Mackie SRM450: 120hz hum with no signal from audio input...
  • DJDoubleBass
    • Jul 2014
    • 6
    I'm working on a 2-way 15" powered speaker: Mackie SRM450.
    At a show, it slowly lost volume until it stopped working. Opened it up: blown fuse. Threw in another fuse, turned it on and immediately blew it as well.
    Tested both rails (one for high pass and one for low pass) and pretty much the entire low pass rail had shorted rectifiers and transistors.
    Swapped the entire blown rail along with the 1/4 watt resistors on the low and high pass sides (probably overkill) as well as all of the larger resistors connected to the rail. Also swapped the (4) 6800uf 50v caps in the power section.
    Now when it powers on it doesn't blow the fuse, but a loud bassy 120hz HUM comes through the speaker, with no control over the volume from the gain knob. I can't get any signal coming from the input section either. I double checked the chassis grounds to make sure the connections were nice and tight.
    Also, when I turn it on it POPS with the green power indicator LED turning on. Soft turn off though.
    Any ideas or advice on this would be VERY much appreciated.
    Here's the service manual with schematics:
    http://www.eserviceinfo.com/download...ie_SRM450.html
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Mackie SRM450: 120hz hum with no signal from audio input...
    Could be AC hum not being filtered properly. Verify you replaced the caps polarity correctly. Couldn't download schematic. My system abit slow today. Look at Output Transistors or ICs. Measure the VCC to them are correct.
      • 31289
      if there is a pair of smoothing caps after the power rectifiers then start there.
        • 31289
        on page6
        check the 2 rectifiers and the 4 6800uf caps
          This is BI-AMP powered speakers, so if the bass amp is not working (it blew up as indicated on post 1), I would expect that the tweeter amplifier will be working and putting out sound, unless the Tweeter (HIGH-FREQ. AMP) also failed. I would check all the output voltage on page 6 to make sure they are present with correct voltages as shown. I would also check all the works that have been done to make sure the correct parts are used and installed properly.
          BTW, the woofer amp is Class-G power rail switching set up type.
          • DJDoubleBass
            • Jul 2014
            • 6
            Awesome! Thanks for the responses everybody. I'll do all of the above and report what I find out.
            • DJDoubleBass
              • Jul 2014
              • 6
              Referencing page 6 of the schematic I posted, I get these results:
              45v- is: -46.3v actual
              45v+ is: +46.3v actual
              80v- is: -93.6v actual
              80v+ is: +93.5v actual
              15v+ is: +14.2v actual
              15v- is: -14.2v actual
              I've got the 2 main rectifiers, "D55" and "D56" in the mail, as well as the 4 filtering caps near the 15v + and - (C157, C158, C156, C165).
              Hopefully that'll solve this problem. I'll keep you posted on my progress. Thanks again for your responses.
                • 31289
                why not just test the old ones?
                • DJDoubleBass
                  • Jul 2014
                  • 6
                  I get mixed readings with the old rectifiers, and the capacitance function on my multimeter simply doesn't work :-\
                  So while I work on getting a new meter and the parts are only a few bucks anyway, I'll just shoot for replacing them.
                  • dj_ricoh
                    • 2073
                    • uk
                    you can test them with Ohm settings from the meter.
                    ofc if that is working to.
                    • DJDoubleBass
                      • Jul 2014
                      • 6
                      I mean, of course you can test a cap with the ohm setting to see if it's open, but can you test for it's value?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        120hz is almost always bad filter caps.test with esr meter or replace.
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          Also heavy load caused by a bad amplifyer.
                          My pc
                          CPU : AMD PHENOM II x4 @ 3.5Ghz
                          MB : ASUS M4A89TD PRO USB3
                          RAM : Kingston ValueRAM 16gb DDR3
                          PSU : Cooler Master 850W Silent Pro
                          GPU : ATI Radeon HD 6850
                          • PalGStudio
                            • Mar 2018
                            • Brazil
                            _________________________
                            Hi, I read about your problem, and at the moment I have the same problem, SRM 450, noise at 120Hz! Could you let me know how you solved this problem?
                            Thank you in advance!
                            palgstudio 03.18
                            • ugamazing
                              820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                              by ugamazing
                              So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                              1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                              2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                              04-10-2024, 08:06 AM
                            • CoinCoin88
                              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                              by CoinCoin88
                              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                              09-15-2025, 03:36 AM
                            • pfl
                              Mackie Thump 15" powered loudspeaker
                              by pfl
                              Hello Everyone.
                              The issue with this audio device was a very low bass level ; tracking the bass signal path on the preamp module i discovered a missing component (resistor R98) on the inverting input of op. amp U14 (allegedly active low pass filter) (see picture).
                              I put a 1k resistor but now R/L passive speakers sound level is too low compared with bass level ; i guess resistor value is wrong
                              Can someone tells me what's the correct value of R98 on preamp pcb
                              or
                              can someone provide me with schematics / service manual
                              pierre...
                              06-23-2025, 06:40 AM
                            • Xristakis795
                              samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
                              by Xristakis795
                              hi to all
                              i have the above model ue40d5003
                              the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
                              when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
                              when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
                              Can you tell me from your experience...
                              02-09-2023, 03:17 PM
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
