Delco AM/FM/CB/Cassette radio 3.5MM input addition
  • dyeager535
    • Dec 2012
    • 6
    • usa
    Hello!
    Hoping someone on here can help me. I saw another post about a Delco radio, so I'm optimistic!
    This radio is an early 80's model, which has the LCD display as opposed to the "older" style with manual tuning.
    Since this is what fits in the vehicle, it's what I intend to stick with. Up to this point I've been using a cassette adapter to plug my phone into, which allows me to be "hands free", or play MP3's from it. Of course, the cassette deck appears to have now failed.
    I have had the idea to add a 3.5MM input jack to the radio for some time, but had little incentive to do so until now. My two concerns are that I have no idea where the jack would be connected so as to "simulate" a tape being played, and how to trigger the radio to switch to the auxillary input the same way it does when a tape is inserted. Those are the two I really need help with. I would guess the switching portion is electro-mechanical since the cassette physically moves the tray, which switches it from the radio to cassette playback, but I know anything can be modified or changed with enough time and ingenuity.
    Obviously the radio is going to have to be at least partially disassembled, and some soldering will have to be done, and I have no problem with that. It's pretty obvious from the LCD on mine, and other comments I've seen, that the soldering on these tends to be pretty poor from the factory, so I can kill two birds with one stone so to speak, when I open it up.
    Thanks for any help!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Delco AM/FM/CB/Cassette radio 3.5MM input addition
    Whilst it does not answer your question these take no skill ingenuity or effort and very little cash?
    http://www.ebay.co.uk/itm/Car-MP3-pl...item232604869b
    Here is a one from china less than USD3
    http://www.ebay.co.uk/itm/Wireless-F...item20c65870af
    • dyeager535
      • Dec 2012
      • 6
      • usa
      I had one similar, pretty cool, but I'm trying to get away from extra gadgets if I can! I really like being able to use the phone for an MP3 player, it eliminates one more thing I have to keep track of and swap between vehicles, and no having to worry about switching something off, or changing volume, etc., when a call comes in.
      • randtek
        • Oct 2011
        • 280
        • US
        Unless you have complete schematics on the unit, it is going to be difficult to make this work. The cassette player will have sensors to detect if the tape is inserted, and reels are rotating. you will probably need to fool those in order to use the cassette circuitry as an auxiliary input.
        • SuperDuty
          • Mar 2011
          • 299
          • France
          I did that to my 1984 Delco unit. It's pretty simple actually, just locate the harness of the cassette player, find the wires for the left and right signal, and the wires for the radio and cassette signal, and the 12v. All you need is some wires, and jack input and a six poles DPDT switch.
          Here's a simple schematic I made, it needs an update but if you have the unit in front of you, it should be easy to understand :
          • dyeager535
            • Dec 2012
            • 6
            • usa
            Don't have it in front of me, but thanks for that! Been looking at the manuals available on ebay, too rich for my blood. From your diagram it is as simple as I was hoping it was wiring-wise.
            Is it feasible with a little more effort to make the radio automatically switch when the input is plugged in? I understand what needs to happen to make it switch, and the 3.5MM plug doesn't appear to provide a means to accomplish that. Switch isn't terrible, I'd prefer to make it automatic if possible though.
            • lti
              • May 2011
              • 2558
              You can get those jacks with switches built into them.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Most of them are just like that actually, and they go for peanuts. I just patched an aux input into a Panasonic stereo yesterday. Tapped into the CD player signal.
                The only snag i ran into was that the IC amp had a muting pin, which was activated when the CD was on pause or stop. I just disabled the muting (grounded the pin) and everything worked fine. Your radio is old enough to not have this, so don't worry.
                A working TV? How boring!
                • SuperDuty
                  • Mar 2011
                  • 299
                  • France
                  Yeah I thought about it but I only had some scavenged parts on hand :P
                  • dyeager535
                    • Dec 2012
                    • 6
                    • usa
                    Can any of you link to one of these? I find the jacks, but not ones that mention switching. How many pins do they have then? 7?
                    Edit: Ok, I've found 8, 9 and 11 pin variants, but no pinout for them. Looks like the "front" five pins are the speakers/ground, and the back would be the switching portion, having the pinout for those would be handy!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      All jacks i've used so far have 5 pins... Ground is shared, the two (left and right) signals are switched.
                      • dyeager535
                        • Dec 2012
                        • 6
                        • usa
                        Might have to humor me a bit.
                        Based on the wiring diagram shown above, with a 5 pin jack, how would you switch the radio and cassette wires, along with providing the 12V? I thought that was the "shortcoming" of the 5 pin jack when wanting to automatically switch cassette(or aux input in this case) to radio?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          You could tap into the radio tuner signal not the cassette. Turn the radio on, plug the jack in, you have MP3. Unplug the jack, you have radio.
                          • dyeager535
                            • Dec 2012
                            • 6
                            • usa
                            Captain Obvious just hit me. Thanks! Much simpler, duh!
                            • mikey5791
                              Sony CFS-5000S radio cassette player no FM reception
                              by mikey5791
                              Hi forum members,
                              In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                              Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                              I opened the casing inside and checked for any dry solder, burned component or loose wires...
                              02-24-2023, 03:48 AM
                            • shelby5041
                              clock radio / radio lifespan?
                              by shelby5041
                              hi
                              ive got a modern digital clock radio approx 15yrs old
                              my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                              since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                              the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                              it uses very little power just a few watts i would imagine that may have something...
                              09-14-2024, 03:30 AM
                            • UserXP
                              Vintage SONY Digital Clock Radio ICF-C12W no audio
                              by UserXP
                              Dear all,
                              I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                              i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                              My question is, do you know of this brand of capacitors and how bad are...
                              07-21-2025, 08:35 AM
                            • praveenramavath
                              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                              by praveenramavath
                              Hello All,
                              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                              https://www.hifivision.com/threads/m...-screen.98243/
                              Troubleshooting Summary: Majority Internet Radio - Flash Chip
                              04-26-2025, 09:08 AM
                              HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                              This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                              09-12-2024, 02:00 PM
