Yamaha EMX 512SC - Bad Limiter?
  • honeybadger0
    • Nov 2024
    I have a Yamaha EMX 512sc powered mixer that gets heavy use. Recently a new problem has arisen ... it seems like the L output is way more sensitive than the R and the limiter light for main L is flashing even at very low (below the 2 setting on the knob) levels.
    It seems to be across all channels and with different inputs. The speakers have been recently tested as well and do not seem to have any of their own issues.
    Has anyone else encountered this problem and could help me out?​
  • Phlox321
    Yamaha EMX 2000 Powered Mixer issue
    by Phlox321
    Hi All
    I have a yamaha emx 2000 powered mixer im trying to repeair.
    the problem is that theres no sound output on the right channel. Left channel works fine.
    Right channel has output when using the phono(headphone output) but not when going through the amplifier
    the left peak meters work but not the right
    the clipping light however does come on when gain is turned up same as left channel
    What i have done so far is make sure that the supply voltages are fine, which they are
    I found several cracked solder joints on the amplifier board which...
    10-19-2022, 11:45 AM
  • Bektronics
    Schematic Digital Audio mixer RCF type M18
    by Bektronics
    Hello dear audio friends.
    I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
    The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
    I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
    Thanks in advance if anyone can help me with this schematic.
    Of course, all information about this digital mixer and possibly references...
    07-24-2023, 06:40 AM
  • sanalelevenstar
    Yamaha RX-V485 Wn9711 Update
    by sanalelevenstar
    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
    12-04-2024, 04:32 AM
  • Longon
    Behringer Pro Mixer DJX-750
    by Longon
    Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
    08-11-2025, 02:17 PM
  • Thermaltake
    Power button on Behringer Xenyx 1204USB mixer dead ?
    by Thermaltake
    Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
    I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
    08-16-2022, 03:22 AM
