Yamaha RX-V563 - any hope?
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Hello. I have a Yamaha RX-V563 with a dead DSP board in it. Previous owner had a plant sitting on it, and when they went to water said plant, water was accidentally spilled inside the receiver, right on top of the DSP board. So it is likely that the main processor is now fried, and possibly some other logic. Rest of it (amp, PSU, transformer, etc...) seems fine tho.
    Right now it clicks the relay on standby board and that is it. No display, no lights.
    Just out of curiosity, I replaced C402 (0.01uf film cap) with no results.
    Any hope for this machine? Is there a way to get this to work as just a standard stereo amplifier? OR I could just scrap it and make new amplifiers with STK chips from it, but my laziness gets in the way there.
    Service manual:
    I can put text here?!
    • 31214
    Re: Yamaha RX-V563 - any hope?
    have you cleaned it wih isopropanol and looked closely for crosion or burns?
      I would check low voltage regulators on the board. A DSP board is likely to use 3.3V & 1.8V/1.5V/1.2V supplies, so check if they are present.
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        I don't think there was corrosion, and there certainly were no burns. I can post a pic of DSP board later.
        As for voltages, I don't remember if DSP got it's voltages from regulators on it's a own board or from the PSU board, will check later.
        For anyone who is interested in helping, first above thank you, and second, please downlad the service manual from my first post. It has PCB and schem. For all board incl. DSP.
        • DJduck
          • Dec 2012
          • 229
          • Estonia
          Here are some readings from connectors to DSP board.
          DC volts, black probe on ground
          CB82:
          PRV2 1.88V
          THM 0.86V
          XMP WR 0V
          PRY 3.26V
          /PDET 3.15V
          /RESET 3.27V
          CB81:
          IG -0,52V
          +5I 4.47V
          +5XM 5.01V
          +5D 5.02V
          DG 0V
          DG 0V
          DG 0V
          +3.3D 3.31V
          HG 0V
          +3.3H 3.27V
          +6.3VH 6.28V
          +5VSB 5.02V
          • DJduck
            • Dec 2012
            • 229
            • Estonia
            I looked around a little more and there are no voltage regulators on DSP board. It gets its power from power supply board marked Operation (2) in service manual.
            How likely am i to get this thing to work? As far as I know the DSP is simply not powering on, therefore no other thing powers on. Or is something else wrong? Hmmm....
            I have fixed analog (mostly vintage) amplifiers before but none of yhis damn digital BS.
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              Well, all the power supply voltages seem to measure okay, so it simply looks like the DSP board has genuinely kicked the bucket. And I have FAR too little knowledge about digital audio and digital stuff in general to mess with that board.
              I paid 10€ for it, and I think I got a good deal, this thing contains a goldmine of good parts. STK chips from this receiver will be used to build a new amplifier and power supply electrolytics are going straight into my Samsung L4A.
              If anyone has any more ideas on what to measure or replace, let me know. I fill wait till tonight, and the this receiver is going to be stripped for parts and then it's off to the scrapyard with this.
              • DJduck
                • Dec 2012
                • 229
                • Estonia
                I see a few slightly bulged Nichicon VR(M) capacitors near STK chips, but i doubt changing these would make any difference? They are 10v 100uf.
                • DJduck
                  • Dec 2012
                  • 229
                  • Estonia
                  Yep,this thing's DSP is absolutely toasted. It can't even run in protection cancel and diagnostics mode. Teardown time!
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Try getting a broken unit from Ebay and use the DSP board in your receiver.
                    I had a Harman Kardon AVR1700 with spilled fluid in it and one third of the board it was super corroded, rust all over. One pin from one of the chips was completely corroded off(missing). I have soldered another wire there, cleaned the whole board off and the receiver turned on and all the functions worked as they should, except I couldn't get any sound out of it.
                    I have managed, to pick up another broken receiver, for $40 with a remote controller and swapped the boards and all it was OK. The remote alone, it's around $45 on Ebay.
                    • DJduck
                      • Dec 2012
                      • 229
                      • Estonia
                      Well the problem is that this is a pretty uncommon receiver. Guy who had it before me had been hunting one down for about a year with no luck. He looked on ebay, forums, local repair shops, etc... with no luck.
                      I already tore it to pieces because I don't have room to keep broken stuff, I have barely enough room for my working stuff. I usually sell what I fix but I keep a few items every now and then, and I have stacks of stuff.
                      As for the Yamaha's STK chips and other parts, I will be building a new amplifier soon and I might post it in this forum as well.
                      • lti
                        • May 2011
                        • 2557
                        If you don't need the DSP functions, you might be able to make an input switching and volume control circuit controlled by the front panel or the remote (if it has a remote). The video inputs might be more difficult to switch between, but the audio part won't be too hard. The hard part would be programming a microcontroller to control everything.
                          master hoarder
                          • May 2008
                          • 12175
                          ^ Or better yet, just take out all of the digital circuitry out and simply wire it like a classic 70's/80's amplifier with everything using mechanical buttons and a real potentiometer for the volume control. Ugh, I can't stand that optical sensor crap on modern hardware. Maybe add analog EQ or tone controls too. Simplicity at its finest.
                          • bhatti76
                            • Jun 2014
                            • 7
                            • australia
                            I got Yamaha RX-V563 not turning ON apparently no sign of burning but only i can see heat marks on the regulator IC on the secondary board where AC DETECT signal coming from. regulator IC giving out put 3.2 volts.
                            on transformer all AC voltage there except no voltage on yellow cables which connects to secondary board pin AC-6.
                            can any body help me in this regard.
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              Or just buy a Marantz. Gigity
                                master hoarder
                                • May 2008
                                • 12175
                                But I really like my Yamaha RX-830 Natural Sound already .
                                  20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                  I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                  At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                  Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                  04-09-2023, 08:04 PM
                                • Ugur87
                                  MacBook Air M4 A3240 Brand New Water Damage no Image
                                  by Ugur87
                                  I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                  08-28-2025, 01:09 PM
                                • edugimeno
                                  Stagg sms12p audio amp has water damage
                                  by edugimeno
                                  Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                  I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                  There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                  There is only one signal wire connecting the first boards...
                                  05-24-2025, 06:00 AM
                                • sanalelevenstar
                                  Yamaha RX-V485 Wn9711 Update
                                  by sanalelevenstar
                                  Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                  I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                  I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                  12-04-2024, 04:32 AM
                                • RetroComputingGrotto
                                  Water Damaged Toshiba 48L1435DB
                                  by RetroComputingGrotto
                                  I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                  The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                  10-07-2024, 08:23 AM
