TDA2030A Audio Power Amplifier Question
  • RetroComputingGrotto
    • Aug 2023
    • 108
    My boss always says "the only stupid question is the one not asked" so at the risk of asking a stupid/obvious question I'm going to one any way...
    I've got a pair of speakers with an amp built in to them in for repair and on inspection I can see the TDA2030A amplifier ICs have blown (so I've ordered some spares which should arrive soon):
    My quesion is with regards to the white paste you can see on the TDA2030A and heatsink, I'm assuming this is just some thermal paste and if so is it a special kind or will the grey thermal compound that I have in the store cupboard that is used for computer CPUs be OK?
  • redwire
    • Dec 2010
    • 3912
    It's (silicone) thermal grease for better heat transfer from the IC to the heatsink. You can use CPU grease, the original has nothing special here. That white stuff is messy silicone and cleanup with IPA and Q-tips.
    Note the tab on a TDA2030 has power on it (-Vs) so it typically is insulated (electrically) from the heatsink. I don't see you having that (insulator and bushing) so the heatsink must have juice on it which is OK but can be a rude surprise.
    Newer IC's like LM1875 have the same pinout and can be dropped in as well. It has better protection if you keep roasting the 2030. The TDA2040, 2050 could also work.
      • 31434
      one shatterd chip happens,
      2 is a bit of a coincidence.
      check the circuit and make sure you dont have shorted output/damping capacitors or some fault causing the chips to be driven by AC.
        • Aug 2023
        • 108
        ​Thanks I'll bear that in mind for the future (I've added it to my repairs notes I keep in Microsoft OneNote).
        Is there any specifics I should look out for when purchaseing some white thermal grease or is any one from an electronics repair distributor (like the one in this link) OK?
        https://cpc.farnell.com/kontakt-chem...4?st=silicobne
        The capacitors were not very happy so I have replaced them already! They were both very swollen. Working in a school they keep these speakers on 24/7 as if they get turned off our helpdesk gets inundated with calls saying there is no sound in all the rooms as they are unable to operate an on/off button or switch. How a Teacher manages to operate their light switches, TV and microwave or air fryer at home is a mystery as they all have the same on/off button and symbol on them as the equipment at work!!
          • Aug 2023
          • 108
          I've just had a look on CPC's website and they sell 2 different LM1875 ampliers:
          https://cpc.farnell.com/texas-instru...?st=M18%20BH-0
          https://cpc.farnell.com/texas-instru...8489?st=lm1875
          The 25W one is cheaper than the 20W one by nearly 50% - I believe the TDA2030 is 14W so are either of the above a good replacement or would the 20W one which is closer to 14W be the better choice out of the two?
            • 31434
            buy the cheap one,
            the only difference in part numbers is the code for lead-free packaged.
              master hoarder
              • May 2008
              • 12182
              The above 2 links are not working for me - I get an "Access Denied" error. IIRC, this is the 2nd time I get this problem now with farnell. Looks like their website uses a shitty design where if links are viewed from a different country, it just doesn't work.
              With that said, instead of links, can you post the manufacturer part numbers instead? (These are usually the same regardless if looking up on farnell or Mouser or Digikey, so that way we can see what you are seeing.) As for the output power to the speakers, that is usually limited by the output voltage (and sometimes power supply power output rating.) If these computer speakers use a plain ol' AC line transformer instead of an SMPS, there's a good chance the transformer voltage will drop quite a bit under high power demand, thus limiting the output power that can go into the speakers even further. With that said, there may not be much of a difference whether your amp IC is capable of 14, 20, or 25 Watts. They are all class AB, so the efficiency will always be the same... thus the heat output will be the same too.
              Speaking of heat output (and heatsinks)... you can use any thermal compound to couple the new IC to the heatsink. CPU/GPU "gray" thermal compound is probably (usually) superior to the regular white silicone thermal compound. But in this application, it doesn't matter at all, because the average dissipated power by the amp IC will be relatively low. So any thermal compound will do. In fact, if the old IC wasn't physically broken like you show in the pictures, then you could have even re-used the thermal compound from the old IC, provided that it wasn't dry / chalky yet. I do that all the time when I'm lazy or "temporarily" fixing stuff (with some of those "temporary" fixes being years old now, LOL ).
                • Aug 2023
                • 108
                Here you go!
                • redwire
                  • Dec 2010
                  • 3912
                  It might be running the IC's in bridge mode BTL for the pair. Is this a stereo on mono thing. I would expect the speaker got roasted when the IC shorted. Kids cranking up music can do it.
                  I would get a pair of the best price LM1875 the noPb ones.
                    • Aug 2023
                    • 108
                    Cheers guys!
                      master hoarder
                      • May 2008
                      • 12182
                      OK, as we suspected, there's not much difference between the two, other than one being Pb-free. So just get the cheapest one.
                      BTW, it might be worth investigating the output voltage of the power supply in the speakers. Perhaps it was close to the absolute maximum rating limit of the IC, and that's one possibility why both may have blown.
                        • Aug 2023
                        • 108
                        Both ICs were replaced (along with the 2 large powerline capacitors which were swollen) and the speakers are now working coreectly.
                        I have another set of speakers in for repair (like busses they keep on coming) and they have similarly numbers AMP ICs:
                        Click image for larger version  Name:	20241111_133057147_iOS.jpg Views:	0 Size:	1.78 MB ID:	3504845
                        Click image for larger version  Name:	0002.jpg Views:	0 Size:	350.2 KB ID:	3504846
                        The speakers in question are Behringer which basically make a decent pair of speakers at a very good (low) price so even the same model of speakers can have different cable connectors in them for example depending on what the manufacturer could get the cheapest!
                        I'm going to assume the D2030A and V2030D are pretty much the same thing? Asumming this is correct, are the TDA2030A ICs I have also the same thing as they are all 2030 Amps - in other words, can I replace a suspect D2030A or V2030D with a TDA2030A?
                          • 31434
                          same thing, just a tacky rebrand.
                          those caps with the 4 point diamond are absolute shit btw.
                          replace them with panasonic low esr like FR or some rubycon ZL and they will sound better
                            • Aug 2023
                            • 108
                            Thanks that's what I was hoping. Both replaced and after PAT testing them, the speakers are now back in a classroom ready to be used.
                            Thanks also for the feedback on the capacitors, I do try and by Panasonic or Rubycon when available but I'm limited to places like CPC or RS Components and their minimum order cost before free delivery etc. - feedback like this is genuinely always appreciated.
                              • 31434
                              you dont pat test electronics - it can damage them.
                              you only inspect the cabling and any earth bonding to the chassis.
                              i have a thread or atleast a bunch of posts here about the PAT scam and how it is mis-interpreted.
                                • 31434
                                a quick follow-up.
                                if you have a transformer with an output of 18v for an amp - just an example.
                                and you hit it with 500v the transformer will hit the electronics with about 40v
                                use the full 2kv and you can use your imagination.
                                if the device has surge supressors in it they will break down and stop your tester or take partial damage and short out later on.
                                • Veyron7887
                                  Laptop overheating after replacement thermal paste
                                  by Veyron7887
                                  Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                  11-24-2024, 05:08 AM
                                • harp
                                  Metod for removing glued heatsink from fragile component
                                  by harp
                                  I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                  06-23-2025, 02:01 PM
                                • maxbers
                                  Asus ZenBook 14 UX425EA – Won’t Turn On After Thermal Paste Change
                                  by maxbers
                                  I’m new here and I’m trying to learn some board-level repair skills.
                                  I have an Asus ZenBook 14 UX425EA that won’t turn on after a thermal paste replacement. The laptop was fully working before the disassembly. I only removed the cooling system to clean the CPU and apply new thermal paste.
                                  Current behavior:
                                  • No normal power on
                                  • Battery only: the white power LED turns on for a few seconds, then turns off. No display, no fan activity. I must disconnect the battery or hold the power button for ~15 seconds to get the LED again.
                                  • AC only: the white
                                  12-09-2025, 12:29 PM
                                • Ven
                                  Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                  by Ven
                                  I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                  The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                  I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                  If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                  07-08-2024, 09:32 AM
                                • MrCommunistGen
                                  Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                  by MrCommunistGen
                                  My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                  I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                  07-12-2021, 05:11 PM
