folder, but my magnifying glass app has a separate folder which was never snyched to my nas (it is now)
                I have a lack of diagnostic equipment. I'm tempted to go for this https://usavshop.com/products/Replac...fer-p639819992 (edit 2: oh shit that's for a series I)
                  • 32068
                  look at the bottom near the written-in date code.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5080
                    • US
                    ohhhh, where that screw is right? I think this is a single layer board, could that really cause this?
                      • 32068
                      depends how far the crack goes,
                      i can only see to a heatsink.
                      • R_J
                        • Jun 2012
                        • 9775
                        • Making Money
                        Here is a picture of the trace side of the board, looking at where the crack is on your board it looks like at least two traces are broken, someone marked them red and black
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5080
                          • US
                          I'll take the board off and look under
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5401
                            • New Zealand
                            • Electronics and computer repair
                            I see other areas that could be cracked too. I would very carefully inspect the board all over for cracks and broken traces.
                            -David VanHorn
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5080
                              • US
                              bottom looks...pretty bad
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5401
                                • New Zealand
                                Hard to see much with all the flux residue. Looks like it might have been damp to turn white like that... or cleaned incorrectly at the factory...
                                -David VanHorn
                                  • 32068
                                  that is what we in the trade call "a fucking mess Click image for larger version
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5080
                                    • US
                                    Should I clean it with isopropyl?
                                      • 32068
                                      clean it with something!
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5080
                                        • US
                                        There is a vent right under the board, but the customer says it was never exposed to any moisture on the floor. I'll get some alcohol pads and clean it, also likely will use some 60/40 solder+flux on some of these concerning joints
