Yamaha RX-V659 the processor does not run but looks alive.
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Hello everyone.
    I am facing a problem with the processor of this amplifier, in normal condition it is not oscillating, when I set the reset pin low (normally high) the processor is oscillating normally after disconnecting the reset circuit , when releasing it comes high again and the processor stop oscillating.
    All power lines looks ok, VSS also, I am not so clever in processors and micro-controller topics, but I have solid experience in electronic repairs.
    The schematic can be found here on the website of Electrotanya https://elektrotanya.com/showresult?...a=All&kat2=All.
    Thanks for you help.
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    I finally found what was the problem, that is weird. I found a non polarized capacitor , C654 which was normally 22nF which dropped to 4.5nF which caused that the power could not insure to supply the correct tension for the chip IC652, a cmos 4013. After replacement with a 400V equivalent , everything works normally again. That was the reason the reset circuit was dizzy , also the relay was not working.
Name:	Yamaha RX-V659.png
    • sanalelevenstar
      Yamaha RX-V485 Wn9711 Update
      by sanalelevenstar
      Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
      I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
      I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
      12-04-2024, 04:32 AM
    • jjne
      Yamaha RX V675 sound issues
      by jjne
      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
      At first I thought it was either a speaker relay or the DSP, but I don't think...
      06-24-2025, 07:01 AM
    • AlexVG
      YAMAHA CLP-550 without of sound
      by AlexVG
      Hi.
      I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
      I have replaced all green marked elements, but it gave me nothing.
      The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
      But it is custom YAMAHA's chip, and I can't find any information about it.
      Maybe somebody came across with the same issue?
      Any information will be very useful. I will be very appreciated.
      Thank you....
      06-08-2025, 09:29 AM
    • hemant_2222
      Yamaha RX-A1020 full dead
      by hemant_2222
      Hello Everyone,
      Greetings!
      It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
      09-14-2024, 11:25 AM
    • sanalelevenstar
      My yamaha Rxv-485 showing version error
      by sanalelevenstar
      My friends Yamaha RXv-485 receiver has stopped communicating on network and Bluetooth, we decided to make a firmware update from USB stick but after a while it comes up with the message "unknown".... Its the latest 1.87 version we are trying to load and it seems like the is no firmware in it at the moment as it does not state the old version ?
      Any ideas how to resolve this issue?​
      07-31-2024, 07:11 AM
