Radio Shack Pro-97 scanner
  • ryan74
    • Oct 2012
    • 471
    • usa
    This scanner volume does not work. I can hear the National weather frequencies(I use because it is always on) with my ear against the speaker but when I turn the volume knob up or down the volume doesnt change.
    I dont know where to start, the volume/squelch knob does not seem damaged and I don't know if/how it can be tested.
    I can hear a change in static sound from adjusting squelch(normal) so I assume that part of knob works.
    Any advice?
  • ryan74
    • Oct 2012
    • 471
    • usa
    Re: Radio Shack Pro-97 scanner
    I found this at radioreference.com
    Quote: There's a known issue with the volume pots on these things going bad. Mine did the same thing right at the one month mark. Question: if you put the speaker right up to your ear can you hear squelch rushing very very faintly as you turn the knob?
    Looking at the schematic, there are a few components between the discriminator output and the audio amp. The beep signal is inserted AFTER the volume pot. I agree and think the volume pot is VERY LIKELY the problem.
    I found the part number
    12429163 from RSU(radioshack unlimited)
    It is $16 if it is still avail.
    I wouldn't mind an alternative. From what I read it is 50kohm volume and 10kohm squelch.
    • ryan74
      • Oct 2012
      • 471
      • usa
      I pulled the pot and volume side tested bad.
      Im not sure if I can match up a replacement.
      pot # HTA503
      U245
      B10K
      I took measurments the best I could and posted on pic.
      • ryan74
        • Oct 2012
        • 471
        • usa
        I decided not to fix after finding out analog scanners will be obsolete soon with the digital switch. Plus the part is out of stock.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah... It's a bummer. My scanner already is useless (a nice digital controlled one I might add). I can't pick up any emergency channels.
          sigpic
          (Insert witty quote here)
          • imp
            • Aug 2010
            • 125
            • Sweden
            Please note that you also have at least one bad capacitor on the board (first picture, lower right corner)
