Marshall Stockwell 2 BIN file for Bluetooth CHIP
  • zakiyy
    • Jul 2012
    • 13
    • mauritius
    Hello. i wanted to know if someone have the bin file for a Stockwell 2 bluetooth chip. everytime you click on the bluetooth button the set switch off.
  • Kiwoz
    • Dec 2024
    • 9
    • Italien
    Hey! Did you manage to get the Bios File? Have the same problem. Thank you.
    • malycinek
      • Mar 2023
      • 10
      • Poland
      Hello, I am looking for firmware bin file from mainboard. Anyone have?
      • Kaulitsa
        • Jan 2023
        • italy
        Same problem anyone can post the bin file?
        • yaso143
          • May 2021
          • 59
          • philippines
          anybody had a bin file of this device?
          • Kiwoz
            • Dec 2024
            • 9
            • Italien
            Here you go. This bin worked for me.
            • yaso143
              • May 2021
              • 59
              • philippines
              Thanks ill try this
              • Silviu2
                • Jun 2025
                • Cluj-Napoca
                Hi, i try this and now i don't have sound, any suggestion? i write directly on PCB. Is this a problem?
                • Bobo2025roby
                  • Oct 2025
                  • Italy
                  Hi, it is the Same file we can see in YouTube video by workshop freaks Stockwell repair video? It is 8.00mb? Tnks
                  • Kiwoz
                    • Dec 2024
                    • 9
                    • Italien
                    Hey, yes thats the same one.
                    • JBS Amalik
                      • Dec 2025
                      • United Arab Emirates
                      yes, that work for me.tnx
                      • linuxpower
                        • Oct 2021
                        • South Korea
                        thanks
                        • isloboda
                          • Apr 2026
                          • Ukraine
                          I think there may be two hardware revisions of the Stockwell II main board, and that the bin in this thread only works on one of them. Posting my findings in case it helps the people here who got a dead unit after flashing it.
                          **The two flash parts**
                          The bin attached in this thread is named for an **MX25L6436E** — a 3.0 V, 64 Mbit Macronix part.
                          My board carries an **MX25U6432F** — 1.8 V, 64 Mbit. Same capacity, different supply voltage, which means a different board revision. Mine is:
                          - Main board: LRMPS1301-0001, date code 20211213, silkscreen APEPS1301
                          - Control board: LFA113390-1201, date code 20181106
                          - MCU label on the large QFP: PS1301 V57
                          - BT SoC: Qualcomm QCC3007 (module marked WCB321000 / V16 / 75F5A4)
                          **What happened to mine**
                          A repair shop flashed this exact bin onto my speaker and returned it non-functional. Symptoms: no Bluetooth advertising at all, not discoverable even after a 7-second factory reset, no audio via AUX, status LED permanently red. Charging, battery indicator and all four knobs work normally.
                          I removed the flash and read it. Two independent reads, both byte-identical to the bin from this thread — same SHA-256. Including the **previous owner's Bluetooth pairing records** still sitting in the PS store: a phone name and a router SSID that are not mine.
                          That last detail matters. Every successful pairing writes to the PS store, and so does a factory reset. Those foreign records being untouched means the QCC3007 has not written a single byte since the shop flashed it. It is not merely failing to advertise — it has never executed.
                          **Other diagnostics, in case useful**
                          There is a UART console for the main MCU. On the solder side, look for silkscreen `.3V3 / T5-T52 TX / T6-T49 RX / T7-T50 GND` next to connector CN105. 115200 8N1. Mine outputs:
                          BootLoader Ver is 0x04
                          unPlug
                          TypC Ver is 10.22
                          Battery is connected
                          dsp boot start
                          dsp boot end & ok
                          Ma12070_Init
                          Ma12070_Init finish
                          Audio_Init
                          unPlug
                          So the MCU, the separate DSP, the Infineon MA12070 amplifier and the USB-C controller all come up clean. No Bluetooth activity anywhere in the log.
                          The flash VCC rail measures a stable 1.8 V, and it is gated by the power switch — so the SoC appears to have power. The chip itself is fine: it erases and verifies correctly.
                          **My theory**
                          The QCC3007's PS store contains board-specific hardware configuration — PIO mapping, DSP interface, control layout. If the bin in this thread was built for the earlier MX25L revision, flashing it onto an MX25U board would leave the SoC initialising against a hardware description that does not match, and it would hang before doing anything. That would explain why this file fixes some units and bricks others.
                          **Two requests**
                          1. Does anyone have a dump from a Stockwell II with an **MX25U** flash — i.e. a 2021 or later build, board LRMPS1301-0001? That is what I need, and I have not found one anywhere.
                          2. More useful for everyone: **if you have flashed this bin, could you report which flash part your board had, and whether it worked?** MX25L or MX25U, plus the board date code. A handful of data points would confirm or kill the revision theory quickly, and would tell future readers whether it is safe to flash their unit.
                          Happy to share full notes, more photos, or my own dump if anyone wants to compare. Thanks.
                          • Antoniogg99
                            • Aug 2026
                            • Estados Unidos
                            Este archivo funciona también para el chip MX25L6436F solo es cuestión de escoger antes el chip desde Asprogrammer, ya que funcionan con el mismo voltaje .
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • DynaxSC
                              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                              by DynaxSC
                              Hi
                              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                              08-04-2025, 12:20 PM
                            • Zilicon
                              ATS2835P Bluetooth Chip used in a Zealit Bluetooth speaker
                              by Zilicon
                              Greetings everyone, please I need help with the above Bluetooth module.
                              I was fixing a Bluetooth speaker that was dead, no sign of life. On checking, i didscovered the bluetooth chip ATS2835P got hot.
                              I bought a new ATS2835P, the bluetooth flashes red light faintly continuously.
                              Does this chip requires programming before it can work?...
                              07-05-2025, 02:54 AM
                            • testaccgta
                              Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                              by testaccgta
                              Hi, everyone!
                              I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                              I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                              09-01-2024, 08:24 PM
                            • Berun
                              HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
                              by Berun
                              Hello All,
                              I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
                              I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
                              I read the Chip on board 8 times (with power...
                              04-09-2026, 06:24 AM
