Peavey KB100 popping and thumping with humidity
    Re: Peavey KB100 popping and thumping with humidity
    It is the compression indicator to show that the compression circuit (U1A/B, U7B, U2(87478 is an OTA (Operational transconductance amplifier): https://cdn.badcaps-static.com/pdfs/...323fc6188c.pdf, ) has kick in if the signal feeding the power amp section is too high.
    • macjedimatt
      • May 2012
      • 21
      So I have finally replaced all the capacitors and it doesn't seem to have gotten any better. It thumped a few times in the first minute or so of turning on. I hooked some tunes up to it and caught it in action on video: http://youtu.be/zjHkZr2dD54
      No combination of turning/pushing/pulling on the knobs seems to replicate it reliably. Also does it with no source connected.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        I wonder if there is a bad transistor or IC somewhere.
        Muh-soggy-knee
        • macjedimatt
          • May 2012
          • 21
          I did some more testing tonight:
          • Going straight into the PWR AMP IN = Clean with a couple faint clicks that could have been line noise.
          • Headphones on the PRE OUT = Heard thump in headphones and speaker
          • PRE EQ Patch in only = thumped, seemed to do it a few times also when messing with the EQ knobs.
          • Bypassing the reverb coil = still thumped.
          I've attached an annotated schematic with what I have tested so far. At this point, I feel like the main power amp is probably fine. I'm not sure if it is something in the EQ or maybe the +/-15V lines of the power supply. I have a DMM with a peak hold. Should I put that on the +/-15V lines and look for spikes? Could the transformer be going bad?
            Insert the blank phone jack into the Power amp in J4 (this will disconnect the line out signal from feeding into the power amp input section), then connect a Powered speaker line input to the J5 line out and see you do hear a thump from that line out, and see if still hear the thump from the internal speaker.
            It sounds to me the thump is from the preamp section.
            • macjedimatt
              • May 2012
              • 21
              Just put the meter on the 15v lines. -15 was -15.2 and pretty rock steady. +15 was 14.8 and also steady. Not sure if my meter just wasn't picking up the spikes though.
              • macjedimatt
                • May 2012
                • 21
                Confirmed. Signal patched in, headphones on the pre out, and a blank jack plugged into the pwr amp in. Thumped in the headphones. I think my neighbors like this test better :-) Now the question is, what the heck would cause this?
                • macjedimatt
                  • May 2012
                  • 21
                  Ok, just discovered that flexing the pan that the board is attached to is causing it... So it probably has a bad joint or damaged trace somewhere that I missed.
                    Might as well resolder all the connections and use good flux.
                    So now we have to start tracing backward from U6B output pin 7 back to U5A (since you use J2 and it still thump). So you replaced all those lytics caps C18, 19, 24, 39 in the signal path?
                    Check the DC offset at the pin 1, 7 of U5, 6 also.
                    BTW, the thump is really loud? and only when you it on, otherwise the amp sounds fine?
                    • macjedimatt
                      • May 2012
                      • 21
                      Yes. I'm going to have to get back to this tomorrow. 4AM comes awful fast. Thanks for the help so far!
                        At least you are getting close.
                        • macjedimatt
                          • May 2012
                          • 21
                          Finally got it all fixed! Last night I discovered that one of the small NP caps in the EQ circuit was the culprit. It had a bad solder joint. I found it by poking the board with a marker while listening to it through headphones.
                          Thank you for all of the suggestions!
                            Glad you found the and narrow it down to that section where U5 and U6 are. What is the designator of the cap? C??
                            • unimatrix93
                              Egg incubator humidity sensor replacement
                              by unimatrix93
                              My egg incubator humidity sensor kicked the bucket, I read open circuit on it with DMM even in the MOhm range.
                              So I started identifying this piece of crap and look for a replacement part.
                              This thing has 6 turns or black lines, while the one I found similar has more turns and has 33kOhm. ​
                              Based on the number of black lines, this one looks like the 23kOhm version of this thing, but I cannot find anything with this value on the local distributors.
                              I assume the 33kOhm wont work?
                              What do you guys recommend?...
                              05-15-2025, 08:10 AM
                            • otoluk
                              Auriol weather station humidity sensor
                              by otoluk
                              I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
                              I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
                              Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
                              11-06-2024, 07:57 AM
                            • diazald
                              Searching for a Peavey XRs schematic
                              by diazald
                              Searching for a Peavey XRs Schematic. A SMD capacitor with no values cracked on me. I have searched off and on for months with no luck.
                              Any help would be greatly appreciated
                              11-24-2023, 02:49 AM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
                            • roman-hartwig
                              Onkyo TX-NR828 - popping sound every 5 min
                              by roman-hartwig
                              Object: Onkyo TX-NR828
                              Problem: Popping noises in the right surround channel every ~5min
                              Service manual: available
                              After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
                              07-29-2023, 08:08 AM
