MOTU TRAVELER MK3 AUDIO PROBLEM
  • falcontech
    • Oct 2013
    • 475
    • italy
    Good Afternoon
    I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip, so much so that in desperation I also updated the firmware so communication between the computer and the card occurs, at the time of start-up the card also appears among the peripherals in the audio section, on the side I have a switch that lets me choose whether to power it via the firewire bus or the external power supply, when the problem started to appear it was connected via power supply, the problem started to appear after sudden power failures due to bad weather, initially after a few turns on and turn it off and it was fine again, then it abandoned me definitively, even powered only with firewire it has the same problem. the capacitors all seem good, near this switch I have a resettable fuse from littlefuse, I would start from there since in the past these apparently working fuses have given me a lot of trouble with other equipment. I hope someone can give me a tip before sending it in for assistance thanks
    N.b. the most detailed and clear photos are taken from a blog of a guy who repaired the firewire chip by making an overview of the rest of the board and its components, if it were useful I can put the link
  • CapLeaker
    Leaking Member
    • 8300
    Hmm. I wonder if it can’t sync / lock phase clock? That results in no audio as well. Would I count the FireWire chip out yet? No! Not convinced on that yet.
    • falcontech
      • Oct 2013
      • 475
      • italy
      What do you recommend? Can I do some tests?
      • CapLeaker
        Leaking Member
        • 8300
        You’d need an oscilloscope and check if the clocks are in sync or even missing altogether. It’s not an easy task.
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • tk5ep
          Stanmore JN3018 audio problem help request
          by tk5ep
          I've been given a non working Stanmore JN3018 loudspeaker.
          The power supply part works normally, I have all voltages on all chips. But no sound is coming out.
          I tried to track the audio signal from the inputs to the loudspeaker.
          Unfortunately, it's not easy, as most signals are PWM. But the analog part is working, and I can track the PWM at the inputs of the TAS5508c.
          At the TAS5508c output, I only have pulses which I can find on the input of the final amplifier TAS5342a.
          Can somebody help me to resolve this problem ?
          02-16-2025, 10:46 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • PapaFi
          Teac AG-D9260 AV Receiver Audio Problem
          by PapaFi
          After turning ON the unit, as the 2nd relay clicks. No audio response even radio or from dvd player. During vol adj from remote/manual adj as the vol increased there's a loud "tic" sound from the speaker. Even up to max vol still no audio. As you played the adj +/- from remote/manual along with the loud "tic" sound. All of a sudden the audio turned ON but uncontrolled vol even +/- adj. looks the audio is stuck on its level of vol. Even max/min audio level is the same (but the "tic" sound still there as the adj from min to max and vice versa and of course as you reached...
          08-26-2020, 04:04 AM
