Identify cap problem in amplifier help
  • Gutch220
    • Oct 2006
    • 6
    Hi, I suspect that my caps are going bad (already are?) in my amplifier. It is a 1990 Marshall JCM900 4100, so the caps are at least 15 years old. The symptoms are intermittent fuzziness/static accompanied by random drops in volume along with an oscillating hum. There is no visible leaking in any of the caps. For example, I will let a chord ring out for a few seconds and I can hear the oscillation go up and down, this is followed by a static and intermittent drops in volume.
    My question is; are these signs of failing caps? and, what are the audible signs of failing caps?
    Right now there are two LCR 50uF+50uF, 500vDC caps. The tubes are brand new.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Identify cap problem in amplifier help
    you can find nos caps for these amps
    has it ever been serviced? there is other stuff to attend to. wait for KC8 to pass by and advise.
    • Gutch220
      • Oct 2006
      • 6
      It has been serviced. As metioned, the tubes are brand new with proper bias adjustment, I remelted questionable solder joints, cleaned all sockets, pots, and switches, and all of the components on the PCB still look good (no burnt out resistors or anything). I just want to know if I should focus my energy on the caps.
      Here is a pic of the two caps I got from online (its not my personal amp)
      • arneson
        • Sep 2005
        • 1267
        Bad caps are very possible, even likely, but they would be located under this chassis.
        Jim
        • kc8adu
          • Nov 2003
          • 8829
          • U.S.A!
          bad main filters would cause a constant loud hum.
          sound more like oscillation.
          open bypass caps.
          can be an intermittant short in a tube too.
          • Gutch220
            • Oct 2006
            • 6
            what would the sound differences be between bad bypass caps vs. bad main filter caps?
            also, where would the bypass be on this schematic?
            Schematic
            *if they aren't on here in can provide other schematics.
            • japlytic
              • Oct 2005
              • 2085
              Have you tried carefully placing a hot soldering iron close to the non-polarized capacitors to determine the problem (Don't short the bit to anything)!
              Also, I think you should keep the amplifier on for about an hour (no sound) to reform the electrolytic capacitors.
              In the schematic, there are two electrolytic capacitors under the chassis (100V 10uF) for the bias voltages.
              • Gutch220
                • Oct 2006
                • 6
                - no, I've never heard of doing anything like that, what does it do?
                - wouldn't keeping it on for an hour or so only be a temporary solution?
                • Gutch220
                  • Oct 2006
                  • 6
                  I just looked at the bias caps you mentioned and there is no visible damage to them that I notice.
                  I just played the amp for a bit and left it on for about an hour with no problems what-so-ever which makes the problem really annoying. It will be fine for days or weeks then out of nowhere it will spuratically go intermittent on me. This is no good because if that happened at a gig, I'd be in trouble.
                  I will order two filter caps tomorrow just to have them on hand.
                  • arneson
                    • Sep 2005
                    • 1267
                    The caps under those tubes would not look bad, but it's likely they are dryed up.
                    It is more interesting that the tubes are new, the caps under them should be replaced.
                    Jim
                    • Gutch220
                      • Oct 2006
                      • 6
                      well I ordered 2 new filter caps this morning since I will eventually need them in the future and they don't make the LCR caps I need anymore so I might as well buy them before they disappear........... after doing some more reading and talking to people I believe the problem also might be the tube sockets. they might need to be tightened around the pins a bit. I will try doing this with a small eye-glass screw driver later. If it doesn't work I will start replacing screen grid reisistors.
                      I hope I don't have to replace the sockets, they are a pain in the ass.
                      thanks for your help
