sherwood Newcastle R-672 A/V Receiver Shuts down
  • Virden1
    • Nov 2012
    • 4
    I have a R-672 that powers down to standby mode randomly. It was in a cabinet that held a lot of heat, and was wondering if it was triggering a heat sensor or something from getting too hot. I took it out of this cabinet and and let it sit to cool down for several hours. I unplugged everything but the power just to make sure there wasn't a short from a wire or something and still had the same issue. I then did a factory reset to the reveiver, powered it up, and still had the same issue. I took the cover off the unit and saw no visible problems to any capacitors or anything. Any ideas of what's going on?
    Thanks,
    Steve
  • 999999999
    • Sep 2006
    • 774
    Re: sherwood Newcastle R-672 A/V Receiver Shuts down
    Probably a leaky transistor causing excessive current -> overheat condition. Look at the output stage, the main output transistor, then those that bias it and so on.
    • Virden1
      • Nov 2012
      • 4
      Ok will do!
      • BigPete
        Intermittent display on Sherwood Newcastle R-965 Receiver
        by BigPete
        I'm working on a Sherwood R-965 at the moment. It came in with relays clicking constantly and also going into protect mode.
        I've re-soldered a lot of dry joints and replaced quite a few capacitors and now it works, but I still have one problem I haven't solved and would like some opinions.
        The vacuum display is quite intermittent. Sometimes it won't turn on, sometimes it will turn on but the characters, numbers and letters are frozen on, regardless of which buttons are pushed. And sometimes it works flawlessly. If the display doesn't turn on initially, restarting...
        08-25-2024, 02:48 AM
      • CDNBrewer
        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
        by CDNBrewer
        Hello Everyone,
        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
        Symptoms:
        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
        • I swapped the Left and Right surround
        08-05-2025, 09:29 PM
      • wolf1976
        wireless receiver for 6 speeds fan control with remote control
        by wolf1976
        hi i have a receiver that is destroyed from the overvoltage i guess
        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
        the motor fan has not label
        i have an other receiver operational
        In your opinion can i measure the voltage at the output ?
        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
        thanks in advance...
        07-23-2025, 03:12 PM
      • huzo
        HP Omen shuts down when loading OS
        by huzo
        The model is 15ec-1061nm
        Board number is DAG3EDMB8D0​
        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
        10-29-2024, 12:05 AM
      • CdDvdFlash
        DSE GE6878 possible TV receiver dying remote not working well
        by CdDvdFlash
        For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
        07-03-2024, 03:55 AM
