Fisher CA-880 Stereo Amp from 80's sound from only one channel
  • ntehicks
    • Mar 2011
    • 272
    Re: Fisher CA-880 Stereo Amp from 80's sound from only one channel
    I am amazed at how different the 800 model versus the 880 is. I started with the signal that enters in through the rca plugs. and followed that through the tuner selector switch. the switch is working good. I think it has to have something to do with the board right under the volume. I think that is the pre amp. I have looked to see if I could find the CA-880 schematic. not sure if one is available.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4963
      • New Zealand
      This is the preamp board you are talking about, right? The one you said you already tried replacing the op-amp on?
      I assume the green wires are signal input, the white ones are output, and the red\blue are power?
      I would check the power supply, what voltage you get on the red\blue wires? Is it the same on both pre-amp boards? Check the opamp supply pins 4 and 8 also, what voltage across those? is it the same on both boards?
      Can you post a clear photo of the foil side of the preamp board? It would be easy to draw out a schematic.
      -David VanHorn
      • ntehicks
        • Mar 2011
        • 272
        I am having a hard time tracking down what is pulling down the resistance. I have started to test OP amps I have one that on pin1 and pin7 are both suppose to be output but I only get output on pin 1. I tested one on the tone board and pin 1 is over driven and distorted and pin 7 in very weak and quiet.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4963
          • New Zealand
          First of all you should verify that the opamp is getting the right supply voltages. If it is not getting the right voltages it can start clipping the outputs and causing distortion.
          Compare the supply on the working preamp board with the non-working one, check that both op-amps have the same voltage on their supply pins (pins 4 and 8)
          -David VanHorn
          • ntehicks
            • Mar 2011
            • 272
            Red and Blue wires are 20.5 -20.5 volts and the op amp is getting 20.1 and -20.1
            The green wires come from the volume VR and there is a Brown wire the goes from the volume VR to the Tone Board. The input in the back of this unit goes to the selector board and then there is a wire that goes to this toner board.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4963
              • New Zealand
              #26
              The voltage may be too high - datsheet says maximum +/-18v supply for that IC. Is it the same on both boards? Check your voltmeter doesn't have a flat battery?
              I attached what I think is the schematic of the preamp and the opamp datasheet
              -David VanHorn
              • ntehicks
                • Mar 2011
                • 272
                So I removed the Op amp to see if I could get some different readings. still getting one channel really low. sometimes the one channel that works will stop and if I pulling the mic mixing knob the channel restores. so I did some testing with wire coming from the mic plug. the red wire which is the side that has the short once removed from the toner board. the short goes away. but when you play now no sound at all will play. I have one connector on my toner board it is labeled 10 and it has no wire going to it. not sure if it is suppose to have a wire or not. it is the only connecter on the tone board that has no wire. I did find one cap that looked bad but it tested out perfect. I replaced it anyway.
                  • 31058
                  so this has 2 pre-amps right?
                  swap the outputs going into the driver stage and see if the fault jumps to the other channel.
                  if it does, put the wires back,
                  and swap the pre-amp inputs over.
                  you should be able to find if the fault is before, on, or after the pre-amps that way in a few min's.
                  • ntehicks
                    • Mar 2011
                    • 272
                    ok so I swapped sides on the volume control and the other side works. I cleaned the mic pull and volume and the balance knobs and now both channels work. thanks for your help.
                      So it was just dirty pots and switches?
                      • Sik_6ty_Sixx
                        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                        by Sik_6ty_Sixx
                        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                        02-18-2025, 05:06 AM
                      • eccerr0r
                        old X58 triple channel board... memtest86 memory speed?
                        by eccerr0r
                        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                        06-28-2025, 09:06 AM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                      • samson7point1@yahoo.com
                        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                        by samson7point1@yahoo.com
                        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                        The player processes the audio signal using two different reference frequencies. The "R"...
                        04-30-2024, 11:22 AM
