RCA RT2870-A Surround Freeze
  • Hw00d
    • Mar 2011
    • 15
    Hello, have this receiver (RT2870-A) that stays @ the "Welcome" on the display. Like the eeprom is whacko'd or am I close? Is there a possible reset for it?
    thanks.
    ~Hw00d
    "Don't think inside the box, Don't think outside the box"......Just destroy the box!
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • dmccul2698
    Pioneer DEX-P99rs "No EEProm " diagnostic code.
    by dmccul2698
    Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
    1). Understand the schematic and check the connections between the EEProm and DSP
    2). Check the functionality of the EEProm
    I don't know if this is the unit's problem but it's a place to start.
    I have little to no electronic experience...
    04-08-2024, 05:32 PM
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
  • edgarmg15
    Damaged EEPROM on TV Vizio E320-A0
    by edgarmg15
    Hi everyone
    I´m trying to repair a TV Vizio E320-A0 that I found in the street
    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
    11-19-2022, 03:46 PM
