Cassette player dropouts
  • Tom41
    • Oct 2005
    • 336
    • England
    I have an old SONY 'boom box' style cassette/cd/radio unit that's developed an annoying issue. When playing tapes, the audio randomly silences for a short time then comes back. There doesn't seem to be any pattern in the silence frequency or duration - I've had silences that last a split second, and others that last several seconds!
    The problem is definitely with the cassette player, not the cassette. When it silences, if I wind back the cassette and listen to the same point again, I hear the audio as it should be. Also the CD and Radio don't seem to be affected by this issue.
    There are no crackles or anything, so I doubt it's any of the signal wires. It's as if the amplifier is momentarily cutting out then coming back on. Any ideas what might be causing this?
    I'd post a sample of the problem happening, but WAV and MP3 files can't be attached...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Cassette player dropouts
    Could still be loose connection somewhere. Does tapping\lightly hitting it cause the fault to appear or go away? Check any mode selection switches for bad solder joints\dirty contacts. Note these may switch power and not audio signal, which would account for no crackling.
    Signal tracing with scope or external amp should find the problem fairly easily.
    -David VanHorn
    • Towncivilian
      • Jul 2014
      • 22
      • US
      Have you cleaned the transport (heads, capstans, pinch rollers, tape guides) using 91% isopropyl alcohol and a Q-tip?
      ASUS P8Z77-V LK, i7-3790, 32GB DDR3-1600, GTX 750 Ti, 256GB 840 Pro & 2x1TB / 1x2TB, Creative SoundBlaster ZxR, FSP Aurum S 400W
      abit IP35 Pro, Q9300, 16GB DDR2-800, GTX 750 Ti, 128GB 840 Pro & 1TB WD Blue, Corsair CX430
      HP d530 CMT, P4 EE 3.2ghz (with modded BIOS for correct microcode), 4GB DDR-400, ATI 9600XT, X-Fi, 80GB Velociraptor, 500GB WD Blue, XP SP3, Sony SDT-9000 & Seagate CTD-8000 DAT drive for ripping audio DATs
      abit BX133-RAID (recapped + SMD caps installed in processor socket), PIII-S 1.4ghz Tualatin, 768MB PC133, FX5600, SoundBlaster AWE32, 40GB Deskstar, Windows 98SE
      Depeche Mode Live Wiki
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Playback head may need de-magnetising
        • SteveNielsen
          Retired Tech
          • 2327
          Dirty heads and tape path will not produce that symptom, neither will magnetized heads. Most common causes would be bad switch contacts, broken wire, bad solder joint, or failing component.
          • Towncivilian
            • Jul 2014
            • 22
            • US
            Nonetheless, thorough cleaning and demagnetization is a good idea if it hasn't been done fairly recently. Use a wand-type demagnetizer if available over a DC powered cassette demagnetizer. Switch & potentiometer cleaning is a good idea too; see this guide for details.
            • SteveNielsen
              Retired Tech
              • 2327
              Most definitely cleaning and degaussing should be done anyway, especially after working on it. It is not going to fix the problem though.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                Yeah, magnetized heads or misalignment will make the audio sound like crap but I can't see it causing random dropouts, unless you have some *severe* transport damage, in which case you're going to get tape munching etc instead.
                -David VanHorn
                • Tom41
                  • Oct 2005
                  • 336
                  • England
                  Ok, some further information. I managed to make a recording of the dropouts happening (can't post it here, as it won't let me attach an MP3). You can probably see the two gaps caused by the cassette player, and I assure you there is no gap in the music at that point on the tape. Looks to me like an amp problem - the sound abruptly cuts off, remains silent then quickly fades back in. Could it be the caps? Doesn't seem to be affected by moving the unit around or tapping it...
                  Also there are no mechanical switches to get dirty on this. All the switching is done electronically; pressing buttons to select radio, tape or CD. Even the volume control and tuning is digital.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    I doubt it's a main amp problem if you say CD\Radio etc work without issue.
                    You may be able to compress the file in a ZIP archive to upload it, or use something like dropbox... although probably not necessary.
                    Unlikely to be capacitors I think, audio equipment like this doesn't typically use an SMPS so you don't have typical badcaps symptoms... that said capacitors in audio can go bad (usually dry out from being old) and you get hum in the audio.
                    Best thing I think to do here is signal tracing, find out at what point in the signal path the audio starts dropping out. Easy if you have a schematic, but not too hard if you don't.
                    Start at either end and work your way along... might be easier to start at the tape head and go from there. From there it would go to a preamp circuit first, then to maybe some EQ circuit, through input switching and to the main amp. Just go through the whole thing and find at which point the signal stops at the same time the output goes silent.
                    Obviously this will take a bit more time since the thing is not totally dead, you have to wait for the signal to die before you can verify if the point you are testing is OK or not..
                    If you don't know how to do this, give us something to go on to help you... post model numbers, photos if you have them.
                    -David VanHorn
                    • R_J
                      • 9535
                      If the cassette deck is also a recorder the playback/record switch can become oxidized over time due to lack of use, cleaning it should help. its located inside and activated when the record button is pressed.
                      Its used to switch the head from record to playback.
                      It might look something like this one...
                      • mikey5791
                        Sony CFS-5000S radio cassette player no FM reception
                        by mikey5791
                        Hi forum members,
                        In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                        Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                        I opened the casing inside and checked for any dry solder, burned component or loose wires...
                        02-24-2023, 03:48 AM
                      • shelby5041
                        clock radio / radio lifespan?
                        by shelby5041
                        hi
                        ive got a modern digital clock radio approx 15yrs old
                        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                        it uses very little power just a few watts i would imagine that may have something...
                        09-14-2024, 03:30 AM
                      • slothen92
                        Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
                        by slothen92
                        Hello
                        Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
                        I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
                        On the body of the IC it says: “LF33AH GK133544”.
                        Does anyone know where to find this part or a replacement for it?
                        Cheers
                        04-09-2025, 08:30 AM
                      • provider10
                        nad 6050c cassette player
                        by provider10
                        Hi
                        I don't know if I can ask this. Does any member who might have a scrap NAD 6050 cassette player as I am looking for the plastic base that the heads fit on
                        Regards
                        James
                        11-25-2024, 08:36 AM
                      • UserXP
                        Vintage SONY Digital Clock Radio ICF-C12W no audio
                        by UserXP
                        Dear all,
                        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                        My question is, do you know of this brand of capacitors and how bad are...
                        07-21-2025, 08:35 AM
