Sherwood Newcastle R-772 Receiver no Audio
  • Virden1
    • Nov 2012
    I have a Sherwood Newcastle R-772 receiver that has no sound. The components were hooked up using Optical and Digital coax, and just stopped working one day. I double checked the inputs to make sure they were assigned properly and eveything checked out ok. If I use the analog audio jacks I get sound. I did a factory reset on the unit and still have the same issue. Checked the digital audio board for visible bad parts and couldn't see anything wrong. Any ideas?
    Thanks,
    Steve
  • Cornito
    Denon AVR-2700H audio stops while receiver still works
    by Cornito
    Hello team,
    I've got a new issue with a Denon Avr-2700H.
    After several minutes working, receiver stops playing sound with a poc eared in the speakers.
    Receiver still work and display video with error message on display.
    Seems to me that is the main output relay.
    I'm looking for the service manual that I can't find for the moment.
    Does somebody have it?
    Regards...
    08-03-2025, 06:10 AM
  • JRade
    Audio video receiver KENWood KR-V990D,no sound
    by JRade
    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
    I replaced the capacitor C303/0.047F, nothing changes.
    I'm asking for help, what should I do next?
    Thanks in advance!...
    08-05-2025, 10:23 PM
  • kotel studios
    Lantec PULSE 386 subwoofer - no audio output
    by kotel studios
    Hi
    I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
    After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
    The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
    11-29-2025, 04:15 AM
  • PapaFi
    Teac AG-D9260 AV Receiver Audio Problem
    by PapaFi
    After turning ON the unit, as the 2nd relay clicks. No audio response even radio or from dvd player. During vol adj from remote/manual adj as the vol increased there's a loud "tic" sound from the speaker. Even up to max vol still no audio. As you played the adj +/- from remote/manual along with the loud "tic" sound. All of a sudden the audio turned ON but uncontrolled vol even +/- adj. looks the audio is stuck on its level of vol. Even max/min audio level is the same (but the "tic" sound still there as the adj from min to max and vice versa and of course as you reached...
    08-26-2020, 04:04 AM
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
