Advice on headphone amp and DAC for Grado GS1000i
  • ba001
    • Apr 2013
    Hello all,
    I recently picked up some used Grado GS1000i, in excellent condition. I thought I might use them in my main Naim system but I think I'm going to use them at my desk with my iMac.
    I'm eyeing up the Naim DAC V-1 as this looks like a good solution having a DAC and headphone amp. Ideally I was looking to spend less than this, and wondered if anyone has any recommendations to partner with the iMac and Grado? Also, I was hoping for something compact, ideally more so than the DAC V1 (if that's possible)
    Currently I am using the headphone out from the iMac. The Grados are the most detailed bit of kit I have ever heard, but this resolution could come at a cost if i'm not careful - I imagine they could be quite fatiguing over long periods with the wrong match. I imagine a smoother / warmer amp would suit them well. Saying that, they are sounding damn nice even from the iMac headphone out!
    Any thoughts / advice much appreciated. Thanks!
    My Personal Blog!
  • 999999999
    • Sep 2006
    • 774
    Re: Advice on headphone amp and DAC for Grado GS1000i
    I suspect a better place to ask is at Head-Fi. Let them know the budget range you're looking for, or there are a lot of good sounding options for much cheaper than a manufactured retail unit if you're willing to build it yourself.
    They have member created and peer reviewed designs that are pretty easy to follow along with some having professionally made PCBs so all you really need is ability to read a schematic and use a soldering iron, although often they modularize and one design would be a dac and another the headamp, but if you wish you could just put both in the same case and it would be much smaller than the Naim DAC V-1.
    http://www.head-fi.org/f/3/equipment-forums
    http://www.head-fi.org/f/6/diy-do-it...lf-discussions
    Don't forget to check their For Sale / For Trade forum
    http://www.head-fi.org/f/6551/amplif...for-sale-trade
    • badalex
      Banned
      • Aug 2013
      • england
      i am sorry, i can't help you for this question. maybe you can go to the local store to consult some professionals.
      • ba001
        • Apr 2013
        alright, thx
        My Personal Blog!
        • ryogadan78
          iMac A1418 - No LED, no power after overvoltage on Ethernet port
          by ryogadan78
          Hi guys, I need your help again.
          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
          06-10-2025, 03:49 AM
        • Stephen
          iMac M1 DFU restore issue
          by Stephen
          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
          this is the message it gives me with the error
          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
          03-07-2025, 12:19 PM
        • Stephen
          iMac 27” 2020 Boot issue
          by Stephen
          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
          08-16-2024, 09:32 AM
        • tommy97
          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
          by tommy97
          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
          Any ideas what might've...
          04-20-2024, 04:48 AM
        • Tom_x
          Rotel RSDX-02E headphone mode
          by Tom_x
          Hi!
          I need help to disable headphone mode on this unit!
          Someone played buttons on front panel and now no sound on speakers. When i push the Surround button, only HEADPHONE MODE appear
          Amplifier does not have headphone connector in front, only 3-pin on main board and factory grounded the hpsw line
          i tried all combination on front panel, but no success....
          In sevice manual no info about full reset, only reset speakers settings to default.
          Anyone have info?
          regards
          Tom
          12-22-2024, 11:33 PM
