Fisher CA-880 Stereo Amp from 80's sound from only one channel
  • ntehicks
    • Mar 2011
    • 272
    I was given this Stereo amplifier. I did some searching on Google and thought it was one of the two STK-0080 so I purchased one and installed it. I still get the same small static sound out of the left channel. I have worked on several flatscreen tv's but haven't done much in the area of classic audio. any help would be greatly appreciated thanks.
    Re: Fisher CA-880 Stereo Amp from 80's sound from only one channel
    On the back of the unit, does it have the Power amp input/Preamp output RCA jacks with the U jumpers?
    These units are known to have bad/noisy transistors in the pre amp sections, the legs of the transistors are blackened due to oxidiation.
    • ntehicks
      • Mar 2011
      • 272
      no it doesn't have the u shaped power out pre in. the static was from my input. I was using my cell phone and it was causing the noise. so I get very faint sound out of the left channel. I thought I would rule out the STK-0080 and put the one that is in question in the side that works. does anyone know where I can get a schematic or service manual.
      • ntehicks
        • Mar 2011
        • 272
        Ok so I swapped the two STK-0080 and both chips are good. I found that the signal that feeds the amp one is much louder than the other. does anyone have a schematic that would show me the pre-amp?
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          The first thing I do is clean all the switches and pots. That's fixed a few problems. Use Caig Deoxit D5, spray it in the switch or pot and turn or flip it several times, probably about twenty times. Do this about three times, wait about a day between cleanings. Then follow up with some Caig Shield to replace the lubrication stripped out by the Deoxit.
          sigpicThe Sky Is Falling
          • Radio Fox
            • Jan 2010
            • 281
            One good thing about stereo amps with one failed channel is that you always have the good channel to compare it with.
            Sometimes, when you don't have a service manual available, you just have to do things the hard way & work out the route of the signal yourself, working your way through the circuit comparing the 2 channels until you find a difference.
            ________________________________________________
            Invisible airwaves crackle with life
            Bright antennae bristle with the energy
            • ntehicks
              • Mar 2011
              • 272
              I found a service manual it shows a af amp ic njm4558. does anyone know the best way to trouble shoot this chip.
                Do you have any signal generator? Did you already try cleaning switches and pots yet?
                • redwire
                  • 3907
                  With the STK's, I find internal transistors go bad or the IC bonding wires get loose and tapping them with a screwdriver can flush that out.
                  Does this amp use a voltage amp (i.e. STK3042, STK3082)? It's usually one module that drives two channels, and it can fail. The venerable 4558 is usually in the protection circuit.
                  Here is the internal circuit of the STK0080 and STK0080II family:
                  • ntehicks
                    • Mar 2011
                    • 272
                    I have tested by removing the stk-0080 and swaping the chips around. I get the same results. I have tested the audio that is fed to the input on the amp board one is significantly lower than the other that is why I think it has something to do with the pre amp. I have tested the VR Main volume pot and It test out perfect on both sides. The one thing I found that has me thinking I need to dig into the circuit that is just before the volume is that two wires on the volume board were touching each other.
                    • ntehicks
                      • Mar 2011
                      • 272
                      The reason I think it is the 4558DX chip is in the service manual it shows a preamp between the main volume control and the STK0080 power amp. in the picture with the chip the green wire comes from the main volume control and on the other end of the board the white and silver wires go to the main amps or stk0080's
                      I have included the pdf file that is in the service manual to show the diagram.
                      • redwire
                        • 3907
                        One technique I use is to inject 1kHz sine wave into both channels (tape/aux) input, and use my multimeter on AC millivolts and compare the reading between both channels. I start at the balance potentiometer and volume control. This way is easier to find a few dB difference- which stage might be lazy (pre/pwr amp etc.)
                        Otherwise you could compare DC voltmeter readings too. The 4558 is just a generic dual op-amp you could swap out, if it's in a DIP8. I find any newer op-amp sounds a little better I.e. LM833
                        • ntehicks
                          • Mar 2011
                          • 272
                          I replaced the OP amp but still have very low signal. I did put a low signal on each amp circuit and both STK0080 are working. so it looks like I will just have to trace back the channel starting with the RCA inputs.
                          • cadiman
                            • Mar 2010
                            • 397
                            I normally pull the op amp after confirming outputs and signal trace (even with an old cheap scope) to check preamp in signals. All 80`s stuff is re-solder even on the output transisters. stk outputs were the good 80`s it got much worse from there.
                            For sure clean all input switches and contact switches as these were mostly the reason for preamp issues. no or low signal input.
                            • ntehicks
                              • Mar 2011
                              • 272
                              so I started working on this project again. I went through and cleaned the switches and pots. I was testing the main volume control and did get some weird readings. on left channel the pot is normal 0 - 170k but on the right channel I get 0 - 56k. so I removed the pot from the circuit and tested it and it test good 170 on both. so I must have something that is pulling down the circuit. not sure where to start testing. I have included a picture of the pot. as well as the board that the pot wires goto.
                              when I test c03 and r03 in circuit I get 96k when I test c04 and r04 in circuit I get 98k not sure of that would be far enough off.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4953
                                • New Zealand
                                Is there anything in parallel with the pot?
                                -David VanHorn
                                • ntehicks
                                  • Mar 2011
                                  • 272
                                  here are some drawings of the circuit.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4953
                                    • New Zealand
                                    Doesn't really help though since it's for a different model...
                                    Can you post a clear photo of bottom and top side of the board your volume pot connects to and show where it connects?
                                    -David VanHorn
                                    • ntehicks
                                      • Mar 2011
                                      • 272
                                      ok here is some top and bottom pictures.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4953
                                        • New Zealand
                                        In regard to your schematic notes - What about the board you said goes between the pot board and the tone control board? If that is where the pot connects to then something there is more likely to be affecting the resistance reading.
                                        Did you check back through the tone board and other board to the pot board to find out where the signal becomes lower?
                                        -David VanHorn
                                        • Sik_6ty_Sixx
                                          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                          by Sik_6ty_Sixx
                                          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                          02-18-2025, 05:06 AM
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
