STK4392 pin out
  • Evets
    • May 2024
    • 28
    STK4392 pin out
    I seem to have spent a long time searching for a pint out diagram for an old STK4392 amplifier chip without success. Can anyone help?
  • redwire
    • 3912
    Have you tried google?
    • Evets
      • May 2024
      • 28
      That was my first search, I found some circuits using it but no explanations.
      • redwire
        • 3912
        https://datasheet.octopart.com/STK43...eet-104240.pdf is the main 2 pages, full datasheet is 6 pages.
        Explanation on how the IC works? Is that what you are after, or circuits? It is basically 6 transistors per channel, a simple 15W+15W chipamp.
Name:	STK table1.jpg
Name:	stk circuit1.jpg
        • Evets
          • May 2024
          • 28
          Thanks for the trouble you have gone to but I think you are assuming a level of knowledge I don't possess (I came here to try and learn). I was hoping for a picture of the chip with a legend for where each pin would go in the most basic circuit.
          • redwire
            • 3912
            Projects using the STK modules are using a PC board. That would be easier to start with.
            It's a whole family of modules with different power ratings- BUT the same pinout and circuit.
            i.e. STK4432 is 25W+25W, and the same pinout. But I don't see any low cost boards for sale.
            Check which one is popular.
            CircuitTest kit
            Newer analog chipamps are TDA7297, LM1875, TDA2030/2040/2050, LM3886 etc. and much easier to find boards and kits.
            What power transformer and heatsink you have (they are the big dollar items) determines what IC's could be used, what power level you want.
            The datasheet shows pin 1 on the left, and a few projects show the parts layout and wiring i.e. https://varikap.ru/usilitel-na-sborke-stk4392/
            Just image search for the part or its relatives, there is plenty of youtube vids as well.
            • Evets
              • May 2024
              • 28
              Thanks, I'm trying to use items I've got to build and modify a simple amplifier circuit. I believe one of the best ways to understand something is to try and build and improve an item.
              • jinu_j
                How to test Subwoofer Amplifier with only a multimeter
                by jinu_j
                Hi Folks
                Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                Problem
                I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                Any advice would be appreciated...
                08-29-2024, 02:05 AM
              • UserXP
                Mackie CR4 amplifier no sound
                by UserXP
                Hi, people.
                I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                10-17-2020, 05:06 PM
              • mikey5791
                Help on car amplifier only one channel works
                by mikey5791
                Hi all forum members,
                Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                08-06-2025, 10:36 PM
              • Francesc V.
                Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                by Francesc V.
                Hi:
                I've realized that one of the channels of this amplifier has no proper sound.
                This is the signal at the speakers output.
                As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                07-15-2025, 01:33 AM
              • waspie
                Aiwa GX-770 Amplifier Protection Circuit
                by waspie
                I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                11-29-2022, 09:58 AM
