Yamaha rx v373 - no power
  • mmoore5553
    • Oct 2013
    • 171
    I got this unit from a friend and been trying to fix it. I have made sure it was not in protected mode and as you can see comes on and then off after a certain amount of time. I can not keep it on long enough to check voltages. I would love a schematic and/or some help. I want to try to get it working. I have pulled the transformer and measured ohms across it and get 2.5 ohms. I would expect the transformer to show higher ohms. Any help is appreciated.
    I then found this video which states the ohms should be bigger. http://www.youtube.com/watch?v=1xIlqe-P1CM
    i did unplug transformer and some of the other leads and found on c1504 5 volts on one leg which i would think it normal and then c1502 i did not find any voltage on any leg ????
    Also if you just hit the power button nothing happen at all. No relay click or anything.
    Here is the video of what is going on
    http://www.youtube.com/watch?v=67GEcKIbqs8
    i have the service manual and thinking a bad cap or something as I do not see some voltages.
    Re: Yamaha rx v373 - no power
    Completely dead?
    Check this video for similar fault
    https://www.youtube.com/watch?v=J42wDUzgx7s
    • mmoore5553
      • Oct 2013
      • 171
      Yes it is completely dead when you hit the power button. I seen that video before but was unsure as I do not think i have that cap. I will take a picture when i get home. I was going to order an ESR meter but i do not do enough small component fixes.
      If i still live in my apartment i would be happy to go dumpster diving for things to fix.
      Once i get paid i was going to order bob parker meter - assembled of course.
      I am too lazy to do things for myself but fix or put together other people's stuff I am game lol.
        ESR meter cannot test the cap shown in video. Only for electrolytic caps.
        • mmoore5553
          • Oct 2013
          • 171
          Wow i did not know that. You saved me some money. I tried to ohm them out in circuit and some read 980 ohms and others where open or showed 1 on multimeter. Then i just ran a continuous check with tone and only one cap actually beeped. I think i am going to replace them all but unsure. I do not know how to test the caps in circuit. But if i am replacing one might as well do all small ones. I have attached the board and the caps i will replace unless you do not think so.
            That does not use the low power standby design it is completely different, my video does not apply in this instance unfortunately.
            • mmoore5553
              • Oct 2013
              • 171
              I understand but voltage is clearly not getting there at all. I am unplugging the other boards and the voltage does not come up. I do not even hear a relay clicking on when i hit the power. Nothing happens at all. I found voltage on one cap and the other nothing.
              • mmoore5553
                • Oct 2013
                • 171
                Any suggestions as i been all over the board looking
                • mmoore5553
                  • Oct 2013
                  • 171
                  It appears to have a standby via the schematics. Here are some shots. the only cap i see in standby is c1507. I take some tests points and do not see the 9.3 at all. I see around 11 volts. So i assume the relay is not kicking on. I also assume it is because it is in standby. I know i could be totally off but that is my thinking. Your thoughts ?
                  c1507 is the blue cap in the previous pictures.
                  i can provide full schematic if needed for anyone.
                  • mmoore5553
                    • Oct 2013
                    • 171
                    Here is another shot where it shows it is going straight into the the standby it appears. But also hits the transformer.
                    I did an ohm test on the transformer and it showed 2.6 I figured it would show higher out of circuit.
                      So at S9, you are getting about 11vdc? What do you get at PWR_RY?
                      • DJduck
                        • Dec 2012
                        • 229
                        • Estonia
                        I remember EEVblog did a video on an older Yamaha receiver that would not power up because one of those 500v poly film caps on the 5V rail was toasted.
                        I can put text here?!
                        • mmoore5553
                          • Oct 2013
                          • 171
                          Budm - I have 13.54 at S9 and at PWR_RY I have nothing.
                          DJduck - I have seen that video and my board is not the same layout but I have thought maybe c1507 causing the error but unable to test it. I do not know how to test the small ones but I did check c1507 has 120 volts AC running through it.
                          Also I checked the power button and only 1.5 volts was going up to it.
                            The fact that you're seeing good standby voltage (variations are expected; that voltage is given when the amplifier has powered on fully and is producing audio) but no POW RY indicates the main board is somehow not sending the right signal. There will be a regulator on one of the boards somewhere knocking the 11V down to 5V or 3.3V; test that.
                              You need that 3V to turn the transistor which drive the power relay to supply the voltage to the transformer. So main board is not doing its job. BTW, the the transformer DC resistance will be very low, but at 60 Hz, the impedance will be a lot higher.
                              • mmoore5553
                                • Oct 2013
                                • 171
                                I am having trouble getting to it as it is on the heatsink. Can i power it on without the regulator being on the heat sink ? they have a bunch of caps in the way.
                                • mmoore5553
                                  • Oct 2013
                                  • 171
                                  Okay I have to say sorry that I do not have this on my desk but i have a TV on it that i am waiting on parts but i have it on the ground trying to take readings but i am not getting anything. Do i need to have everything plugged up ? I do not have the hdmi and rca hooked up or the front panel. As i am just trying to find where the volts are being dropped to five. I am not finding any voltage now but 120 AC. Do i need to have something else plugged in ??
                                  do not worry i have them sitting on cardboard. I have repaired a lot of things in my short life but a stereo is kicking my butt. i will take a laptop repair or tv or anything else but another one of these .
                                  If you want to make fun of my work floor that is okay too.
                                    When I work on something that is crowded and hard to get to check the voltage, I just solder a long piece of wire to the test point, hook eveything back together and just measure the test point on that wire with ref to the chassis..
                                    • mmoore5553
                                      • Oct 2013
                                      • 171
                                      Okay i got the bugger put back together without some parts that i believe do not need to be on and still unable to track some voltages down. I am almost ready to give up. Anyone want a fixer upper for free ..well just pay shipping. Hell i will even go in half to ship
                                      I will even throw in the service manual i bought.
                                      This is a shame though.
                                      • mmoore5553
                                        • Oct 2013
                                        • 171
                                        anyone wanting a receiver to toy with ?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          09-06-2024, 05:59 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
